Everything posted by RWB
Here is one that is Laced down the nose, and has a finish on it. I have yet to decide if I should tie stirrups in them or just stamp another pair that I like better. Ross
I just wanted to say thanks to everybody for their advice. I look forward to trying it out on the next pair. I've got a Full flower saddle coming up that I will get alot of practice in on, and we will see how it goes. Again I appreciate everything. Anything thing else would be more than readily accepted. Ross
Hey Steve, That big red X is my stamping, what are you laughing at?! I try and I try, sheesh. No, just kidding. I would love to hear what you think about them when you take a look. I'll post a pic after I tie a stirrup in them. Thanks Ross
Hi, Anyone is more than welcome to give this a critique, but I would be very appreciative Bob if you could help me me out. My stem work is always this clubby looking. I just can't seem to figure out how to make the stems have more symmetry an flow. Are my circles to big and to far apart? I used the same size of circle for both the large flower and the two small flowers together, but I think that the small flowers were just to small for that size of circle. But even with the big flowers my stem work just looks clubby I guess, thats the only way I can describe it. Like I said ANY critcism is more than welcome, you can't hurt my feelers. Thanks, Ross Brunk
If your having trouble with a glue line, then just stay about a 32nd of an inch away from your edge with your glue. That still gives you enough glue to hold it while you stitch.
laporte tuff tree vs. rawhide wood tree
RWB replied to checkers78's topic in Saddle Supplies, Tools & Trees
There are several custom tree makers out there. All who do a good job, Bill Bean, Swanke Trees, and Quality Trees are all a pretty good tree. Personally I prefer Bill Bean's trees. His work is super clean when he puts them together. But he's also one of the highest priced tree makers out there. Personally I think that Quality Trees would be a great beginner tree. Lower cost, but also not bottom of the barrel for quality. I think they make a pretty good tree. Rod and Denise Nikkels, who are on this site, make trees, and they could chime in and give you the low down on their trees because I've never used one. My advice for you would be to get with an experienced saddle maker, and have them help you with the measurements. That way you don't order a tree that is to narrow or wide or something else you don't want. What Steve said is spot on, just save you money until you can get what you want. A nice custom tree is going to be far easier to learn on than a tree that isn't put together very well. Ross Brunk -
Looks great, Mike. Pinning it was a great idea. If it works that way do it. Kinda like leather work if works, why do it some other way? As far as drilling out the side, things happen. That blade is still going to get murderously sharp and that is all that counts. Looks great! Ross Brunk
$25.00?! Wow, that was a steal. I would like to see pictures of it when you get a new handle on it. Ross
Mike, Thats a really nice W. Rose blade. I have two in my shop that I use every day. I personally think that Rose knives have the best steel of all the antque blades out there. Personal opinion is all, I'm sure others would disagree, but no matter. The easiest way I have found to put a new hand on is this: Cut a blank of hardwood close to the size that you want it to finish out at. Drill a hole in the top large enough to accomodate the entire tang of the blade. Then make sure its going to work, dry fit the knife and such. When it is were you want it, then go ahead and fill that hole with JB Weld. Not only is JB Weld a glue, but it also acts as a filler that is sandable. It will fill in the gaps thats are created by a round hole and a flat tang. (Hint if the tang doesn't fit right and that JB Weld sets up on you, you will have to cut the wood off of the tang. Just make darn sure its right before you glue it in.) When it's set, then all you have to do is sand or cut the handle to exact shape, polish it and it's ready to use. If you want a more finished look go ahead and wrap the top with either copper or brass and braze it together. But if you JB Weld it in there is really no reason to this other than provide a finshed look. That JB Weld will hold it to dooms day. You can also shape the handle before you drill the hole, but it's tough to get the hole exactly centered. I have accidently drilled out the side of a handle before trying to do it that way. Tell me if that helps. If you have the original handle you can also just JB Weld that back on. I've fixed numerous tools that way too. Ross Brunk
Antique
RWB replied to gringobill's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Bill, It depends on how much of the antique you want to pick up. I typically use Neat-lac immediately after I wipe off my antique. If you scrub really hard in a circular motion you are obviously going to take up more than if the Neat-lac is applied lightly. A trick that I have learned is if you want more color then antique it twice. Apply the antique, wipe it off, Neat-lac, let it dry and do it again. There is no rule that says you can only do it once. For that matter there is no rule that says you can't apply two different colors of antique to the same project. For example mahogany antique over the top of black antique gives an incredible dark cherry color. Another thing that is going to determine what kind of color you get is how much oil you apply. If its lightly oiled chances are your color is going to be light. Nothing is wrong with light color, but you will have a tendency to get more vibrant color with a slightly heavier oiling. But on the flip side of that coin to much oil is not good for the leather and it darken the color to much. Play with it, that is the best advice I can give. Try different things. Ross Brunk -
R M Williams Saddle Dressing
RWB replied to gringobill's topic in Saddle Identification, Restoration & Repair
I think Kings Saddlery in Sheridan, WY still carries it, but I could be wrong. Google them, they have a web site with a phone #. Ross -
