I see nothing negative with having a taller work bench, you can just raise your chair. And also at least I tend to stand up sometimes when I do some cuts and such.
For me it did make sense to use the same height as my cabinet from Ikea (So it's 70cm in height) but if I would build a frame I think I would make it a little taller.
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
My only consideration would be - can I get my head over the top of the work without getting a bad back? My worktop sits atop  a singer table and luckily works out ok.
As for cracking; If you can work out where you'll do the most bashing, make sure there's a solid leg under it rather than having to move your work to get over an existing leg
The bench is coming along...I have covered the top with 3/4" plywood.
Getting ready to put the granite slab down, I
On 9/15/2021 at 1:47 PM, MikeRock said:
 More insurance can be had by using a strip or two of roofing felt under the marble.  We used that on some 'heavy duty' lab tables and it both evened out the support and quieted things down a bit.   I know, that makes a thick top....but I like it.
Thanks for all the ideas...MIkerock I'm taking your idea into consideration. Good idea!
Does anyone have any other ideas for sound dampening? I was thinking maybe the rubber shelf lining material for cabinets?
Thanks everyone!
Here's a progress photo
  • 2 weeks later...
I still use the foam that came from my original Tandy starter kit!   I also placed some of this tough rubber mat stuff I purchased from Tractor Supply.  It resembles the rubber mat many out door stuff playgrounds have, today.
