Aart Posted July 1, 2021 Report Posted July 1, 2021 Hell there, My old mare has a now recurring problem inside her front leg hoof (2nd abscess in 3 month time) With the vet we opened the sole and away went the pain. Medication for several days and a new dressing each afternoon before going out into the paddock at night. It is rather warm here in Southern France now ;-) Next morning when she comes in the bandage is still there but the bandaged 'sole' is gone and there is grit in the pit, which is far from ideal. Question is, as I'm a kind of a leather smith, is there someone around who has made a kind of protecting 'boot' from a sturdy piece of leather. Sturdy enough to keep in place for some time. If not I'll have to ask my farrier for help. Any help or ideas greatly appreciated. Best Aart. Quote
Members Rahere Posted July 1, 2021 Members Report Posted July 1, 2021 Ask your farrier. He should be cutting a drainage channel so any gunk getting in there will drain. However, you have to be certain you've got it all or it will be back. You will find rubber covers on the market, rather than start kludging yourself, which may even be illegal. He may even tell you to keep her stabled for the 4-6 days needed for the open wound to come together, with a week more for a full heal. Quote
Members Hasbeencowboy Posted July 1, 2021 Members Report Posted July 1, 2021 Back in mu younger days when I was cowboying, I had a horse get a stone bruise that abcessed. I took a piece of harness leather and cut a piece the size of the hoof and nailed a shoe on over the leather (after packing the foot). Do the same for the opposite foot. It worked OK for me and horse healed up pretty quick. I also tried using vet wrap to hold the leather in place but it cost more for vet wrap then the horse was worth........lol Maybe one of these home remedies will get you out of the woods Quote
Aart Posted July 2, 2021 Author Report Posted July 2, 2021 Thank you gentlemen, Called my farrier for an appointment Have a good weekend Best Aart. Quote
Members Klara Posted July 2, 2021 Members Report Posted July 2, 2021 By all means, ask the farrier what he thinks, but my quick and dirty attempt at a solution would be something like the hipposandals used by the Romans, but made from leather. If you have very thick scraps lying around... And I'd bandage first, to eliminate the risk of the leather straps used for tying the soles cutting into the skin. Making a proper boot - they are available - would probably take too much time, as you need something immediately. Quote
Members Sheilajeanne Posted July 2, 2021 Members Report Posted July 2, 2021 Farrier found an abscess developing on my horse's sole when shoeing her. He cleaned it out, packed it and put a piece of leather over the sole of her hoof, held in place by the shoe. Unless you get one of those fancy hoof coverings, like Easy Boots (TM) there's no way other way of keeping dirt out of the wound while it heals. They aren't cheap, and tend to fall off and get lost much more easily than a horseshoe. So, suggest you get her shod for now. Quote
Members Rahere Posted July 2, 2021 Members Report Posted July 2, 2021 On 7/2/2021 at 7:21 AM, Klara said: By all means, ask the farrier what he thinks, but my quick and dirty attempt at a solution would be something like the hipposandals used by the Romans, but made from leather. If you have very thick scraps lying around... And I'd bandage first, to eliminate the risk of the leather straps used for tying the soles cutting into the skin. Making a proper boot - they are available - would probably take too much time, as you need something immediately. Expand You can get them over the counter in rubber these days. Don't forget he's in the south of France, valley country, but it can get dry in the summer. Quote
CFM tsunkasapa Posted July 2, 2021 CFM Report Posted July 2, 2021 When our sled dogs cut cuts/etc on their pads, we put a "patch" over it held on with superglue. It stays in place for several days and keeps the wound clean. Superglue was developed for surgical purposes. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Members Rahere Posted July 2, 2021 Members Report Posted July 2, 2021 On 7/2/2021 at 2:51 PM, tsunkasapa said: When our sled dogs cut cuts/etc on their pads, we put a "patch" over it held on with superglue. It stays in place for several days and keeps the wound clean. Superglue was developed for surgical purposes. Expand There's a serious difference in size. A hoof's dead keratin nail, but live flesh is putting consuderable weight on it. That can cause what we'd call blisters, but are rather worse. The farrier'll have made a hole an inch across minimum, and deep with it: its not a flesh pad. He may decide to fill it with resin in a couple of weeks time, but right now he'll bekeeping an eye on the heal. He'd likely have wanted to have a look about now anyway. Quote
Members jcuk Posted July 2, 2021 Members Report Posted July 2, 2021 (edited) I am taking that you are past the stage of hot tubbing and Animalintex and you are just wrapping for protection, what we do here is soak some gamgee in a iodine based solution pack the cut away area with it this will also help harden the foot off, cut another piece of gamgee to fit your horses foot wrap with a comforming bandage and then vet wrap after that wrap the the sole of the foot using some Gaffer tape double up on it if you need to. Yes Vet wrap is expensive stuff but anything for the treatment of horses is, also you will have to change daily for awhile but at least you will be keeping an eye on the problem and flushing the foot clean with salted water (Epsom Salt if you have it) and letting the sole of the foot get some air to it. I have seen Farriers put pads under the shoe on some horses feet in some cases they have been know hide a lot of other problems if your Farrier or Vet are not around to monitor this, here in the UK only a Farrier and a Vet can shoe a horse and i have been around horses for a long and i am yet to see a Vet do this, yes you can take a shoe off if it is sprung, loose or moved but you cant put it back on it, illegal here. We have a saying no foot no horse. Hope this helps JCUK Edited July 2, 2021 by jcuk Quote
