Wizcrafts
Moderator
  1. Check on the Weaver Leather Master Tools Cub web page. There are some positive reviews from actual buyers.
  2. A few years ago, @Cobra Steve was mailing out variable density light filters that we could insert between the light source and the sensor in the brushless motors everybody was selling. The filters gave very smooth control of the startup speed if properly positioned (and if they stayed put). I don't know if he has any light filters left, but it might be worth inquiring. He owns Leather Machine Company (Cobra), an advertiser here with banners on top of our pages.
  3. You must have a brushless, pushbutton controlled servo motor. Those are horrible for slow speed use. I discarded all of those and replaced them with brush servos that have a knob on the front to limit the speed. These motors start at zero and gradually speed up. The motors I now use come prefitted with a 2" pulley. This lets the typical machine to sew at about 1.5 stitches per second, depending on the diameter of its pulley. When I need even more slow speed control, I add a speed reducer (shown on same page as above linked to motor).
  4. From my personal experience with sewing machines, just because a given needle bar and throat plate/feed dog will clear a #25 needle does not in itself mean that the shuttle or take-up/tensioning system can handle #277 bonded thread. I found that only the largest leather stitchers can actually handle this size thread efficiently and pull its knots well up inside the leather. I also learned that trying to force feed #277 or #346 thread to a machine that wasn't built with this in mind will damage it.
  5. You should be able to open the faceplate and loosen the set screw or screws securing the presser bar to the lifting cranks and lower it until the presser foot makes contact with the throat plate. The best rotational time to do this is when the inside foot has just barely touched the feed dog. That's when the outside foot should still be in contact with the throat plate. Don't forget to re-tighten the set screw after lowering the foot!
  6. I put a thin spacer inside the top of the stitch adjuster nacelle on my CB4500 and it helps equalize reverse stitches.
  7. This is not the best machine for your tin projects. It is super heavy duty and would need to be "dumbed down" to properly sew thin seams with thin thread and thin, 2.75" long needles. You should be looking at light to medium duty walking foot machines, in flat bed or cylinder arm/with add-on table configuration. For flat beds, a Consew 206RB-5, or P1206RB, or Juki DNU-1541, or equivalent Cowboy CB1541 would be good choices. For cylinder arms, the Consew 227R, Cowboy CB227R, Juki LS-1341, Cowboy CB341. These all use thread sizes 46 through 138, top and bottom. Some can apply extra top tension to pull up #207 thread. They also need heavier duty presser foot springs to hold down the leather while pulling up heavy thread knots. Later on, if you need to sew thicker than about 20 ounces, or use heavier thread than #138, you can buy a CB4500. It uses thread sizes 138 up to 415.
  8. @Silvershadow What Bob and Glenn are telling you about the height of the feeder is due to the fact that your machine was made for use with edge bias tape binder attachments. The feeders only move forward and backward on binder machines to help gather the bias tape and push it tightly against the edge of the material. Some binder machines have a smooth feed dog, but yours has teeth. Methinks those teeth will interfere with the normal feeding of leather, pushing and pulling instead of just pulling. That's why they need to be at, not above the top of the throat plate slot.
  9. These are medium duty sewing machines. While they can sew up to 3/8 of an inch, that probably doesn't include worked and hardened veg-tan. But, 12 ounces should be fine with either machine; even 18 ounces. After you cross that general thickness it becomes harder to hold down the leather to form a stitch. Also, these machines can't handle #277 thread, which is required for three layer holsters. The most they can handle would be #207 thread on top and #138 in the bobbin. That means that the strength per stitch is limited by the smaller thread. In this case that would be 22 pounds test. Holsters and sheathes with fillers should be sewn on a harness stitcher, like a Cowboy or Cobra heavy stitcher. They can tension #346 thread and hold down 3/4 inch of leather.
  10. It is a patcher, for sewing patches on vests, repairing loose thread on boots and shoes, fixing tabs on purse straps and other light leather work. It can sew up to about 1/4 to maybe 5/16 inch of light to medium temper leather with #69 or #92 bonded thread. The bobbins are very tiny and don't hold much thread in sizes over #92. When new, or rebuilt, the stitch length maxes out at 5/inch at about 1/8 inch, dropping to who knows how short at 1/4 inch. It really depends on how worn the feed motion mechanism is. Did you see a Sutton patcher for sale, or already own one?
  11. Your photo is showing the back side of the machine. We need to see the front to identify the make and model. Take a close-up showing just the head, in sharp detail. Look for a tag with a model, or a manufacturer and photograph it. Aside from that, all I can say is you have a patch machine on a treadle stand.
  12. Here you go: https://d28lcup14p4e72.cloudfront.net/197085/3767937/SingerModel29UFAManual.pdf
  13. I would advise you to join the forum (it's free), then post this ad in our Marketplace sub-forum, under the sewing equipment > Used section. You will get more replies and they won't need to be approved before being unhidden. PS: Either way, please include your location! We have an international user base.
  14. You have a photo of the back side. You'll get better responses from a frontal view of the head, preferably a close up of the head portion.
