Yes, it will work on that machine just fine. The 500GR has built-in 3:1 gear reduction. This makes it more powerful than it looks. It also limits the top speed of the motor to 1500 RPM. The SewPro 500GR mounts a little closer to the table than a clutch motor. You will lose one inch of belt length, if the motor feeds the machine directly, without a speed reducer. If there is a reducer in the system the belt change may be negligible and easily compensated for via the motor adjuster bolt. If it is feeding all the way up to the flywheel on the machine, buy a 1" shorter belt. If the pulley on the original motor is larger than 2 inches, subtract another inch for each inch that the SewPro is smaller. In my case, I replaced a clutch motor that had a 2.5" pulley with the SewPro motor and a 2" shorter belt. This positioned the motor a a favorable angle for the pedal rods to pull smoothly. Doh! I almost forgot the last question you asked! The existing belt will have a number after a letter. The letter probably is M. The number indicates the length of the belt, at the inside of the tapered belt's circumference. For instance, if the original says it is an M44, and the original motor has a 2" pulley, you would then order an M43 belt with the motor. If the original pulley is 2.5 or 3 inches, you would order an M42 belt (assuming a 44" to start with). The threaded adjuster allows for about 1.5 inches adjustment, up or down from the center point. But, the good operating angle occupies a range of about one inch, from the center down. Each pedal setup may differ from others and your floor pedal may allow a full range of adjustment, up or down, without binding. Mine didn't.
It replaces the existing motor and switch box, with its wiring.
Worse yet, some of the sewing machine dealers on eBay simply ship the unopened box to you, without first going over the machine. Some of those dealers buy out entire job lots from other dealers who go out of business (I've seen them advertise their lot of sewing machines in a storage locker). Our dealers remove the machines when they receive them from the manufacturer. Then, they go over them, looking for any problems that need fixed. Then, they adjust the timing and particular clearances, mount them on tables and sew them off. When you buy a machine from our people, it will work as advertised. Plus, if you have problems, or just general operational questions, out dealers are always willing to help you out. Finally, if the worst happens and the machine jams beyond your ability to fix it, you can ship it back to our guys for repairs. Most eBay sellers will only take back a machine if it is dead on arrival. You may find lower prices on eBay, it is true. But, very few of the low price eBay sellers are also equipped to service the machines afterward. Also, you can forget about telephone support with most of those folks (but not all). Whatever machine you buy, from wherever you buy it, don't neglect to oil it regularly. If you buy an automatic oiling machine. check the oil level every week or two. It only takes a couple of minutes to seize a shaft in a bearing if oil doesn't get to it.
You can get anything you want at Alice's Restaurant!
I second what JimBob told you about the SewPro motor. I bought mine from Toledo Industrial Sewing Machines and it is a God send. I used to hand wheel around belt and strap tips, with my well adjusted clutch motor. Now, I use the servo motor to sew at 1 stitch every other second, guiding the work with two hands. BTW: The SewPro 500GR from Bob Kovar has a 2 inch pulley. This really slows down the maximum speed, while multiplying the torque. My hot-rodded walking foot machine is now capable of sewing 1/2 inch of leather, at slow controllable speeds, without slippage, thanks to that little servo motor.
Polyester thread is for use on items that are often used in direct sunlight or water. It is primarily used to sew awnings, tents, car wash cloths, boat covers and sails. Bonded polyester thread usually has a UV coating to prevent discoloration in direct sunlight. Bonded nylon is a tad stronger and seems to be better bonded. It is used more often on items that are not left in the sun or that are frequently soaked in water. Nylon thread is cheaper than Anti-UV coated polyester. It is the staple thread of most leathercrafters with machines. There is one more type of thread I want to mention: Glazed linen. This is the cream of the crop thread that is used in shoe sole stitchers, and in most needle and awl harness stitchers. Many commercial holsters are sewn on needle and awl machines using waxed linen thread. When properly waxed, this thread will outlast the owner of the sewn goods. If one stitch breaks, the rest stay locked. This is why shoe soles are sewn with waxed linen thread. Most Puritan machines use waxed linen thread.
I apologize for assuming that Tat2 was trolling. This was not the case. Sometimes, things aren't what they appear to be.
