kgg Posted June 5, 2022 Report Posted June 5, 2022 16 hours ago, JollyDodgerCanvas said: I need to bind a piece for a bag with a 1" radius and also tried to use a needle plate binder attachment for my P1206rb and had the same issues of not being able to turn a corner tight enough. I only use your standard bed mounted inline binder attachments on my machines whether they are on my portable walking foot, flatbed or cylinder bed. The main reasons for me using this style of binder attachment are they more cost effective cheaper ($20 vs $200), gives me more flexibility of tightening / closing the exiting gap of the binder for the tape and the ability of using the same binder attachments on all my machines. I find the run off which sometimes happens is mostly cause by my inattention of keeping the material tightly in the binder attachment as I fed the turn, sewing speed, the thickness of the materials edge, the type of binding tape, the thickness of the binding tape and whether it is raw edge or double folded binding tape. I find the bias tape is more forgiving then nylon or poly tapes but is much weaker. Also bunching can be cause by your binder attachment having to large an exiting opening for the thickness of the binding tape so it doesn't give a nice tight wrap. Doing corners particularly tight corners in thicker materials or with thicker / stiffer binding tape I would suggest adjusting the binding attachment a little closer to the needle so the seam is farther in from the edge. I would also suggest doing some test runs with a different size radius's so you can see how you need to adjust the distance from the needle and the best way to feed the item through the binding attachment to get a good result. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted June 5, 2022 Moderator Report Posted June 5, 2022 Decades ago I was the sewer for a one man industrialist. We needed to edge bind honeycomb material road worker vests, having inside curves at the armholes, and, after trying commercially available units, I ended up having a custom right angle binder made. My deduction is that 1, you need a right angle binder to sew inside curves and 2, it may need to be built for the job at hand. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members shoepatcher Posted June 5, 2022 Members Report Posted June 5, 2022 On 4/14/2021 at 11:36 AM, Runzeigrun said: Thank you very much!!!! I will reach out to them! Will not be cheap glenn Quote
Members JollyDodgerCanvas Posted June 14, 2022 Members Report Posted June 14, 2022 On 6/4/2022 at 11:30 PM, nylonRigging said: You say your doing/Binding Canvas fabric . What is the thickness of the material you are feeding into that 441 Binder ? also what size thread you using on that canvas ? Can you post a Pic, of the 'bunching' problem you get ? . did you buy the feet offered/supplied by KH on their 441 setup ? . or, did you cut/trim your own for the Binder ? the feet set-up is a fine point to complement the binder system and end result, also the angle that your feeding the material through the binders throat will change your results . Also for your learning technique with a synchronized binder and compound feed and feed/turn rhythm . slow the machine down on the radius and make a conscience effort to only feed-turn the material, on the needles down stroke, when the needles foot is down, with the outer feet off . That KH 441 machine and binder set-up is a brute for Binding, and you maybe able to get far better results with a smaller/lighter cylinder bed or flat-bed machine and binder set-up . for me sewing.. ( example Fabric ) .. On that 441 Binder set-up . I have a couple small outside corners on a closing flap of a bag that I regularly do . that is 'smallest ' I do on that machine and binder for ( thickness ) of material when Binding around radius lid and closing flap .. Is binding threw .. 2-sides of 1" type-ll nylon binding . 1 piece of webbing . 3 pieces of 1-k denier . and 3/8" foam . I have the machine dumb down with nylon #138 . That is NOT Even Close to workload that size of machine and binder can do and handle . It's nature is big tension, thick thread cord, big needle and thick material . . working with Good quality Binding tape material is a must , but I got to take a different view of binding material than RockAussie . Not that you can not turn a nice radius with gross grain , but I find that I prefer binding with a bias and herringbone weave over the gross grain when turning tighter radius. . Using V138 bonded polyester thread, the attachments are from KH, using the 25mm one now. I bought a "bias binding folder" to make my own binding material out of 10 oz canvas, cut on the bias. I also bought cotton webbing in