Members LK1 Posted December 16, 2020 Members Report Posted December 16, 2020 Hi all! Sewing and leatherwork newbie here, in need of some quick help, my stitch is loose! My top stitch seems to be leaving big hoops/loops and really loose holding stitch, But the underneath is a decent stitch? I’ve tried the two thread tentioners, lowering the needle position, made sure the bobbin catches and is in the correct position and still to no avail! Somebody please help a guy out! I can provide pics with whatever you guys need, many thanks! Quote
Members Constabulary Posted December 16, 2020 Members Report Posted December 16, 2020 (edited) most important is what machine are you talking about - so yes, please post as many pictures as possible. Also please post pictures of your top thread path. Edited December 16, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members LK1 Posted December 17, 2020 Author Members Report Posted December 17, 2020 Thanks for the speedy reply @Constabulary! It’s the generic replica “cobbler hand crank sewing machine” from amazon but it’s the exact same green model that’s all over youtube, I’ll send a link to a video a guy had one the exact same as mine. https://youtu.be/JeKI2tjFZ24 ill take some pictures and whatnot soon! Quote
CFM Frodo Posted December 17, 2020 CFM Report Posted December 17, 2020 generic answer my ''green amazon'' cobbler does not like my thread to pass through both thread tensioners. so i only use the tensioner closest to the front of the machine Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members LK1 Posted January 21, 2021 Author Members Report Posted January 21, 2021 On 12/17/2020 at 1:16 PM, Frodo said: generic answer my ''green amazon'' cobbler does not like my thread to pass through both thread tensioners. so i only use the tensioner closest to the front of the machine Interesting take! I’ll definitely have to try this because I’m still having problems, now it’s snapping after the needle making me think it’s the foot being too sharp and ripping the thread or some point being too tight, but I’m almost certain it’s not my tensioners as they’re the loosest they possibly can be! I’ll upload some pictures tomorrow because I’ve spent hours testing today to no avail again! Had this problem for a couple weeks now some days I feel I’ve got it down then I’m back to square one resetting everything to try and get a clean stitch without problems! Quote
Members Squid61 Posted January 21, 2021 Members Report Posted January 21, 2021 I am deeply grateful for this thread. I played with idea of getting one of the green monsters but now there isn't a chance. Quote
Northmount Posted January 22, 2021 Report Posted January 22, 2021 Moved to leather sewing machines Quote
CFM Frodo Posted January 22, 2021 CFM Report Posted January 22, 2021 (edited) OK guys, I am going to try and tell you how to get your machines working go to this link here How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube if you have questions after seeing this, i can help you, i am not on this forum every day., pm me if it is the needle, put your finger under the machine, roll the crank, the neddle should tap your finger with out cutting you. if you do not feel the needle, it needs to be lowered, if it draws blood it is to long and the needle bar needs to go up Edited January 22, 2021 by Frodo Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
DonInReno Posted January 23, 2021 Report Posted January 23, 2021 On 12/16/2020 at 1:19 AM, LK1 said: My top stitch seems to be leaving big hoops/loops and really loose holding stitch, But the underneath is a decent stitch? I have a non-answer that probably won’t solve your problem directly, but will hopefully help get you closer. The patchers are interesting little machines, and when all the issues are sorted out they do make a stitch, but you’ll have to fix a half dozen issues just to barely have a reliable machine. First, throw out the thread that comes with it and order a spool of 92 weight bonded nylon. If you later want to try a thicker thread you can, but this is the easiest of the thicker threads to figure out - rather than pushing the limits right off the bat, get 92 to work first. Second, remove roughness from everything the bobbin thread comes into contact with. Use some 400 grit sandpaper and polish off sharp corners that the thread has to drag across - including the little holes in the hook that the thread gets dragged through. Third, get comfortable with thread tension adjustment. Only use one tensioner - the second is intended for winding bobbins - regardless of how many well intentioned people say to use both don’t do it. If two tensioners were any advantage, every industrial would have two, but they don’t. Make sure your hook has a bobbin thread tension spring - some only have