Members mrwatch Posted August 9, 2021 Members Report Posted August 9, 2021 I put A broken 1/16th drill bit in a drill and held to my one inch belt sander. The golf ball is drill out with a nut pressed into it for a file handle as seen on YouTube. The hex was a tad big so revered it in the drill and a slight sanding then put into a bench vise and tapped the ball on. Some file handles don't stay on well but it does okay. I will try it out. Bob Quote
Northmount Posted August 11, 2021 Report Posted August 11, 2021 @mrwatch A picture or two would help so we can see what you are trying to describe. Quote
Members Tugadude Posted August 11, 2021 Members Report Posted August 11, 2021 I'm assuming it is an awl that uses a golf ball as a haft. But...pics or it didn't happen. Quote
Members mrwatch Posted August 11, 2021 Author Members Report Posted August 11, 2021 Sorry I'm rather sure they did post. I selected nuts for the with of several file tangs. Drilled near the size of the nut then used the drill press chuck to press the nut into the ball. Quote
Members mrwatch Posted August 11, 2021 Author Members Report Posted August 11, 2021 1 minute ago, mrwatch said: Sorry I'm rather sure they did post. I selected nuts for the with of several file tangs. Drilled near the size of the nut then used the drill press chuck to press the nut into the ball. Don't show again. Image way to large. Quote
Northmount Posted August 11, 2021 Report Posted August 11, 2021 Thanks for adding the photos. You can use various apps or software to reduce the size of your photos. 800x600 or 1024x768 pixels is adequate size for most details to be seen. Smaller files are also great for people on the fringes of the internet that take a long time for larger files to download. Some helps are located in this thread. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 Quote
Members Klara Posted August 11, 2021 Members Report Posted August 11, 2021 Isn't a golf ball much too large for an awl haft? Regarding picture size, I can reduce it in my tablet's viewing app (Samsung A8) Quote
Members mrwatch Posted August 12, 2021 Author Members Report Posted August 12, 2021 14 hours ago, Klara said: Isn't a golf ball much too large for an awl haft? Regarding picture size, I can reduce it in my tablet's viewing app (Samsung A8) I will find out as I mostly resew old hunting knife sheaths and may need to open a stitch hole to pass a needle thru. Or I would have to make a wood handle for it. For a larger men's hand it should be okay. Quote
Members Tugadude Posted August 12, 2021 Members Report Posted August 12, 2021 It also depends on the size of your hand. Maybe the golf ball will feel "just right". No other way to determine it but to try. Quote