  15. Twenty ounces of Herman Oak carved, dyed and finished is probably on the hard density end, just not the hardest. What I consider medium density would be apron suede, or biker's chap sides, or perhaps saddlebag leather. I have had some bridle leather that was very easy to sew, while other cuts were tougher. Sometimes there are remnants of rawhide along the backbones on sides and double bends. Rawhide itself has a hard density. Garment leather has a soft density. The real test of density has to be determined by testing a sewing machine with the largest size thread and needle combination it can handle. If the foot pressure spring can't hold down the leather as the needle and thread come up out of the top side, or if the knots can't be pulled inside the layers and completely hidden on both sides, it is insufficient for that kind of sewing and the density of the leather. I hope this explanation helps a little. Important facts: There is a HUGE difference in the foot pressure to hold down between 5/16 and 3/8 inches of veg-tan leather versus 8 to 10 ounces of the same type of leather. There is a big difference in the amount of top tensioner spring tension needed to pull knots up inside 24 ounces vs 10 ounces with thread sizes 138 and up. For a given machine to happily sew 20+ ounces of veg-tan with #207, or #277 bonded thread, it must have really strong springs and very beefy crank shafts, take-up lever and bearings on load bearing parts. In order to penetrate 20+ ounces of veg-tan leather will also require a very high motor to machine pulley ratio, possibly involving a speed reducer between the motor and balance wheel. The feeling I get from your inquiry is that you intend to sew finished, medium hard to hard density leather stacks easily reaching and probably exceeding 20 ounces. This is the high end of the typical sewing capacity of upholstery grade machines. They are not built with such usage in mind. Upholstery leather is relatively soft at the thicknesses usually encountered in making seat and sofa covers, or carrying bags. I therefore recommend that you take a serious look at the Cowboy CB3200, as it won't be over-stressed sewing 24 ounces of veg-tan with #277 thread, using a #25 leather point needle. This thread is a good match for 3/8 inch of leather, having 44 pounds of breaking strength per locked stitch. If you end up having to sew jobs under about 6 - 8 ounces, search for a used upholstery grade walking foot machine. Upholstery shops often sell off old walking foot machines when the buy new ones, or downsize. These machines can sew from a few ounces to almost 3/8 of an inch, but only with up to #138 bonded thread, which only has 22 pounds test. I wrote an extensive article, pinned near the top of this forum, describing the type of sewing machine you need to sew leather. It makes a good read and may help you choose a most suitable machine. Note, we have a section here called the Marketplace, which has a section where people can sell their used, or rebuilt sewing machines to other members. You should peruse that section to see if anybody in your area of the World might have a suitable machine for sale at a price you can afford.
  16. I have a Singer 42-5 in my (now closed) leather shop. I use it to sew chaps and heavy upholstery, like motorcycle seats. I actually bought a handful of bobbins from somebody in Australia. I forget who. I am able to fit exactly 5/16 inch under the feet. Not one iota more. It feeds very reliably and has sharp teeth on the feed dog. I also got a good supply of authentic Singer leather point needles for and with the machine (System 88?). Those needles are now irreplaceable. Anybody with a 42-5 who doesn't have the proper needles may have to lower the needle bar to use System 135x16, which will reduce the maximum sewing thickness to 1/4 inch.
  17. You may be right. It's been a year since I changed pulleys on a mounted motor. Let's just say "a new v-belt to mach the different pulley."
  18. Clutch motors are easy to tweak via a bolt on the front left, in front ot eh output axle. Backing it out gives more slack before she engages. Then you can adjust the spring on the right end of the control lever to push it up more or less. Of course, the position of the foot pedal can be adjusted to suit your foot or shoe profile. Finally, a very small motor pulley will slow it way down. I recommend a 50mm or smaller machine pulley and a longer type 3L belt to match.
  19. I'd say it is very similar to a Consew 206RB-5. The bobbin is on the left end, accessed by sliding the bobbin access cover plate to the left. It uses M style bobbins like the 206 and has the same needles and presser feet. One difference is that the Fabricator is optimized for sewing canvas, vinyl and Sunbrella, not leather. The maximum thickness is about 1/8 inch less than the Consew 206.
  20. Pay no attention to the man behind the curtain... The motor has been there for about 10 years. The guy I bought it from attached the motor 5 years before I bought it. I can tell you that the motor is a 1.5 amp model and it won't start the machine by itself unless the hand wheel is disengaged by the bobbin winder friction disk. I stopped trying to use it a few years ago but left in attached for shits and giggles. Now, I either hand wheel or treadle it. You should see the motor on my Adler 30-7 patcher! 1/2 horsepower clutch motor running through a speed reducer. I love to hear machines going ta-pocketa-pocketa
  21. Oy Vey! That's one hell of a non answer. See if there are any social media user groups for Robin Industry. Maybe somebody somewhere owns these machines and can actually give accurate information.
  22. I don't mean to discourage potential buyers of spring foot machines, but I used to own a Singer 132k6 and currently have a 42-5. They work great is the top grain isn't slick. The top foot needs to dig into the top and follow it back with the bottom feed dog. When the dog reaches the back of its travel and drops down, the spring foot springs forward, just like Daylight Saving Time! BUT; there's always a but... I learned that if the material is slick on top, the spring foot just slides uselessly on the top and fights the feed dog's action. The 132k6 turned out to be a huge disappointment to me for sewing polished surfaces, like stamped and polished belts and holsters. The stitch length varied wildly as the foot slipped over the top. TBT, the Singer 132k6 was marketed as a buffing wheel sewing machine and there was an attachment that moved stacks of round cloth in a circle and away from the needle as it sewed arcs. That's why they have a long 1/2 inch maximum stitch length and 1/2 inch clearance under the feet.
  23. A close-up look at the head shows that it uses standard Singer 111 compound feed walking foot machine feet. They are sold everywhere industrial sewing machines are sold. The same feet are used on Consew, Juki and dozens of other brands that are based on the Singer 111w155. Note: This machine doesn't use the feet from the smaller portable Sailrite machines. Those are only dual, top/bottom feed machines that have specialized feet with teeth on the bottom.
  24. If you are asking if this machine can use external spools for the bottom thread, the answer is NO.
  25. Not only have they not answered you; they haven't answered my email or Facebook Messenger questions either. Methinks they may be (temporarily?) closed for business.
