I am curious to see what sort of techniques and tools you would use to make folded leather straps such as used on a handbag?
I once got a bunch of "strap folder" for double needle machines from a closed leather business. Most are gone (sold too cheap) and I only have 2 left. Never used them but you never know. They are single folds so I do not know what kind of strap they used it for. I´m sure there are other strap folders out there that produce clean edges (triple fold?). Maybe clean edge binder attachment can do the work but of course depends on the leather you want to use.
Edited by Constabulary
With thin leather straps i was taught to cut four times the width required plus 6 times the thickness, fold into the centre and then fold both sides together and sew
Thanks @Constabulary. They look nice but it would seem you would end up with an exposed edge on one side of the strap with them ones, which is hard to imagine what that would be useful for. I have been working on some folding pieces that fold into the middle but I would like to see if anyone has any special tools or methods for that process already.
Sounds better than above except that one side would be one big fat fold and the other more of a joined look. I expect that the technique would be quite time consuming unless there are any tools that can do such a fold?
Hi Brian, Here is a setup which might work for the leather without the webbing??? might give you some ideas, it looks quite neat with the two folded edges together in the end??? The only other thing i can think of is the typical motor, roller on table and folder setup which i am sure you have googled a million times Lol...
And if you want to try your hand at a folder.....C´est si bon..Lol.
Edited by jimi
WOW!!!! thanks @jimi that double needle juki set up is awesome but it would be great to see it doing some leather. Might be a little expensive though.
The second vid is also showing a master of metalcraft in action and I can not help but admire his skills. Again it would have been good to see it folding some leather.
I have been for some time printing some folders for my little folder rolling machine but I am starting to experiment with a design that does not need the rolling machine for those that want to do it by hand. (cheap, simple and efficient)
Mostly I just want to see what other type of things people use to accomplish the job.
Seamstresses have been using bias binding for many years before sewing machines came along. They line the raw edge up with the centre of the tape, sew one side of the tape, turn it over and sew the other. Sometimes pressing so starch holds it together.
And fold cased (better than dripping wet)when possible
Edited by oltoot
evolved
Thanks for the input @Rahere. That sound like what we would called a French edge this side of the pond. Not quite what I am talking about but this Video shows a good example I think -
Unfortunately this is a bit outside of a lot of peoples price range. I would love to have one though.
These are some of the guides I have made for my little folder below (they work very well and cost very little to produce)
The guides at the back in this picture are made for my roller machine and the squarer shaped ones at the front are the new ones I am working on that don't need a roller machine.
This shows some of the strap work on the handles and as well the leather strapping used with the patchwork.
I will try and get a video done up showing them in use in the next few days.
No, a French binding halves the binding material then buries the raw edges against the raw edge being covered, leaving four layers on the wrong side after it's wrapped. If you take the same centre crease in the binding, and fold the edges in to meet that, then wrap the raw edge, so you get only two layers of binding either side of the material being bound, it's thinner and neater sewing, because only one layer covers the edge.
I have the OMAC Star3000. It’s a good machine, however it’s folding options are limited unless you get them to make a special folder for you.   I was quoted about $300 fir a custom made folder.
14 hours ago, sbrownn said:
The dies look 3D printed, were they?
Yes they are and they work great once you get all of the design specs worked out. Video's coming soon.
I am working on a range for the Cowboy strap cutter and folder combo machine at the moment and hope to get a few vids done shortly. The basic design is pretty easy to adapt to any machine and if you want to give me the width of strap and the thickness once folded I could make you them up for about $25 US dollars plus post (about $15 dollars to the states I think). Should be able to do quite a few sizes for the same postage cost. I would need the diameter of the rollers and the distance from the centre of the rollers to where you screw the folder plate down and the spacing between screws. Give me a week to get these video's done and I think you will be quite impressed.
Edited by RockyAussie
You should just print and sell the dies.  I would imagine it took some trial and error to get the folding geometry worked out?
I am working towards that but I am way quicker at designing stuff like this than I am at doing up video's to show case them unfortunately. :wub:
This is the equivalent in cloth, if it helps: it shows how to make the binder material and then apply it.
In the case of a handle, you may use a rope filler in place of the cloth being bound. There's also a video out there somewhere showing how to skive the ends down to form an opened-out sewing tab.
Thanks for the info on that @Rahere .that folding devise looks pretty good in action. Not video's yet but here are a couple pics showing some strap folding with my folding tools.
There's another technique not shown, butt-joining fabric strips. If you do something like that in leather, you'll probably skive the edge to a feather along the line of the join, so you can fold and glue it back after sewing, maybe even stitching again on either side of the join to hold everything flat. It's still wise to join on the diagonal though as it spreads the weakness along the strap.
The issue of fabric thickness also happens in your jig, bringing the edges completely together in the centre doesn't allow for the thickness of the leather or any core when you fold it in half again. The middle has to stretch across two buried thicknesses within, so the edges should be that much apart, maybe more if using a core.
Edited by Rahere
There are some nice looking double belt folders at College sewing at reasonable price and quite adjustable  https://www.college-sewing.co.uk/folders-attachments/suisei-folders-attachments/suisei-straight-folders/suisei-belt-loop-folders.html
Edited by chrisash
That is true if you wanted to do a fold it over in 1/2 again. It is quite easy to run them through and get an allowance to do that by having the strap cut less wide but in this case I have concentrated on bringing them together to meet as tight as possible in order to use as a strap as is if wanted and also I prefer to use 2 separate straps put together if I want more thickness. I think they look better that way and in many cases I am putting a top over skin as shown in the crocodile bag handles above. The main aim here is to do the job quickly, neatly and easily as possible. These straps take me a few minutes to make and I can show you many a video of makers/teachers? showing had to make these straps in time frames I could never recommend. I give credit to the person in this video for a lot of things that he shows and shares in his video's but the methods shown in this one just can't work for me.
