25 minutes ago, Uwe said:
I just now installed it on my CB-3200 for the first time
What is the cost??
kgg
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
1 hour ago, kgg said:
What is the cost??
kgg
Uwe (pronounced "OOH-vuh" )
Links: Videos
Thank you Uwe. It is a nice conversion method of achieving 90 degree synchronized binding. For us Canadians the cost converts to $ 372.32.
kgg
Thanks for sharing the details of this Uwe. Looks very interesting. Do let’s us know how you get on with it and what the capabilities are.
Hope it works out well
Typical TSC441, Juki 1508, Singer 201, Singer 29k, Sailrite LSZ, Pfaff 238, Pfaff 335, Adler 98, Adler 166
Thanks for posting those pics Uwe! You're always at the front of the pack with cool innovations like this   I was wondering if you have tried using any right angle binder block?  I've purchased some  from you for my 335 in the past and I'm curious if they would be usable with this setup.
On 2/14/2021 at 10:11 AM, Uwe said:
Damn .. saying that is   .."very reasonable price".   is understatement on that hardware kit receipt you just posted . Those Pic's you posted, sell themselves .
& Very affordable price to purchase and have a wide selection of different Throat sizes. to have on hand for binding different thicknesses of materials.
Edited by nylonRigging
My invoice pic above shows a KHF2 tape folder that may not work well with this combo. I recommend using the KHF441 tape folder, which was designed to be part of this set..
I had to make three small modifications: filing about 1mm off the tip of the arm to clear the ridge on the 3200 (should not be required on other 441 machines; the ridge is unique to the 3200 design).
The thick shim piece under the tape folder also needed one edge filed down a bit to line up properly with the mounting slots on the tape folder.
The feed dog also was a fraction of a millimeter too wide to fit the mounting slot on my 3200 - this may also be a 3200-only issue. I filed it down a bit and all was well.
I ended up using two 20mm long M4 screws to attach the tape folder to the arm. The included screws weren’t quite long enough.
Edited by Uwe
Links: Videos
Much appreciate the Info, and also the time you are taking putting it to Pics. and Posting . It really helps cutting down on some of the modification headaches that are always there when your getting new  'sight unseen' hardware for a machine .
These pictures look fantastic.  Here is a gif I made up using a light box and turntable.  Something I've been playing with.
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
On 2/14/2021 at 10:57 AM, Uwe said:
For the Cowboy CB-3200 this is the most promising binding setup I have found. I just now installed it on my CB-3200 for the first time - I haven’t sewn with it yet. It’s made and sold by Kwok Hing. It’s the only synchronized binder setup I know of for the CB-3200. It should fit any Juki TSC-441 class machine and, surprisingly, also the Durkopp Adler 205.
Uwe, any pics of items that you’ve sewn with it?