three different thicknesses and had luck with the thicker material, keeping the needle down when turning is a good tip! I have had to use my awl a lot to keep the material from walking away from the edge. The fabric I'm binding is a composite of 24oz canvas, thick interfacing and 10 oz canvas liner. I found sewing the edge on my flatbed machine first helps keep everything together. I have used standard straight binders in the past to good effect, but I'm just learning how to use the right angle binder and will admit the CB4500 is a beast and I may have been better off with the next size machine down, but that's what I have now and will eventually get it to work. I have used the CB4500 for top-stitching with heavy thread, v277 and it's been great for that. I"ll add a post later with photos, thanks for the tips! Quote
Members nylonRigging Posted June 15, 2022 Members Report Posted June 15, 2022 (edited) 11 hours ago, JollyDodgerCanvas said: Using V138 bonded polyester thread, the attachments are from KH, using the 25mm one now. I bought a "bias binding folder" to make my own binding material out of 10 oz canvas, cut on the bias. I also bought cotton webbing in three different thicknesses and had luck with the thicker material, keeping the needle down when turning is a good tip! I have had to use my awl a lot to keep the material from walking away from the edge. The fabric I'm binding is a composite of 24oz canvas, thick interfacing and 10 oz canvas liner. I found sewing the edge on my flatbed machine first helps keep everything together. I have used standard straight binders in the past to good effect, but I'm just learning how to use the right angle binder and will admit the CB4500 is a beast and I may have been better off with the next size machine down, but that's what I have now and will eventually get it to work. I have used the CB4500 for top-stitching with heavy thread, v277 and it's been great for that. I"ll add a post later with photos, thanks for the tips! This particular 441 KH Binder that I set-up . I only have run about 250 yard of binding threw it so far, but overall I am pretty pleased with their hardware design . Setting up Binders is always a small pain in ass and eats up many hours of your time till you get it all smooth and GTG . Every guy out there that been sewing for years has their own techniques for Binder set-up and personal built techniques for Binding. Ok lets start here . how did you set-up your binder and swing arm ? , your binder set-up is going to make or break the finished outcome. also synchronized binder is not as easy as ( for example ) a Needle-feed . Unison Feed, you need to witness the feet movement with the swing-arm, but try to get the binder head slotted-in as close as you can . here a pic of what I usually do .. trim feet to get binder head in . I found their Foot in the set-up was really not what I prefer, so just grid/trimmed and Modified a stock Foot . & Also DON'T Ask ??? why . .. but this model KH binder set-up has NO push-bar at exit of the throat . it's pretty ridiculous that they did not, as you Very Much Need tracking of the binding material exiting the throat of held firm as you feed materials against it . ..but for the Good price of the whole set-up they offer .. I DID NOT Bitch to much about the it at all....LOL So I, Drill & Tap a small piece of angle then trimmed to work with the synchronized movement . I put a Red Arrow to show the piece of material push bar . - - and this, the 1st Item tried binding on the new Binder Set-Up . - Edited June 15, 2022 by nylonRigging Quote
Members TonyGreen3455 Posted June 15, 2022 Members Report Posted June 15, 2022 gents, reading your conversation and the first and only Q coming - is it worth it? I'm trying to find a solution to bend a leather tape over the canvas or thing leather. genuine leather 0.5-1mm, not fabric tape. my inner designer and marketing director calling "Yes, we need it!" but my inner technician crying reading about all these possible troubles. designer telling - "the real leather tape only, let's keep our level up!", but the technician does not understand how to bend it and pull it out through the binder to get a pro result. KH mailing to me "90° binder is better for binding material with turns", but my common sense disagrees - "no, smaller angle better, keep it straight as possible due to leather friction" and BTW his KHF2 Raw Edge Binder can be fitted at 90° only. so, custom-made binder - the only solution? my inner bookkeeper has tensed up... advice and suggestions you could give would be much appreciated ps my machine is DA669 and I'm in UK Quote
