Digit
Contributing Member-
Everything posted by Digit
You can use all sorts of reinforcements for chrome tan leather, depending on the sturdyness and thickness you want. Salpa (bonded leather) comes in several thicknesses (0.4, 0.6, 0.8, 1.0mm), there's also Velodon, Texon, and you can use just about any type of woven textile cloth or canvas as well. Just glue it to the leather with PVA and make sure you sew around the edges to keep the layers from peeling. If you use some porous reinforcement (eg textile) it'll be a mess of glue of course. Any mess or ugly reinforcement you can hide with thin leather lining on the inside, such as pigskin.
I've heard of people using Dettol to combat mold on leather, which apparently worked. I haven't tried it myself.
I got taught to use contact adhesive, then sew with a left toe walking foot. The CA should keep the pieces aligned. Do use contact adhesive and not PVA/white glue or something. I haven't used double-sided tape for leather seams yet (I did get warned by my teacher to never sew through tape though), but from experience elsewhere I can imagine it would more easily come loose than CA while manipulating the leather when sewing.
When you're going to try machine stitching close around magnets or any other non-stichable material, the walking foot (or presser foot) will hit the magnet. If the magnet is not too thick this might work, otherwise you're in for bumpy ride. I'd suggest to cut your leather large enough (or choose your magnets small enough) so that they stay out of the way of the machine's feet. First glue the magnets inside the leather parts, then stitch around. Having magnetism around a sewing machine isn't much of a problem; there are magnetic edge guides you can stick to the plate to assist you. Unless the magnet is very strong, a triple transport machine shouldn't have much problems dragging it along; you might need to put in some extra effort in guiding the leather to accomplish a nice stitching line.
That's exactly the Chinese creaser I have. I guess the brand name in the display can be OEM'd. The detail photo of the creasing tip shows a horrible MIG spot weld btw; at least my tips have been grinded down and nickle-coated _after_ any welding was done :-) If you do want to save money, buy it straight from AliExpress I'd say instead of having it dropshipped by someone adding a margin. This is mine: https://www.aliexpress.com/item/1005001298911899.html
About durability: I believe the Regad machines at school were bought 4 or 5 years ago when the course started up and they're running pretty much 6-8 hours per day, 5 days per week. It looks like they simply contain a transformer and some circuit to control the temperature (probably PWM). The Chinese unit I have does have electronics to power the display and provide a simple one-button menu system. It would likely fail earlier than a Regad, but at these prices I can consume a lot of Chinese units before reacing the cost of a Regad and that will talke some years I guess.
Yes it was the cost. I'm just a hobbyist and I only use it occasionally for edge finishing; I can't tax-write off such investments :-) A single-outlet machine costs around 380, a handle 170, tips between 160 and 180 depending on type. My Chinese model cost around 100 (machine, handle, three tips) and around 12 per extra tip. All prices Euro including tax, but you get the idea. Maybe when I start using it more often I could invest in a Regad in the future, but for now I'm still learning and building experience (both with leather working and with this machine). For edge burning it's definitely an improvement over the lighter gas soldering iron I used before :-)
We use the the Regad machines in school. They seem sturdy enough, with large massive brass heads heated by an external coil that glows red-hot. The driver units are sturdy steel boxes, but pretty basic in function: just an on/off switch and a knob to select power on a scale to 10; no feedback on the actually produced temperature. We use them on chrome tan and select power based on leather thickness (mostly around 1-2 mm ~ 2.5-5 oz) and creasing speed. For home use I bought a Chinese unit at a fraction of the price. It's heads are only a third to a quarter of the size the the Regad heads and seem to be nickle-plated something. The few times I used it, it did its job. The unit I have has a display with feedback on temperature and duty cycle (if temperature is reached but duty cycle is still 50% or higher, you know that the head hasn't fully reached temperature yet). It goes into sleep mode (lower temp, but not off) after a few minutes idling. The Chinese units all seem to have a threaded bolt to fix the head to, so switching out a hot head can be done easily with welding gloves. I have no idea how the Regad heads are switched (we have about 8 machines at school, all with a different head, so we never need to switch). I didn't find any Chinese units that look like a Regad, so I think Regad effectively builds these machines themselves.
