Members ThoughtFission Posted January 14, 2022 Members Report Posted January 14, 2022 I know there isn't one answer to this question but I would really appreciate some advice. I need a starting point. What size thread would companies like Hermes, Channel etc generally use for their handbags (purses). I'm about to purchase some thread and before I make that investment, I need some advice. Thanks!! Quote
MtlBiker Posted January 14, 2022 Report Posted January 14, 2022 36 minutes ago, ThoughtFission said: I know there isn't one answer to this question but I would really appreciate some advice. I need a starting point. What size thread would companies like Hermes, Channel etc generally use for their handbags (purses). I'm about to purchase some thread and before I make that investment, I need some advice. Thanks!! I think that before anyone can suggest a thread weight to you, they'd need to know what you're sewing. I know you said handbags, but the type of material you use, as well as the thickness (not to mention how many layers) all are a factor. Also the machine you have might be a limiting factor as well. Thread choice could also be affected by aesthetic concerns... do you want the thread/stitching to be an attractive visual or more unobtrusive. I doubt there's a right answer to your question without knowing a lot more. Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
MtlBiker Posted January 14, 2022 Report Posted January 14, 2022 Oh, one more thing... You say you want a starting point for thread weight before you "make that investment"... I would suggest that thread cost is minuscule in the overall scheme of things for your projects. The machine, the fabric/leather, needles and other accessories certainly are a bigger investment than a few spools of thread. I use everything from heavy duty thread (consumer thread) on my home machine, to v69, v92 and v138 threads on my other machines. Then my choice of which thread to use is based on the material I'm sewing, the strength required and the look I'm after. Maybe you should start with a bunch of different weights and experiment to see which you like better with your material and machine. Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Members DrmCa Posted January 14, 2022 Members Report Posted January 14, 2022 OP: Are you asking what size holds up over the typical lifespan of a bag/purse or what size looks good? 69 is sufficient for most purses. 92 is sufficient for larger bags. But if you want decorative look then you can go up several notches to 277 or 346 or above. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members chrisash Posted January 14, 2022 Members Report Posted January 14, 2022 69 is a good general all rounder for ladies handbags but 92 for heavy veg tan versions Quote Mi omputer is ot ood at speeling , it's not me
Members ThoughtFission Posted January 15, 2022 Author Members Report Posted January 15, 2022 (edited) 19 hours ago, MtlBiker said: I think that before anyone can suggest a thread weight to you, they'd need to know what you're sewing. I know you said handbags, but the type of material you use, as well as the thickness (not to mention how many layers) all are a factor. Also the machine you have might be a limiting factor as well. Thread choice could also be affected by aesthetic concerns... do you want the thread/stitching to be an attractive visual or more unobtrusive. I doubt there's a right answer to your question without knowing a lot more. Fair point. Here's a few examples of the type of thing I want to achieve. https://www.hermes.com/us/en/story/106191-birkin/ https://www.sothebys.com/en/buy/handbags/_hermes-Gold-Epsom-Constance-To-Go-Wallet-Gold-Hardware-2021 https://www.saksfifthavenue.com/product/tory-burch-ella-nylon-tote-0400013631916.html?dwvar_0400013631916_color=OCEAN SIDE Edited January 15, 2022 by ThoughtFission Typo Quote
Members ThoughtFission Posted January 15, 2022 Author Members Report Posted January 15, 2022 17 hours ago, MtlBiker said: Oh, one more thing... You say you want a starting point for thread weight before you "make that investment"... I would suggest that thread cost is minuscule in the overall scheme of things for your projects. The machine, the fabric/leather, needles and other accessories certainly are a bigger investment than a few spools of thread. I use everything from heavy duty thread (consumer thread) on my home machine, to v69, v92 and v138 threads on my other machines. Then my choice of which thread to use is based on the material I'm sewing, the strength required and the look I'm after. Maybe you should start with a bunch of different weights and experiment to see which you like better with your material and machine. A valid point. I've already made the investment in all of those things (except the leather,but I live in Hermes country in France so it's actually quite reasonable). Thread, however, is really quite expensive for the good stuff. Quote
Members ThoughtFission Posted January 15, 2022 Author Members Report Posted January 15, 2022 15 hours ago, DrmCa said: OP: Are you asking what size holds up over the typical lifespan of a bag/purse or what size looks good? 69 is sufficient for most purses. 92 is sufficient for larger bags. But if you want decorative look then you can go up several notches to 277 or 346 or above. The latter, what size looks good. Is the 69 you're referring to TEX or Ticket Number or something else altogether? I'm absolutely lost when it comes to thread sizes. 15 hours ago, chrisash said: 69 is a good general all rounder for ladies handbags but 92 for heavy veg tan versions Thanks! Quote
Members ThoughtFission Posted January 15, 2022 Author Members Report Posted January 15, 2022 1 hour ago, ThoughtFission said: The latter, what size looks good. Is the 69 you're referring to TEX or Ticket Number or something else altogether? I'm absolutely lost when it comes to thread sizes. Thanks! I think this is what you meant by 69, correct? Size 69 / Tex 70 / Govt. E Quote
kgg Posted January 15, 2022 Report Posted January 15, 2022 31 minutes ago, ThoughtFission said: I think this is what you meant by 69, correct? Size 69 / Tex 70 / Govt. E Yes the thread size 69 and 92 refer V69 (Tex 70, Tkt 40) and V92 (Tex 90, Tkt 30. A good reference table for thread sizes / strenght and needles sizing can be found at ( https://www.tolindsewmach.com/thread-chart.html ). kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