Johanna; I hate to do this, but I believe that it is necessary. I have a Troll on an ad I placed in the Used Machines section of the forum. The topic is here - for a Randall R132 strap cutter. A member from Canada, using the handle Tat2 - is an equipment dealer and is challenging the (asking) price I posted and has just revealed that he sells a foreign made copy for much less. I take it that he is trying to drive traffic away from my ad, to his own store. I have no problem with people hashing out the nature of this or that machine, or who has the best package prices, where people are looking for basic information. But, this looks to me like out-right theft of my topic, by a dealer looking to sell his machinery at a lower price. I thought you should know. I couldn't find a name for the moderator of that section. Sincerely, Wiz Feinberg Name: Wiz UserName: Wizcrafts IP Address: 76.122.131.41 Email Address: leatherworks@wizcrafts.net
The value is high because the machine was built entirely IN THE USA, with AMERICAN parts and AMERICAN labor. There are very few machines left that are entirely produced here. I'm sure your Italian machine works fine, but what will it cost to add all the extra blades and spacers that come with this Randall? Does your machine have grease fittings on heavy sealed bearings? Anyway, you are a dealer, not a buyer. Why are you trolling on my ad?
The Type Of Sewing Machine You Need To Sew Leather
Wizcrafts replied to Wizcrafts's topic in Leather Sewing Machines
A needle feed - jump foot machine is preferable to a walking foot mechanism, as long as the material is taped, stapled, tacked or glued together. A standard top-pivoting pendulum needlebar doesn't provide the same timing at 3/4" up as it does for the bottom layer. It is the physics of the pendulum that causes bigger stitches to occur on thinner leather than really thick work. On the other hand, a Union Lockstitch machine has a jump foot and true square drive needle feed. All layers move together at the same rate, whether 1/8 inch or 3/4 inch. Their brother-line, Campbell-Randall, are awl-feed machines, where the awl penetrates the layers, then pulls them back together (squarely). The needle only rises and falls on this type of machine. Either machine can lay a tighter stitch than any standard closed-eye needle machine. Both can sew with linen thread run through liquid wax. Their maximum thread handling capacity is 10 cords, left twist. That's like what is used on the soles of leather boots! On most needle feed machines there is still a lot of top pressure required to hold down the leather as the needle (or awl) begins to ascend. But, the pressure is applied to the sides of the needle hole, not directly over it. That's why there is less puckering on the bottom of a needle feed- jump foot machine. By matching a narrow slotted throat plate to smaller needles, one minimizes the bottom puckering on needle feed machines. In some cases the owner will have to have these plates custom made. Other times, the manufacturer may offer narrow slotted plates as an option. Union Lockstitch is one that has such plates as an option. I'm fairly confident that the Campbell-Randall machines also have a narrow slotted cover plate available. The same machines that can sew 10 cord linen thread into armor or hiking/combat boots can also be setup to sew 4 cord linen thread into show harness. I learned to do just that on a Randall stitcher, at Freedman Harness, years ago. At 10 stitches to the inch, using a #11/2 needle and 2 awl, the stitches were tight and beautiful, top and bottom. Walter Mitty would have loved to operate a Randall machine. All day long they go tapocketa, tapocketa! Anybody wanting more information about the Union Lockstitch and Campbell Randall needle and awl machines can contact Campbell Randall, in Yoakum, Texas. -
No, I don't swap wheels. I tend to buy machines that have the best wheel to start with. But, if I need another hand wheel, I'll call "Toledo Bob."
Stitching Indicates Bobbin Thread Tension Too Tight...but
Wizcrafts replied to equiss's topic in Leather Sewing Machines
I don't like that part about the knee lever lifter being out of whack. Tilt the head back again and fix the knee lever rod position. It definitely could impact your stitches if it is pressing against a shaft, instead of the roller it is supposed to push. -
It's not your imagination Steve. These machines need to be broken in. The get quieter and smoother as they age and loosen up. Keep it well oiled between jobs.
