MarlinDave
Everything posted by MarlinDave
The motor was new on the machine when I got it. Might have 20 hours on it.
Thanks for the ideas. I considered a VFD for some 3 phase machine shop items I have. Built rotary converters for 2, one came with a static converter box. I was always scared of VFDs because so many have problems with them. The clutch is not smooth at all - grabs all at once. It takes off fast, then slows.
It has the smallest motor pulley as well.
Hello, I have a Consew 225 with a clutch motor. Too fast for my use for leather. Built a belt and pulley speed reducer, approximately 3 to 1 ratio. Helps but not where I need to be. Lengthened the arm on the clutch motor linkage and getting close. I wondered about an electric speed reducer like you use to plug a router or other power tools into. Anybody ever tried one of these? I built a speed control with a light dimmer switch yesterday. Worked a while but at some point the motor kicked out and I was able to get it going again. Did not expect this to work but wanted to try. Not enough power (600 watts maybe). Would try a router speed control if it would be safer for the motor. I know about servo motors, but really don't need to spend that much right now as I pretty much give all my work away. Thanks.
Mcclellan saddle , help!
MarlinDave replied to bighop72's topic in Saddle Identification, Restoration & Repair
https://mcclellans.militaryhorse.org/mcclellan-saddle-identification/ -
Paddle Sheath
MarlinDave replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Anybody got a pattern for a paddle style sheath for a 5 inch hunting knife?
Moving Industrial machines around the shop and outside
MarlinDave replied to Dave9111's topic in Leather Sewing Machines
Mount them on a little trailer with a bench seat? -
Vehicles with both metric and SAE fasteners, plus Torx, plus Phillips screws. Have to drag the whole shop under the car to test sizes. As for the T shirt, they usually have the seams closer together in the back of the neck than the front. Thats the only way I can tell without putting it on wrong.
spring flowers and good food
MarlinDave replied to chuck123wapati's topic in All About Us and Off Topic
Want Marlin 336CS Lever Wrap Pattern
MarlinDave replied to Reichenbach1976's topic in Patterns and Templates
I figured it would make your lever rust. Here is one that would be easy. Just a strip the length of the lever with holes punched and braided on. Big loop lever, standard lever, pistol vs straight grip would vary in length. https://www.amazon.com/Handcrafted-Leather-Lever-Wrap-Action/dp/B0BWTMX59S/ref=asc_df_B0BWTMX59S&mcid=01ae33d3797c3e7b86ffc385894f0f80?tag=bingshoppinga-20&linkCode=df0&hvadid=79920941687458&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583520405611133&psc=1 -
Do you not just take wide lace and wrap it it till you run out of lever? -
Cheap leather which looks fine till you finish the project and dye it and a big spot in the center wont take any dye.
Consew 230R-1 setting it up for leather
MarlinDave replied to lilbax's topic in Leather Sewing Machines
I have my first machine sitting in the back of my shop. It is the same model Lucy Arnaz used in the I Love Lucy episode where she sewed her sleeve into the dress she was making. Bought it for leather. Will sew one thickness, not 2.- 27 replies
- needle size
- thread size
(and 4 more)
Something that may help you out is many industrial sewing machines have a compatible table and motor. You probably can get just another sewing machine (some call it a head) and replace yours on the table and motor you already have. All you do is lift it up, remove the belt, and it pulls off. That could save on both price and shipping for your replacement machine. You may need a speed reducer if it does not have a servo motor for speed control, or replace the motor with a servo motor.- 27 replies
- needle size
- thread size
(and 4 more)
I would not care except I have some bills due. If they don't pick up today I need to go get them out of the mailbox and deliver them after the thaw. Bill payments are taking 8-10 days without weather issues lately to deliver. I ordered a jump drive from Woodcraft that should arrive soon. It has 13 years of digital Woodcraft magazine for $20. Might keep me occupied till the roads clear. -
Hey Chuck, How regularly does your US Mail run in bad weather in Wyoming? We had a 4-6 inch snow, a lot here, not much for other areas. Still cold so it can’t melt after about 6 days. Mail is not running at all. I don’t ever remember this happening, and a lot worse snows other places I’ve lived. My uncle was our mailman as a kid, had an old 72 Blazer, nothing stopped him. -
Thanks. A little light for my needs I think.
Seller thinks the tag says 281-1.
This is on Marketplace for $200 nearby. Guy can’t find model number. What model is it? Walking foot? Largest thread? Thanks. David