I notice that you put your emphasis on blade. The unfortunate thing is that most swivel knife makers don't make universal or interchangeable blades. So what you probably looking at, (and what I would recommend if all your using is a Tandy swivel knife) is buying a whole new swivel knife. Someone else has mention Paul Zalesak an Bob Beard I personally have no experience with these two tool makers. However I have heard that they make nice tools, and are worth a shot. Barry King form my experience make the best affordable tool out there. I your interested in Sheridan Style Stamping I would suggest that you start by looking athis web site. He carries nice stamping tools as well as good hand tools. A swivel knife from Barry is going to run $45.00 and a Blade$15.00. They come fairly sharp and with a little honing are great. www.barrykingtools.com Another one I would recommend is Chuck Smith. He makes a really great swivel knife, probably the smoothest spinning knife out there. His blades get and stay sharp easily. But you are going to be looking at paying about $120.00 for a knife and blade, if I'm not mistaken. I couldn't find a web site so maybe someone else can jump in for you with that information. Hope that helps. Ross Brunk
Clean little rig. I like it alot. Ross
Bob, You don't have to apologize for your comment. A tin strainer in a lot of ways is a shortcut. And we all use some sort of shortcut at some point. Some short cuts are great and some aren't. I use a strainer and like to do my seats that way, but you didn't offend me. In fact the only person you seem to offended is someone who likes to tell everyone that he is the best. Don't worry about your comment. Ross Brunk
Huh, well I guess it's a good thing that you are such a speedy learner. I might be out of luck, considering I had to spend about 5 years learning from Don Butler, and I still have the balls to admit I'm not the best. C'mon man I'm sure we can all throw around who we learned from, and make people feel bad or insufficient if we all try to. But that's not what this forum is for. The purpose of this forum is to help people. We all have different ways of doing things, some of the people here are better than others, and some are just starting out. If we are going to get caught up in the things we do different, then nobody learns anything. Personally I use a seat strainer. Whoop dee freakin' do da. I've rode a bunch of saddles with seat strainers that would eat your butt off. I've also rode all leather seats that are the same way. Personally I think that a proficient saddle maker can put several different types of seats in and not have them sore a customer. Am I there? NO!!!!! Are we ALL constantly learning? YES!!!!!!!!!! Even those who have learned from some of the best in the business. I went to Wichita Falls this past weekend for the first time, and learned stuff from guys I had never heard of before. Saddle makers and leatherworkers that most of us have never heard of, but they have that cool little trick that I was looking for. There is no point in ignoring that kind of information. Even if it wasn't Steve Mecum who came up with it. None of us are as good as we love to think of ourselves. Ross Brunk
Are you using roughout skirting or a split chap seude? Ross
Neat Lac over dye?
RWB replied to ETW Grumpy's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Sure, if you oil evenly your color will come out even, but if you oil unevenly you color will probably come out uneven. But acid your leather, let it dry out, apply a coat of oil, and then wait for about 12 hours. That will give the oil enough time to soak in and you will generally be able to tell if it's oiled evenly. If not then LIGHTLY re-oil the light spots,let that soak in, and when you have it even then go ahead and apply your Neat-lac. When that's dry apply your stain or antique and what ever your using for your top coat finish or sealer. You can drastically change the color of an item by how much oil you apply to the leather. So just experiment with it. Ross -
Neat Lac over dye?
It shouldn't smear the dye as long as it is really dry (approx 24 hours after the dye is applied is long enough to wait). I use it all the time over a dyed background and dyed edges with no problem. That Clear-lac stuff tends to smear if you not careful though. Ross -
Removing dye smudge
If it is a regular spirit dye, I have to say I've never found a way to get it out. No amount of profanity will help either. Oil dye, not sure, I don't use the stuff. Maybe someone else can come up with something. Ross Brunk -
Give me a jingle. I'd be more than happy to work something out with you. I'm right in Billings. Ross Brunk www.nrcowboygear.com 406-672-1398
Made A Sheath For My Other Round Knife
RWB replied to cgleather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Great job, nice clean lines. I do have a question though, what do you have behind it in the background? Ross -
Art, I just sew my fringe on to the leg, and cut it the way I want it. ThenI soak the fringe in warm water (I try to avoid getting the leg wet),and start start twisting it. I'll twist up a piece of fringe real tightand then stretch it as much as I dare. If you yank on it to much youwill break it off, so just firmly pull on it. Stretching it out seemsto set it and keep it from untwisting so bad. Then just let it dry. I've never had to do anything other than just let sit and dry out. I've also never had a problem with the twist coming out over time. It will to a small degree but for the most part its there to stay. Hope that answers the question. Ross
Thanks for the compliment. I do make custom chinks, chaps, and armitas for whoever wants a pair. I also have a wholesale line that I do for higher end retail tack shops. I have an Artisan 3000 that use for most of my stuff. On smaller stuff like this you have to crank it down pretty far, but it works fairly well if you do it right. Thanks again, Ross
Thanks Butch, A couple of posts up I replied to someone else asking how I twist fringe. Take a look at that and see if it helps. After I get it twisted I just let it dry out and it stays that way pretty much for the life of the chinks. Ross
I just sew my fringe on to the leg, and cut it the way I want it. Then I soak the fringe in warm water (I try to avoid getting the leg wet), and start start twisting it. I'll twist up a piece of fringe real tight and then stretch it as much as I dare. If you yank on it to much you will break it off, so just firmly pull on it. Stretching it out seems to set it and keep it from untwisting so bad. Then just let it dry. The thing that I don't like is it makes your fringe all different lengths. It think that the only way to avoid that would be to cut it long, twist it and then trim all your fringe to the same length. But that would be alot of work. Took long enough as it is. Ross
