Members Klara Posted May 8, 2022 Members Report Posted May 8, 2022 A solid base will also increase efficiency. I've given up trying to set rivets on my work table, which started life as a computer desk and is just too flexible for hammering on. Btw, you can do leather work without stamping... Quote
Members StickHer Posted May 9, 2022 Author Members Report Posted May 9, 2022 my tools for stitching are the mallet and chisel Quote
Members Klara Posted May 10, 2022 Members Report Posted May 10, 2022 The awl is silent and the gentle tap for just marking the stitches shouldn't carry through walls either. Quote
Contributing Member fredk Posted May 10, 2022 Contributing Member Report Posted May 10, 2022 and these are even quieter ~ until you nip your fingers with them! Quote
Members StickHer Posted May 14, 2022 Author Members Report Posted May 14, 2022 what is that fredk Quote
Contributing Member fredk Posted May 14, 2022 Contributing Member Report Posted May 14, 2022 That is a 4-prong/tooth set of stitching hole pliers. I have these 4 prong and set with 2 prongs. You can go around a project and punch stitching holes in it very quickly and very quietly Limits to them are; you can't go any further in tan about 20mm and the hole size and distance gap is set You can also get ones with a larger prong for making lacing holes Quote
Members Rocky143 Posted July 14, 2022 Members Report Posted July 14, 2022 A good way to get a marble or granite slab is from a kitchen countertop company. They have many cut-out pieces that are waste. They would rather give it away than spend $40 per ton to dispose of it in a landfill. They will cut it to the size you want for a reasonable price. Two-inch thick is better than a thinner piece. Three-inches is probably not necessary. Broken slate pool tables are good. How to make sound deadening panels, cheap: https://www.youtube.com/watch?v=fqodnHxRJ7c&t=1654s DIY Active Noise Cancellation: https://www.youtube.com/watch?v=fqodnHxRJ7c&t=1654s At Google Shopping, search for Sound Deadening Material. Look for a high NRC (Noise Reduction Constant), the percentage of sound that is absorbed by the material. The first link above details how to make panels from 2" thick rock wool, which has a NRC of near 100%. Other material less than 1/2" thick has a NRC around 60% and multiple layers can be used. Quote
Members StickHer Posted September 3, 2022 Author Members Report Posted September 3, 2022 so i am finally using a "mallet" and a weaver Diamond chisel to punch holes all the way through. the leather im using is cheap thin scraps. but for w.e reason i feel like im putting in much more effort and swings to get the chisel all the way though. some youtube videos ive seen people giving two light/ moderate taps. https://www.amazon.com/gp/product/B01I6MZ576/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 this is the hammer im using. is it normal to need a lot of force and maybe 5-7 swings to get a 6 tooth diamond chisel all the way through. Quote
Contributing Member fredk Posted September 3, 2022 Contributing Member Report Posted September 3, 2022 No, its not normal. Unless you are trying to go through very thick leather Have you sharpened and polished the chisel teeth? Quote
Members StickHer Posted September 3, 2022 Author Members Report Posted September 3, 2022 no i have not polished or sharped, this is the first time using them since purchase. am i supposed to sharpen new diamond chisel out of the box? Quote
CFM tsunkasapa Posted September 3, 2022 CFM Report Posted September 3, 2022 And what surface are you using it on? Quote
Members StickHer Posted September 3, 2022 Author Members Report Posted September 3, 2022 plastic cutting board from ikea which is on top of hard kitchen counter top not sure what material the kitchen top is but like a granit Quote
CFM tsunkasapa Posted September 3, 2022 CFM Report Posted September 3, 2022 On 9/3/2022 at 9:24 PM, StickHer said: plastic cutting board from ikea which is on top of hard kitchen counter top not sure what material the kitchen top is but like a granit Expand Then I can think of no reason that you would have to pound it as you described. Unless the tool is THAT dull. Quote
Members StickHer Posted September 3, 2022 Author Members Report Posted September 3, 2022 i dont have the tools to sharpen it atm, idk if weaver sends out dull chisels. any recommendations on sharpening sets/tools Quote
CFM tsunkasapa Posted September 4, 2022 CFM Report Posted September 4, 2022 600/800 wet or dry sandpaper wrapped around a popsicle stick. Might go as fine as 1200. Crocus cloth will give it a nice polish. Quote
Contributing Member fredk Posted September 4, 2022 Contributing Member Report Posted September 4, 2022 On 9/3/2022 at 11:28 PM, StickHer said: i dont have the tools to sharpen it atm, idk if weaver sends out dull chisels. any recommendations on sharpening sets/tools Expand We don't know your location so we don't know what terminology you'll understand best. But I think you may be in UK or Europe? Get some different grades of 'wet & dry' abrasive paper, available from a car accessory/parts shop, eg Halfords, costs about 60p/£1 per sheet. Get 320, 600, 800, 1200 Glue strips of these to lolly sticks (available The Works for about £1 per packet) use these on the bevels of the chisel teeth/prongs, working from 320 to 1200. But also do all four of the sides of the teeth/prongs. Spend time doing this. A couple of hours or less, not just a minute or two You should be able to get the chisels really sharp, sharp enough that with a very light pressure they will cut slots into a sheet of writhing paper and, a personal thing to me; I don't like that sort of mallet. I gave mine away. I prefer a similar one but it has an 'ordinary' shape with flat round faces. Like this one; https://www.amazon.com/Leather-Carving-Hammer-Leathercraft-Cowhide/dp/B07H8BH9JR/ref=pd_rhf_d_dp_s_pd_sbs_rvi_sccl_2_13/143-2905049-6470749?pd_rd_w=VK8cg&content-id=amzn1.sym.a089f039-4dde-401a-9041-8b534ae99e65&pf_rd_p=a089f039-4dde-401a-9041-8b534ae99e65&pf_rd_r=ZGVW9JPVPPPCMSQJG7YJ&pd_rd_wg=Vg0YA&pd_rd_r=c2c5f3fb-02a8-4177-8940-f75a10c8369e&pd_rd_i=B07H8BH9JR&psc=1 I find I can give a better whack with it than the other Quote
Members StickHer Posted September 4, 2022 Author Members Report Posted September 4, 2022 thank you for the responses. will go to harbor freight to pick up sand paper and potentially a crocus cloth. should i also invest in some sort of creams , gels, oils, wax, etc ? Quote
Members AlamoJoe2002 Posted September 4, 2022 Members Report Posted September 4, 2022 (edited) StickHer, I like to use a Stanley or box cutter knife with premium blades. I strop the blade often on a strop made from a wooden paint can stir stick. Always strop the blade and you won't have to change it often. I use the Harbor Freight Green Compound stick on my strop....it's good and inexpensive at HF. Also, pick up a poly hammer with the screw in heads at HF. Good tools to start with. Oh, don't buy sand paper from HF. It is pure junk. Get good 3M sandpaper. -JOE Edited September 4, 2022 by AlamoJoe2002 Harbor Freight Sand Paper Sucks Quote
CFM tsunkasapa Posted September 4, 2022 CFM Report Posted September 4, 2022 On 9/4/2022 at 1:11 PM, AlamoJoe2002 said: Oh, don't buy sand paper from HF. It is pure junk. Get good 3M sandpaper. Expand HF is great for a lot of things, but their sandpaper is garbage. Quote
