CFM Hardrada Posted July 4, 2021 CFM Report Posted July 4, 2021 Are you gluing the pieces together before tracing the line and stitching? Quote
Members Rahere Posted July 4, 2021 Members Report Posted July 4, 2021 17 minutes ago, Hardrada said: Are you gluing the pieces together before tracing the line and stitching? I don't recall anyone taking a wider sewing allowance to glue in, then sew, and cut the SA away. That way you get the best of both worlds. Quote
Members AzShooter Posted July 4, 2021 Author Members Report Posted July 4, 2021 58 minutes ago, Hardrada said: Are you gluing the pieces together before tracing the line and stitching? Yes, after everything is glued I draw the line and then stitch. I may be wrong but I like glue instead of double sided tape. I don't think the tape holds down the edges as well. Quote
Members mike02130 Posted July 5, 2021 Members Report Posted July 5, 2021 (edited) 3 hours ago, AzShooter said: Yes, after everything is glued I draw the line and then stitch. I may be wrong but I like glue instead of double sided tape. I don't think the tape holds down the edges as well. The tape will gum-up the needles. Glue is better. Do you have any lining to keep the cards in place in those tranche (slit) pockets? Edited July 5, 2021 by mike02130 added info Quote @mike02130 Instagram
Members AzShooter Posted July 5, 2021 Author Members Report Posted July 5, 2021 (edited) 2 hours ago, mike02130 said: The tape will gum-up the needles. Glue is better. Do you have any lining to keep the cards in place in those tranche (slit) pockets? I put a lining on the back and front plus the card slots all have Tyvex to keep the cards centered. The wallets also have RFID to protect them from electronic scanning. Edited July 5, 2021 by AzShooter Quote
Members Jholden0 Posted July 5, 2021 Members Report Posted July 5, 2021 It looks like you may be starting out with leather pieces that are uneven.to begin with. Try using a square to cut. Use a very sharp box knife or razor of some sort. Leave a trim allowance. Then mark your lines with a wing divider of some type. Quote
Members jcuk Posted July 5, 2021 Members Report Posted July 5, 2021 This maybe of help. https://www.youtube.com/watch?v=haQSsoYZ3_I Hope this helps JCUK Quote
Members AzShooter Posted July 5, 2021 Author Members Report Posted July 5, 2021 Thanks again. All of this is helping me. I appreciate it. Quote
