What Rubber Pad And Where To Buy For Shaping Holsters
Wizcrafts replied to Wizcrafts's topic in Leather Tools
I just placed an order for two pieces of foam, 12" x 24", from knifekits.com.Thanks for the recommendation. I now have two different types of rubber to use. We are still waiting for the metal work to come back, so the rubber can be tested. -
First Machine: Singer 78-1 Vs. Singer 96K40
Wizcrafts replied to AWilliamPast's topic in Leather Sewing Machines
This is a very old machine. Oil it when you get it set up in every available oil hole, including tilting the head back and oiling the connecting rods on the bottom. Then, oil it routinely, weekly for light use, or daily after heavy use. Use industrial sewing machine Lily oil only. Hold the threads back before you start sewing. To lock the stitches, sew backwards about three stitches, then do the Poor Man's Reverse and sew forward to the end. Do another Poor Man's reverse to lock in the last three stitches. Clean all the tension disks and guides, plus the bobbin basket and bobbin spring. Oil the revolving shuttle in which the bobbin sits. Do not over stress the machine. It is for light sewing. Do not pull back too hard on the leather as you sew, or you will override the walking foot and needle feed. This will cause short and long stitches. Use bonded nylon thread if possible. Do not run it too fast or it may overheat and seize the bearings. 10 to 12 stitches per second should be the limit after all these years. Get leather point needles for leather. Use round points for cloth, webbing and vinyl.- 6 replies
- leather sewing machine
- singer
(and 1 more)
All of the brands you listed, plus, Chandler, Consew, Cowboy and Technew, just to name a few good brands. All of these companies make excellent triple feed walking foot machines, with large bobbins and reverse, to modern standards.- 6 replies
- singer
(and 1 more)
I don't recall speaking highly of the 96k40, just mentioning that it was my first mistake when I got into sewing leather. They are tailors' machines and nothing more. The only way I got it to sew a leather vest was by converting it into a roller foot machine, which involved replacing the foot, throat plate and feed dog. After all that, it would only properly tension #69 bonded thread, into not much more than about 3/16 inch of garment leather seams. It definitely sewed better on cloth than leather. The Singer 78-1 is a double feed machine, without feed dogs. You may or may not have trouble maintaining a consistent stitch length, depending on the nature of the material and thickness changes. You should be setting your sights on a true, compound feed, walking foot machine for leather work. Modern w.f. machines can sew with #138 thread, top and bottom, up to 3/8 inches of compressed material. They usually have reverse levers and long maximum stitch lengths. Some can even handle #207 thread, especially those with large bobbins. Read my sticky post at the top of the Leather Sewing Machines forum for details about the type of machines you really need to sew various types and thicknesses of leather.- 6 replies
- singer
(and 1 more)
Hopefully, we'll know soon. My partner is having the metal plates made and welded to the frame strut and jack push rod. The bottle jack is a simple Harbor Freight model without any gauge. It has a two piece round steel handle. I am not so concerned about damaging our blue guns. But, I am worried about a customer's real pistol under such tough material. I'm searching for 30 D rubber to place on the holster side, but have only found neoprene thus-far. The whole shebang will be doubling as a clicker die press. -
Singer Industrial Sewing Machine 591-D300A
Wizcrafts replied to novaroper's topic in Leather Sewing Machines
O. What letter or class of bobbin does it use? -
I wonder if two 1" rubber sheets will accomplish a similar result to a solid 2" sheet (which doesn't appear to be available)? Maybe combinations of 30 D and 40 D, with 30 facing the project. -
Sewing With A Change In Thickness
Wizcrafts replied to Tree Reaper's topic in Leather Sewing Machines
Try backing off the pressure spring, bobbin and top disk tensions. Thin material has a harder time feeding evenly if the thread is pulling it back, or the feet hold it too tightly. -
No, that's not right. You shouldn't notice any change in stitch length for such thin leather. Are you using the feed dog, or just the slotted plate? -
Tell me more about the vacuum bag, Dwight. -
The tag in photo #1 says Natural Gum Rubber. That is not what I got. I ordered Buna-N, Nitrol based rubber. Maybe it is the wrong composition? Why do you need 2 inches on top and bottom? -
If you have a tiny piece that is expendable, could you mail it to me? I need a comparison. -
Most industrial sewing machine dealers stock them for garment and upholstery grade machines. Expect to pay up to double what standard needles sell for, unless you buy them by the hundred. Also, Joann Fabrics, with Viking Sewing shops embedded, stock them for long arm quilting machines and high speed embroidery machines. Here is a Google search result for Titanium sewing machine needles.