Members Rahere Posted July 2, 2021 Members Report Posted July 2, 2021 On 7/2/2021 at 6:05 PM, jcuk said: I am taking that you are past the stage of hot tubbing and Animalintex and you are just wrapping for protection, what we do here is soak some gamgee in a iodine based solution pack the cut away area with it cut another piece of gamgee to fit your horses foot wrap with a comforming bandage and then vet wrap after that wrap the the sole of the foot using some Gaffer tape double up on it if you need to. Yes Vet wrap is expensive stuff but anything for the treatment of horses is, also you will have to change daily for awhile but at least you will be keeping an eye on the problem and flushing the foot clean with salted water (Epsom Salt if you have it) and letting the sole of the foot get some air to it. I have seen Farriers put pads under the shoe on some horses feet in some cases they have been know hide a lot of other problems if your Farrier or Vet are not around to monitor this, here in the UK only a Farrier and a Vet can shoe a horse and i have been around horses for a long and i am yet to see a Vet do this, yes you can take a shoe off if it is sprung, loose or moved but you cant put it back on it, illegal here. Hope this helps JCUK Expand I'm pretty sure that's residual European legislation, but not 100% sure. Last year, you couldn't even buy new horseshoes here, for precisely that reason - the Appleby crew did it all the time, without checking up on other symptoms. I'm about half a mile south of Charlotte Dujardin's stable, so we're not quite as bad as Newbury or Newmarket (US: Kentucky) but not far off. In any case, as a first-aider I made a practice of checking on more serious injuries after four days, you can see if infection's happening or it the matrix has settled. Quote
Members Klara Posted July 2, 2021 Members Report Posted July 2, 2021 On 7/2/2021 at 6:16 PM, Rahere said: I'm pretty sure that's residual European legislation, but not 100% sure. Last year, you couldn't even buy new horseshoes here, for precisely that reason - the Appleby crew did it all the time, without checking up on other symptoms. I'm about half a mile south of Charlotte Dujardin's stable, so we're not quite as bad as Newbury or Newmarket (US: Kentucky) but not far off. In any case, as a first-aider I made a practice of checking on more serious injuries after four days, you can see if infection's happening or it the matrix has settled. Expand Pretty sure that's got nothing to do with the EU, because I used to nail my horses thrown shoes back on all the time in Germany and here in France I could buy horse shoes in the feed store if I needed them (my horse is retired and barefoot). Quote
Members jcuk Posted July 2, 2021 Members Report Posted July 2, 2021 Its why Farriers here still have to do a 5 year apprenticeship and i think it is only illegal in the UK. I have worked worked in a few different countries and have seen people shoeing horses that i think have only had some very basic training, horrible at times. I have worked in France Chantilly the most beautiful race track in the world for me. Any fresh wound needs to be monitored at regular intervals covering it up can cause more problems at times. Quote
CFM tsunkasapa Posted July 2, 2021 CFM Report Posted July 2, 2021 (edited) On 7/2/2021 at 6:16 PM, Rahere said: I'm pretty sure that's residual European legislation, but not 100% sure. Last year, you couldn't even buy new horseshoes here, for precisely that reason - the Appleby crew did it all the time, without checking up on other symptoms. I'm about half a mile south of Charlotte Dujardin's stable, so we're not quite as bad as Newbury or Newmarket (US: Kentucky) but not far off. In any case, as a first-aider I made a practice of checking on more serious injuries after four days, you can see if infection's happening or it the matrix has settled. Expand I'm pretty sure that you THINK you are a master of all things. But you AIN'T. You seem to have a comment on EVERYTHING. You aren't all that and I'm quite frankly tired of your EXPERT opinion on EVERYTHING. Your ass is MUTED!!!!!! Edited July 2, 2021 by tsunkasapa Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Members Handstitched Posted July 4, 2021 Members Report Posted July 4, 2021 G'Day, I think my only contribution here is that I have made boots for a miniature horse . Not sure if this is of any help, but I used a heavy leather on the sole , with a piece of rubber matting with a tread , cut to size, glued to the leather sole for grip, with extra leather that sort of went high enough to cover the fetlock , using velcro strips long enough to do them up by wrapping right around, and tight enough not to fall off. They did work, according to the client. Just wondering if something like that ( on a larger scale) could work here? But then again,there'll be commercially made products that do the same thing. Just a thought Hope your horse gets better. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
