  • CFM
use the closest hole  if you need more tension
use the second hole if you need less tension
thread the first hole then into the second hole if you need max tension
YES, run the thread under the sp[ring
what you are looking at is surface area.  the first hole is closest to the screw  it will be tighter
than the second hole that is farther away from the screw
latest modification,  needle/halo lift  has always been a pita to reach. i moved it to the other side of the machine,  The red handle  was made by Chuck
Edited by Frodo
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
So you are sure that everything is threaded correctly but your patcher still does not stitch?
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Very Heath Robinson-ish pulley setup, Frodo - I love it!:lol:
Only now I noticed that your top-left tensioner's thread guide is upside down from mine. Dunno if it matters but it may be worth trying to rotate it 180 degrees so that it sits above the top tensioner, not below.
  • CFM
Thank you !!
If you like that.  check out my lamp.  do you see the brass lamp switch that has no bulb or shade?  that is the on/off switch for the lamp
I am into Steam  Punk Art
D.C.F.M
  • CFM
10 hours ago, Frodo said:
Thank you !!
Steam punk got its start in redneck engineering.  I dont see no duct tape lol.
  • CFM
HA !! I have you  fooled.  No duct tape  BUT I have tie wire  instead of cotter pins
D.C.F.M
  • CFM
ahh overengineering I see. lol bend em in the direction opposite of spin so they don't getcha.