1: Yes 2: No. It is just a very high speed straight stitch garment machine, with a static (but interchangeable) presser foot and bottom feed only. Any machine can be slowed down by simply adding a Family Sew FS-550 servo, equipped with a 50mm pulley (sold by Toledo Industrial Sewing Machines). No need for a speed reducer on such a light duty machine. The 591 contains an oil pan and has an oil pump. It must be run at high speeds (2500 to 3500 RPM) to distribute the oil to the extremities. It is meant to be run at several thousand stitches per minute (5,000). It will only sew about 1/4 inch (.26") of cloth material, with a maximum stitch length of just under 5 per inch. The bobbin is a standard Class 15 that snaps into a bobbin case on the left end, under a sliding cover. Thread handling stops at #92 (T90 bonded, or T80 heavy jeans thread). The pressure spring is purposed for holding down cloth, not leather. FWIIW: I considered buying one of these from a drapery shop that used it for small jobs made with light material. I tested it on-sight and found that it couldn't sew 8 - 9 oz belt leather without skipping stitches, caused by the presser foot lifting with the needle on the upstroke. There is no future in spending any money on a machine like this unless it is going to make or repair cloth garments or pillow covers. -
I concur with T.R; increase the bobbin and top tensions for tighter thread on both sides. Move up to a larger diamond point needle (to keep a straight line, with top holes filled). Further, try changing the position and tension of the thread check spring by loosening the screw in the slot and moving the disk one way or the other. You may even try increasing or decreasing the travel of the check spring a bit and see if that helps.
That is the material that Tree Reaper bought and linked to. I found a cheaper source, but it seems to be the same construction. I will know in a few days if it has to go back for something less dense. -
It arrived today. The rubber is very hard to the touch. I have my doubts that this 40 Durometer Buna-N is going to actually form around a holster with a blue gun without breaking the gun. Also, it looks like it is assembled from 4 x 1/4 inch sheets molded together, rather than being one piece an inch thick. I won't find out until sometime next week when the metal plates come back from the machine shop where they're being fabricated and welded to the jack post and cross beam. If the 40A is too hard for molding, will 30 Durometers be suitable? -
Yes I find that the needles need to be moved hard right. Yes
I have a 29K172, long arm, big bobbin Singer patcher. It doesn't like #138 thread at all, but does great with #69 or 92. The most it can sew is 5/16" of leather. Originally, it used the proper system 29x4 needles. But, after suffering from too many skipped stitches, I started using system 135x16 in it. Because most of my work is taped together with Venture Tape for leather, I regularly experienced problems with glue sticking to the needles and causing skipped stitches (on the patcher only). So, I experimented and ordered some expensive Titanium coated needles. They rarely let tape glue residue stick to them and I have fewer skipped stitches with these needles. Note, when I got my 29K172 I wasn't aware that the shuttle driver was worn out around the set screw hole. This caused me two years of frustration as I tried everything I could to time it. I even replaced the rack and pinion gears under the arm. Finally, I hauled the head to Toledo Industrial Sewing Machines and had Bobby go over it. After an hour+ of trying things, he pulled out the shuttle driver and saw that its hole was worn oval. He replaced it with a new driver and the skipped stitches are mostly a thing of the past. In the past I have owned a 29-4 patcher that was so worn out inside the drive ring "puck" that the longest stitch was only 8 to the inch. I bronze-brazed it back to original shape+ and got it to sew 5 to the inch.
Now I need to find a source for a custom sized clicker dye cutting board: 12" x 20" x 1" -
My advice is try it before you buy it to ensure that it sews a good stitch. Inspect the body castings for sharp edges that might cause problems with the motion of the various parts. Make sure the presser foot drive ring rotates smoothly 360 degrees. The presser foot should not have measurable slack forward and backward, or stitch length will suffer above 3mm. Get a warranty in case something bad happens after you get it home.
I just ordered 2 sheets of 12" x 12" x 1" Buna-N 40A rubber from Zoro Tools, online, for $50.58 (for both), shipped free. -
I am replying to you from my W7 PC, with JavaScript disabled. There is no formatting toolbar available, as it is created, shown and hidden via JavaScript functions. Are you perchance blocking JavaScript in the browsers on the PCs you referred to?
Do you get the text formatting toolbar now on your iPad? I still have none using my Galaxy phone. The letter N you mentioned is part of the toolbar. If one's device doesn't display the formatting toolbar, the N is not there either. This was typed from my Windows 7 PC. Note: there is a tiny arrow on the right edge of the formatting toolbar. Clicking on it shows or hides the toolbar. That arrow is missing on most Android device mobile browsers.
Adler 167 Sewing Thin Leather And Extra Foot For Machine
Wizcrafts replied to marrie's topic in Leather Sewing Machines
Marrie; Ask your nearest Adler dealer to look to see if there is a throat plate with a very narrow slot available for your machine. This plate replaces the existing throat plate and requires the removal of the bottom feed dog. This converts the machine to dual feed: moving needle and inside foot. If not, see if there is a narrower feed dog and needle plate combination. The feed dog would probably have a much smaller hole, requiring smaller needles, for fine work. Otherwise, you may have to buy a separate machine for the lighter work. I keep a straight stitch Singer 31-15, that takes a wide variety of presser feet (including rollers), feed dogs, throat plates, etc. It is much easier on thin and soft material than any of my walking foot machines. There are many modern equivalents of that machine. It is a tailor's machine. Look for one with a servo motor, that does not require it to be operated at break neck speeds to distribute the oil.
