Everything posted by troop
Denster, WOW! you absolutely hit a home run with that one! I tend to shy from molded revolver holsters because they never seem to mold as nicely as the autos, but not only is that the handsomest molded revolver holster i've seen it ranks up with some of the nicest auto holsters as well..... well done! Tony
Leather Thickness And Ease Of Moulding
troop replied to Andrewsky's topic in Gun Holsters, Rifle Slings and Knife Sheathes
the vacuum bag must help then. if it works i say do it. Tony -
actually Denster, i have found the opposite a problem. i soak it untill ;the bubbles pretty much stop. i tried to do it with less time but found that if i just got it wet for up to only a minute or two that when i molded it would sometime burnish the leather and cause dark spots. i have had no such problems when i soak it for several minutes and am really pleased with my results. Tony -
i used to use 8-10 oz front and back but found you just don't get enough detail in the boning. so now i use 8-10 for the back and 7-8 for the front. works perfectly Tony -
Attempting To Make Dual Mag Holder
troop replied to George B's topic in Gun Holsters, Rifle Slings and Knife Sheathes
ok, now i see what you are talking about. i had the same problem when i first started making mag pouches in that manner. (before i had molds and blanks made) BITONE40 has it right with the way he cants in the thread line and how it evens out after putting the mag in. another option is to cut a U-shaped section out of the middle side so when you fold up the two ends those protruding corners are gone. mine are flat on the back with the front placed in a mold in a 12 ton press. good luck and keep at it. you'll be glad you didnt give up. Tony -
George, i'm not sure what you are trying to explain. are you having trouble with the mag covers? here is an example of one i completed for a shoulder rig if it helps. Tony -
still looks great. are you getting your leather "holstered"? i get mine "holstered" from W/C and it is so tight it is really hard to cut through. i sometimes have to use it to cut designs on for notebooks and stuff and it is really hard to carve on. Tony
1911 Dual Mag Carrier Help Please
troop replied to Shooter McGavin's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Shooter, you hit a home run with that set up. my hat's off to you, very well done! Tony -
not sure i'm understanding you correctly. are you saying you have a 1" gap in between the two mags? that is way too much. a 3/8" gap is plenty to allow a walking foot machine to sew between and keep the unit compact enough. are you molding the top and keeping the back flat or are you splitting the leather even on both sides of the mags. i don't have pics of ones i do with belt slots but on this one you can see the 3/8" gap between the mags. this one has clips on the back side and not belt slots. when i do slots i sew up in between the mags instead of using a tension screw. Tony -
Retaining Screw On Holsters
troop replied to KAYAK45's topic in Gun Holsters, Rifle Slings and Knife Sheathes
it pretty much is straight out of lowes. a t-nut, screw and a rubber vacum line cut into spacers. that is how i used to do them. stopped doing them at all now unless a customer really demands it. they are ok in the beginning but pretty soon you have to keep tightening them until one day they are at the end with no more room to tighten and you find that all you have done is stretch the leather out. just a good ol fashion tight stitch is all you really need. Tony -
Pancake - First Attempt - Need Feedback
troop replied to particle's topic in Gun Holsters, Rifle Slings and Knife Sheathes
it looks good Particle. one thing i noted with the heavier handled short guns is to concentrate on getting as much of the belt as possible behind the the meat of the trigger guard or higher. ( the higher the belt rides, the less tilt over you get) it wont ride as high but its still short enough to stay concealed and it pulls the weight of the gun against the body. it looks like you got the belt good enough behind the tirgger guard. the only way to get the belt higher up is to cant it foward more, raising the belt slot on the slide side. Tony -
What Thread Size For Holsters
troop replied to NC Holster Maker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
i use 346 on the top and 277 on the bottom. Tony -
Newest Holster/ammo Pouch Combo
troop replied to troop's topic in Gun Holsters, Rifle Slings and Knife Sheathes
using Wickett and Craig. i love their leather plus i can get just one side at a time. Tony -
thanks all. actually i bought a square foot of three inch thick HDPE (high density polyethylene) then had molds and blanks made out of it for all of the common magazines. 9mm double, 40 cal double 45 cal double and single.... the stuff is very strong and takes a 12 ton press like a champ. i would recommend it over wood anyday. it cuts like wood but is way stronger. it is expensive ( $100.00 a square foot) but if you plan on doing this for awhile it pays for itself. Tony -
Question Re: Thumb Breaks
troop replied to BConklin's topic in Gun Holsters, Rifle Slings and Knife Sheathes
line 24 snaps are fine. -
From the album: my stuff
New Ruger Holster And A Finish Question!
troop replied to ShortBBL's topic in Gun Holsters, Rifle Slings and Knife Sheathes
what leather are you using? and how are you molding (boning) the holsters. it almost looks like they're not getting enough moisture into the leather and you may be burnishing them when you press the shape of the gun in them. i soak mine until the bubbles stop then let air dry for about 15 min before i start molding the gun to them. i have never dipped my holsters in neatsfoot but do apply it with a dauber and actually love the look i get with the oiled chestnut. Tony -
Too Much Dye?
troop replied to particle's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I wrestled with the dye issues for awhile, then started getting it drum dyed from the seller. very much worth it in both the money it costs to get it dyed and the time saved waiting for the dye to dry. air brushing does apply the dye more evenly and leaves less of a chance of the blotchiness, but i have found i need put it on extra thick with the airbrush to get decent penetration. if money is not an issue, i'd opt to get the leather pre dyed. it is more uniformed color and saves money and time in the long run. Tony -
Airbrushing Dye, Etc.
troop replied to Sixer's topic in Gun Holsters, Rifle Slings and Knife Sheathes
kinda along the same line.....has anyone applied dye, more particularly with an airbrush on english bridle? was curious how it takes dye before i start trying it. Tony -
cool thank Rayban Tony
