Members epiphanist1248 Posted November 13, 2021 Members Report Posted November 13, 2021 Hi folks! Does anybody know where to find hardware for making gags, like ball gags, ring gags, spiders, etc.? Ohio Travel Bag has a few silicone balls and a pony bit but I'm trying to find a wider selection. TIA! Quote
CFM Frodo Posted November 13, 2021 CFM Report Posted November 13, 2021 Wouldn't a nerf ball work? Or those squeeze balls used to strengthen your grip? Now the spider gag. that is way over my paygrade. I do not even know what it is. Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member Samalan Posted November 13, 2021 Contributing Member Report Posted November 13, 2021 On 11/13/2021 at 6:23 PM, Frodo said: Now the spider gag. that is way over my paygrade. I do not even know what it is Expand that spider thing sounds a bitt strange . Quote
Members Matt S Posted November 14, 2021 Members Report Posted November 14, 2021 A lot of these more specialised sorts of hardware are often custom-made for manufacturers in small batches, to their spec. Same as high-end handbag manufacturers, or people who use special widgets for making their pistol holsters. You're probably not going to find what you need off the shelf unfortunately. Making ones and twos is tricky, cos you'll be working with stainless which is a bit of a pig in the home workshop. Quote
CFM Frodo Posted November 14, 2021 CFM Report Posted November 14, 2021 On 11/14/2021 at 6:00 PM, Matt S said: A lot of these more specialised sorts of hardware are often custom-made for manufacturers in small batches, to their spec. Same as high-end handbag manufacturers, or people who use special widgets for making their pistol holsters. You're probably not going to find what you need off the shelf unfortunately. Making ones and twos is tricky, cos you'll be working with stainless which is a bit of a pig in the home workshop. Expand Being that I work with stainless and copper. I ill let you guys in on a little secret. I have head it said time after time that you can not solder stainless steel To this I laugh. OH CONTRAIRE MONFRAIRE The secret is the flux . With this flux and the advice that you not heat your work directly but heat a couple inch's away. you can solder stainless, you can solder copper to stainless, Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM chuck123wapati Posted November 20, 2021 CFM Report Posted November 20, 2021 give Hunter a call. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members epiphanist1248 Posted December 1, 2021 Author Members Report Posted December 1, 2021 On 11/20/2021 at 4:05 PM, chuck123wapati said: give Hunter a call. Expand @chuck123wapati I don't know what that means? Quote
Members AussieNikkie Posted June 6, 2022 Members Report Posted June 6, 2022 Your looking for dental or medical gags, the rest of the hardware you can get from hardware stores, AliExpress and plumbing shops Quote
Members Snowdo Posted January 18, 2024 Members Report Posted January 18, 2024 (edited) You could try websites like Lovehoney, Stockroom, and Extreme Restraints. They usually have a variety of gags and other BDSM gear. Check out the phim sex việt nam website for more info. Edited January 18, 2024 by Snowdo Quote