That's comparing apples and bananas. Hermann Oak is a tannery; they start from hides, tan them to leather, then sell them (to wholesalers, retailers and/or individuals). Like any tannery they probably specialize in certain things and try to deliver constant quality leather. Tandy Leather is a retailer of, amongst other things, leather. Like any wholesaler or retailer, they source their leather from various tanneries to accommodate demand for different types of leather (veg tan, chrome tan, cattle, calf, sheep, kangaroo, aniline, nappa, harness, rawhide, pigmented/colored, ...). Retailers will not always disclose which tannery they got their leather from and they will not always try to supply a constant quality. Sometimes they'll sell lower quality leather from reputable tanneries that failed quality control for which the tannery itself has no market and/or doesn't wish their brand associated with. If you want constant quality or constant color in leather, try to find a retailer that either discloses a tannery and/or product name for their leather, or one that supplies sample cards with promises for constant quality/color.
I use a silver pen for marking leather. Works a treat on smooth chrome and veg tan and wipes off easily with a damp cloth. If you let it on for too long it dries out completely and it may be harder to get off. Don't use it on suede/velours/nubuck/etc as it won't come off at all.
Leatherhouse in Germany seems to have kangaroo lace in 3x1mm: https://www.lederhuis.com/stroken_koorden/vlechtriemen_nappa.php?l=e&action=warenkorb&L=Flechtriemen_nappa You have to order a full roll of 50 or 100m it seems.
I have a Dürkopp Adler 69-373 that I bought second-hand refurbished.
I have a Singer HD 4423 for fabric, but I haven't used it for leather, nor will I ever now that I have a triple transport machine. That singer only has single transport (barbs at the bottom that pull the fabric forward), so heavier fabrics can slip and shift under the presser foot, giving an uneven or crooked stitch. It also probably can't deal with the thread size you typically use for leather. Other features that I've come to love about industrial machines is that a household machine (at least this specific Singer) doesn't have electronic needle positioning that makes it easier to sew stitch by stitch.
What is 'the right leather'? As for thickness, 1.5-2 oz converts to .6-.8 mm. I've ordered two half-hides of .7-.9 mm chrome tan horse nappa last month. So that thickness is certainly obtainable, at least here in Europe. Note that horse nappa is sturdier and less stretchy than sheep or lamb. When I bought my cheap Chinese manual splitter off of AliExpress I tested splitting down both a piece of 3.5mm (8-9 oz) veg tan harness leather and that horse nappa. As long as the blade is razor sharp both worked a treat.
I had a similar problem on my 69-373. Solved it by threading around the tensioner in the opposite direction so that the thread travels +/- 400 degrees (slightly more than a full turn) instead of +/- 300 degrees (less than a full turn).
I've bought some stuff from Lederhaus in Germany (lederhaus.com). They have a large choice of leather (veg and chrome), but you do have to order in commercial quantities (half hide, full hide, croupon, ...) not in small cuts. They also sell catalogues with leather samples for which they offer constant colour. And they have tools and supplies (rivets, glue, buckles, ...).
I've bought a cheap leather splitter from AliExpress which works surpisingly well. Splitting down 3.5mm veg tan is super easy and it even works on 1.5mm chrome tan. It's basically just a holder for cutter blades, so a dulled blade can be easily replaced (or sharpened if you like). The width of the leather that can be split is limited to the length of the blade, so +/- 9cm. This is the one I got: https://www.aliexpress.com/item/1005005967041306.html There's plenty of similars and the price constantly varies, but I think it bottoms out at around 35-40 euros.
How to reduce oxidation of copper rivets?
Digit replied to RichardJ's topic in Leatherwork Conversation
I've got a similar issue with an old piece of riveted leather. In the past I've tried to scrape off that sticky green stuff, but it keeps coming back. Since recently I have a spindle press for setting rivets, so I'd like to replace all the nickel-plated brass rivets with new ones (either nickel-plated brass again or nickle-plated iron, wdyt?). What's the best way to remove rivets? Drill through them? (I do have a press drill).