kgg Posted June 16, 2022 Report Posted June 16, 2022 36 minutes ago, TonyGreen3455 said: my inner designer and marketing director calling "Yes, we need it!" but my inner technician crying reading about all these possible troubles. designer telling - "the real leather tape only, let's keep our level up!", but the technician does not understand how to bend it and pull it out through the binder to get a pro result. KH mailing to me "90° binder is better for binding material with turns", but my common sense disagrees - "no, smaller angle better, keep it straight as possible due to leather friction" Sounds like most of us when thinking about trying something new particularly when it could be expensive. The cheapskate in me always gets first priority until proven wrong. i) The 90 degree binders I have measured have about 1.25 mm space so accommodating .5 - 1.0mm thick material through the binder itself shouldn't give much of a problem but bending the thicker / stiffer tape 90 degrees probably will be a chore. That is where a custom binder will or should solve that problem. To mount the 90 degree binder to the machine will also require a specific type of mounting frame. The bookkeeper ain't going to be happy with a that purchase. ii) The standard inline binders I have measured have about 1.75 mm so accommodating .5 - 1.0mm thick material through the binder itself shouldn't be much of a problem. This style of binder can be gently pried to 2+mm. The bookkeeper would be happy. The downfall is you will need some sort of flatbed attachment to mount this type of binder attachment to cylinder bed machines. I have one for my LS 1341 clone. iii) Some people have difficulty with binding irregardless of the style of binder attachment or binding material they use. To get acceptable results it is more then likely it isn't going to be a simple bolt on affair. It is probably going to require a bit of practice til you are satisfied with the end result. Is there a chance you could post a photo of what you are planning on binding maybe someone can suggest a different solution. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TonyGreen3455 Posted June 16, 2022 Members Report Posted June 16, 2022 8 hours ago, kgg said: Sounds like most of us when thinking about trying something new particularly when it could be expensive. The cheapskate in me always gets first priority until proven wrong. i) The 90 degree binders I have measured have about 1.25 mm space so accommodating .5 - 1.0mm thick material through the binder itself shouldn't give much of a problem but bending the thicker / stiffer tape 90 degrees probably will be a chore. That is where a custom binder will or should solve that problem. To mount the 90 degree binder to the machine will also require a specific type of mounting frame. The bookkeeper ain't going to be happy with a that purchase. looks like all I need - to disassemble common KH binder and put some wedge between a binder body and fitting bracket. it what my inner mechanic telling me. will it help? ii) The standard inline binders I have measured have about 1.75 mm so accommodating .5 - 1.0mm thick material through the binder itself shouldn't be much of a problem. This style of binder can be gently pried to 2+mm. The bookkeeper would be happy. The downfall is you will need some sort of flatbed attachment to mount this type of binder attachment to cylinder bed machines. I have one for my LS 1341 clone. can you show it - will try to find smth similar suitable in my case iii) Some people have difficulty with binding irregardless of the style of binder attachment or binding material they use. To get acceptable results it is more then likely it isn't going to be a simple bolt on affair. It is probably going to require a bit of practice til you are satisfied with the end result. Is there a chance you could post a photo of what you are planning on binding maybe someone can suggest a different solution. sure - pls see a picture attached kgg Quote
kgg Posted June 16, 2022 Report Posted June 16, 2022 Really nice edging in your photo's. This was my solution for my KOBE LS-1341. This was done with no changes to the feed dog or presser feet. The binder was an inexpensive in line using a swing away binder bracket. This may spark your inner mechanic. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TonyGreen3455 Posted June 16, 2022 Members Report Posted June 16, 2022 1 hour ago, kgg said: Really nice edging in your photo's. This was my solution for my KOBE LS-1341. This was done with no changes to the feed dog or presser feet. The binder was an inexpensive in line using a swing away binder bracket. This may spark your inner mechanic. kgg that's it! it's wat I need to be done first - put a binder in-line many thanks for sharing, inner mechanic got a point ) Quote
