Hello! I'm attempting to make a pouch for a new pocket watch I found and I'd like to try to wet-form the leather around the pocket watch. Does anyone have any tips?
1. do not wet form around the watch. carve up a wood or mdf block to mould around and attach that to a bigger piece of wood.
2. use the stretchiest belly leather you can get
3. use a frame over and around the block former covered in wet leather and clamp it down real tight
Yeh, the last thing you want is moisture getting into the watch .
Just make a mould the same size & shape. I have some pine off-cuts that I use , and some MDF like fredk said. I put a coating of oil on the wood so it doesn't  get affected by the moisture.
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • CFM
Yes I have a couple of tips for you you,
Here is a small wet formed pouch about the size of your watch .    ...It is for  my sewing needle packs
Measure your watch, cut the bottom piece the measurement you want the item to be
cut the top piece 1/4'' wider
are you going to line the pocket with  a soft 2 oz leather?
add that   and leave it larger than you want.
 trim off the excess liner go ahead a decorate, stamp dye the pieces
then sew every thing together,
next, drop the pouch into a pan of water for 15 /20 seconds
put the watch in a baggie, shove it into the pouch, use your fingers to form the details
set it out of the way and let it dry
I form pistols and knives, and a baggie works just fine,
20201230_074739.jpg.95f56353176d2dff66255a53b63eb371.jpg20201230_074749.jpg.6fa41508a9f7b9f420e71ce248b90732.jpg
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
Stand your ass up during the National Anthem
Guess I'm the odd man out here -- I think you certainly could use the watch to form over.
Since you say WET FORMING we'll assume you're talking about vegetable tanned leather, and since its a watch we'll assume fairly thin veg tanned. Maybe 2/3 or 3/4?
Cover the watch with plastic wrap... you won't gain enough bulk to matter.
5 leather patterns
No, you are not the odd man out, I agree with you, put the watch in a sealed plastic baggy or cover it with plastic and use the watch form the leather.
  • CFM
Yup. That's what I did when molding a leather case for my Zippo, and also when making a couple of end sleeves for my phone, to cover the cameras semi-permanently.
(Jump to @ 1:05 in the video.)
He used a similar method to make a case for an electronic gadget, so, if you wrap your watch properly, it should be safe:
Edited by Hardrada
Great video, I liked the slicker twirl, that was pretty slick. Lol
Thanks!
Edited by ryano
Yeah, I was planning to use the watch after covering it with plastic and using a fairly lightweight leather. I'm not certain the weights but probably a 3-4oz. Thanks for the tips I'll be sure to post some pics when I'm done.
Also, @Hardrada I love your videos! I'm subbed to you on youtube ^.^
  • CFM
Whoa! They're not mine! That's a Korean crafter there. I was just linking you to what I've found useful. :yes:
Oh! LOL I thought they were yours xD
Well,  thanks for posting his Korean videos.