holes and no spring - order a new hook if need be, but you have to have a tension spring. Now adjust the top tension so the knot is centered in the material - normally the bobbin tension is close enough to get you started so just leave the bobbin alone and make adjustments with the top tensioner. Every time you sew check this and make adjustments as needed. Fourth, there’s no getting around the proper clearance between the needle and hook and proper timing. If you’re lucky your machine will make a basic stitch as set at the factory, but there is 1 in 100 chance it’s set correctly. I’ve read two dozen descriptions of how to do this on the patcher forum on FB and most people are well meaning, but they are a little off base so don’t believe the first write up on his. Just keep in mind as the needle is at the very bottom of its stroke, and then rises the thickness of a nickel, the point of the hook should just be inline with the needle about 1/16” up from the eye of the needle. The point of the hook should be as close to the needle as possible without actually touching it. Order new high quality needles - always make your timing and hook clearance adjustments with a new needle. A slightly bent needle is the easiest thing to correct and should be the first thing you do when troubleshooting. Fifth, practice sewing as much as possible to get a feel for the machine and what issues are normal and which are signs something is wrong. It’s not possible to just jump in and start sewing on a project and expect it to turn out right. Good technique isn’t easy, or everyone would be making professional looking items from day one. We all want to help someone who is putting in the time to increase their skills, but it makes me cringe when someone unwraps a patcher and starts complaining the monofilament fishing line included with the machine doesn’t make a good looking stitch and they just ruined a good belt with crooked stitches....oh, and they don’t want to practice. Sixth, every part of the patcher, every bolt, every adjustment, every everything, is likely to cause problems at some time in the future because of the inexpensive nature of the construction, so don’t expect miracles and accept troubleshooting as a necessary skill when running one of these. There are a lot of articles out there describing how to sort out each part to make it more reliable. Like I said, this isn’t really a specific answer to your problem, although your issue is most likely somewhere in those first four points. Fix and eliminate as many small issues as possible and the solution to bigger problems will be much much easier to diagnose. Good luck and let us know what fixed the problem! Quote
Members LK1 Posted January 23, 2021 Author Members Report Posted January 23, 2021 On 1/22/2021 at 4:14 AM, Frodo said: OK guys, I am going to try and tell you how to get your machines working go to this link here How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube if you have questions after seeing this, i can help you, i am not on this forum every day., pm me if it is the needle, put your finger under the machine, roll the crank, the neddle should tap your finger with out cutting you. if you do not feel the needle, it needs to be lowered, if it draws blood it is to long and the needle bar needs to go up So I’ve watched most of his videos to get me to this point and with a few of your guys help! I’m using a thick bonded thread (T70#69 Bonded Nylon)I’ve stopped using the second tensioner and the machine will stitch to a point and won’t snap thread between the crank and tensioner, which is good because sometimes it would so that problems out the way! I’m also cranking the machine fully around and just feeling the tip of the needle (just a light press touch) So that’s all good too, I’m just running into a problem where now if I stitch it’ll go for a while then hit a stop and my thread is breaking under the needle somewhere, it’s catching the bobbin thread fine, so I know the timing and shafts are all correct and in place ( everytime I reset the bobbin etc I’m getting the thread catch perfect) I’ve released the little latch that makes the bobbin tension tight and still no avail, but it’s going further than it has done before! also just ordered some 400 grit to sand down my presser foot and other sharper edging and got some plastidip so I don’t run into the sharp presser foot problem again, Is there anything else you guys can think of? its just like it’s almost shredding the thread or cutting into itself somewhere as I’m sewing so I can never finish up a job cleanly without a thread stressing inside my needle and leaving it with a unthreaded loose thread after some nice tight stitches:( But I’m almost there guys! And again thanks for all the help on the forum it’s much appreciated! Quote