Your top thread may have jumped out of the middle of the tension disks. The top tension adjuster may have backed off from vibration, or been turned without your knowledge. The needle might be too small for the thread you are now using. Assuming the bobbin tension spring is set to allow light pressure, the bobbin thread might be getting caught or jammed on the way up. Is it easy to pull the bobbin thread through the feed dog from the top of the machine? There might be a clump of thread in the shuttle -
Absolutely!
Smart Servo Motor On My Upholstery Machine!
Wizcrafts replied to olroper99's topic in Leather Sewing Machines
Now that you have slowed down the speed of the motor and smoothed its pull rod operation, the next logical step would be to play with the free movement before the clutch engages. Loosen the big nut on the bolt in front of the output shaft. Turn the threaded bolt out to get more free play, or in for less. Tighten down the nut when you have it set to your liking. -
I'd wager that "Toledo Bob" probably has the large 6 spoke handwheels for the 31-15 machines. If not, he can find another wheel with the same inside shaft diameter to mount it onto a 31 class machine.
Coitently! Read this thread to see how one member slowed down and maxed the torque on his upholstery machine, plus gained a huge handwheel.
I sew patches onto leather jackets and vests with a patcher machine. It is best to use #69 thread, with a #16 or #18 needle when applying patches. Make sure there is enough foot pressure to allow the teeth to pull the work the stitch length you have set. I use double-sided leather quality sticky tape to hold the patches in place while sewing them. Alternately, use barge cement to secure the patches to the leather. The usual procedure is to open the lining at the most convenient place that is inline with the area where the patch will be sewn. Feed the leather garment over the arm and make sure the lining is under the entire arm. Position the needle, drop the foot and start treadling around the patch. Go over the starting point a few stitches, then stitch back past it a stitch or two, then lift the foot and pull the material to the next patch, et. al, until you are done. If there is sufficient top pressure, the foot should feed the taped or glued on patch and leather together, without any puckering. The glue you are using must not be holding very well if the leather is able to shift under the patch, as you stitch. BTW: Please don't take this as an attack, but, typing entire posts in all capital letters is considered SHOUTING and is strongly frowned upon in normal forum and bulletin board Netiquette.
Here's my sticky article: http://leatherworker.net/forum/index.php?showtopic=25239 If the 29U172 is the same machine as my 29K172, it will sew about 1/4" of leather; maybe even 5/16" with the pressor foot at maximum lift. It can handle up to #138 thread, but goes a lot longer with #92 or #69.
What I see in the photos of the two wheels is that while the hand wheel is larger on one, the pulley isn't. That means that it will be easier to hand wheel the machine, but there wouldn't be any speed reduction, nor torque multiplication, if one swapped wheels. The only way to get slower speeds, with more torque, is to do one of the following changes: Change the original clutch motor pulley to a much smaller diameter pulley (with a shorter belt). Buy a speed reducing double or triple pulley to go between the motor and the machine. They mount under the table and add one more v-belt. They typically yield about 3:1 speed reduction and the same amount of torque multiplication. Replace the motor with a SewPro 500GR servo motor (& shorter v-belt). It has built in 3:1 speed reduction gears and a 2" pulley.
From your description of that machine, it hasn't really been reconditioned! It sounds like you will need to replace the needlebar needle securing screw. If the new screw doesn't hold the needle in tightly, the bar may need to be tapped to a large thread and hole size (with a new screw to match), or replaced altogether. The stitch length changing that much, on a relatively thin seam sounds like a loose feed dog, or a loose or totally worn out upper feed mechanism, or an unusually loose stitch length adjuster knob. You may be best to ship it to a qualified dealer on this forum, for professional repairs.
Guys, there's no need to fight over this. My friend asked me to post the machine for sale with his asking price, which is based on what he paid for the machine and the modifications to it. If somebody seriously wants to get this machine they should call him and discuss it with him and see where the price goes from there. He doesn't even have an email address at this time. That's why I posted the machine details for him.
Amen! If you really can't live with the bottom puckers, reduce the pressure on the pressor feet. If there is a pressor foot spring on top of the head, turn it counterclockwise, until it almost pops out. That is the point of minimum spring pressure. As long as the leather doesn't lift with the ascending needle, go with reduced top pressure. If the needle causes the leather to lift, increase the pressure until the leather stays put.
