Thanks people, after reading the specs of EDM i've been tweaking the gears and measuring my good gear over and over to make sure I give it my best shot.
I am also getting them to cut the bottom plate so I can put all the parts together.
Here is what is going to the EDM, on paper no interference issues.....we will see.
If and when I get this "right" I can then provide STL and DXF so people can get these parts made locally, though the tollerances are so tight I am also looking to make these myself to keep the quality and fit right, time will tell on this. I would love to do this the old fashioned way with dividing head and hobber but I don't have a lathe or enough knowledge of hobber design to get it right,,,yet!
https://1drv.ms/v/s!Arc9igKuarE5gSUtRwX55Ou3oxz-
The other research on parts still available is hopefully going to bear fruit. I have the following parts ordered from Ital and Spain.
8608 New pinion gear, I don't yet know if these are in short supply and therefore NOS "new old stock"
8600 New Rack for 29k1 but same rack profile as 29k15 range so can be cut and extended for use on 29k15 or as it on K1
8599 New Small rack used on K1 but could be a donor to be grafted to long rod for k15
So judging what these parts are like quality etc it will offer two routes to getting gears for these values and treasured machines where initially there was none.
I would also like to make an adjustable rack rod so fine tuning of shuttle movement can be achieved like the later machines.
One of the main drivers for me to do this is when I contacted the singer archives I was informed that most if not all of the singer designs and drawings were destroyed in the 80s when the factory was demolished, thats 150 years worth of engineering expertise translated to complex designs and drawings, to reverse engineer like I am doing you really appreciate what they achieved 100 years ago.
If these parts are preserved in computer formats that people can use to replace these parts then these machines could go on for another 100 years.
Edited by 29k15engine
  • Replies 79
  • Created
  • Last Reply
Top Posters In This Topic
Ok bit of an update, still waiting for my friend to cut the gears out of metal.
Meanwhile I have just recieved new follower pinion gears from spain, part no 8608 and found they are so close to what they should be but do not fit.
I will post an image of the gears, it seems that the teeth are too thick by around 0.38mm plus the root of the gear is not deep enough by 0.38mm
Ok so I got my new part 8606 following pinion which is used on the 29K1 machines in a 2 cog configuration with a long and a small rack as shown below and also on the 29k15 machines as a 3 cog one long rack configuration show below.
So as you know I have been modelling the cogs and rack for the 29K15. I have found a supplier of the cog which I have recieved today.
Unfortunately the cogs do not mesh with the 29k15 3 gear setup, this is due to a couple of dimensions being different, I am wondering if on the 2 cog design the tollerances of the pinion did not need to be as accurate as it is just picking up on 2 racks and not 3 cogs and rack.
Below is an image of the 8606 cogs recieved. One looks slightly different on the tooth from the other.
When measured against my good original gears that fit like a glove I find the dimensions below different.
The tooth is thicker 2.51mm not 2.16mm each tooth is 0.25mm thicker
and the root of the gear is not as deep 9.10mm not 8.48mm difference of 0.31mm shallower root to the gear
If I place the two new gears onto the lower plate of the gearbox the gears do not allow the gears to turn as there is no room for them to move.
So I am hopefull that the cogs being made by my friend on an EDM  machine will be better fitting than these.
I am now working with the theory that the 29k1 machines did use follower gear 8608
then when the 29k12 came along they used 8608 but with tighter dimensions, looking at lots of gears now
even unused ones the K1 gears look thicker in the teeth, I do not put this down to wear as my gears are very very good but there is no way a fatter toothed gear would fit when meshed with the adjoining fatter gear.
Therefore Im going to press on with my 29k15 (im encompassing all the revisions from k12 to k15 and k20) gear modelling and cutting research.
I dont know if this YT video would assist you
Mi omputer is ot ood at speeling , it's not me
great Job 29K15engine!   I have been playing with these gears and rack over the last couple of years.  SItamaco in Spain has the 29K1parts made in China I believe.  They are new.  The drive gears, short rack, following gears, shuttle carrier and set screws are all needed today for 29-4, 29K1-33, 29K51-56machines.  Other than Sitomaco, no one is making them.  thee is a big need for these parts.  Singer made over 250,000 29-4 machines!
Gear #8608 was used in 29K1-4,10-18,21-23, 32, 33. right of of original singer parts book.  I know no one is making gears for the 51-56.
glenn
Ok some progress
Hi jimi,
Bit of an update.
My new rack, parts number 8600 arrived today from italy, good news it is exactly the same as the 81899 rack used on the 29k12 29k15 etc , the only operating difference is it has one more tooth than the 81899. I cut this off and shaped the end, i also filed very slightly the back of the rack not very much at all, the hole needed 5mins of emery paper but after that the fit and quality is excellent.
One of the things i wanted to do was get the shuttle timing perfect, i wanted to add an adjuster but as i bought 2 i cut one in half and added 1.6mm to the length, this meant that the shuttle pickup is exectle where it should be, it now stitched reliable and very very .
Hey Mat, you can make some leather jackets again now! :thumbsup:
