Double that! I seem to have a habit of collecting books, magazines, patterns, etc. I'm running out of space so try to scan stuff and put it on my computer. But I keep getting further behind. I did manage to scan 2 shelves 4 ft long each, but they are filled up again!
I agree with NoName. There are lots of resources from a lot of people through the ages. There are multiple ways of doing things, some better for certain cases than others. What works for some doesn't work for others. Here on LW we see many opinions of how to do things the best way. Opinions of quality of tools and leather ... All these opinions help form the way we do our work, just the same as researching and studying from various books by various authors. AS and many others have advanced our arts and capabilities and should be given due credit for the work, skills, and foresight. Same as we appreciate the work of many masters that are or have been part of this forum, one of the best forums and resources worldwide. Learn what you can from others and apply it to improving your skills. I spent 19 years as an instructor in a technical school. The best educated and talented people are those that research and learn the "building blocks" and learn to apply them in their work. "Burning" books does not accomplish this. Keep learning through all the resources we have at our disposal. We have so much available to us now versus even 10 years ago. CTG
Depends a lot on your presser foot pressure. The tighter it is turned down, the more likely it will leave a mark. Damp leather is almost certain to leave a mark. These statements apply to all machines. 2700 is a good machine, but you have to help it punch through 2 layers 8 oz leather when starting at low speed. CTG
Nice to have information compiled into a summarized form. Most appreciated by many here I suspect. One thing that would be nice to add is a link back to the original posts so people can go back and see the associated comments if they wish. Sometimes I glean info from those comments that is usefull for me, especially where there is more than one way to do things. Keep it up. CTG
Cobra Class 17 Vs. Consew 206Rb
Northmount replied to sierrastarr's topic in Leather Sewing Machines
It did come with their standard servo motor. So if you are going to use it for 1/4" plus leather with #24 needle, you need to have it modified, hopefully by the seller. Up to you to describe how you are using it and to negotiate the addition of a speed reducer. If you are using it with a couple layers of 4 oz leather and smaller needle, you will be okay. CTG -
My Techsew 2700 is working well for me. My only complaint is with 2 layers of 8 oz leather, to get enough starting torque, as soon as the needle punches through, it is going a little too fast for me. I'm changing to a servo with gear reduction to eliminate that problem, and putting the current servo on my singer flat bed, replacing the clutch motor that dislikes me! See if you can get a speed reducer pulley set put on it if you are going to use it with 1/4" of leather. CTG -
Do a google search for train silhouette and pick graphics. http://www.google.ca/search?q=train+silhouette&hl=en&client=safari&tbo=d&source=lnms&tbm=isch&ei=XUejT_fVKIui8ASKz6RA&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CF4Q_AUoAQ&biw=1024&bih=644 Some interesting ones came up that you could adapt. CTG
Oxalic acid might lighten the leather. You can oil lightly with Olive OIl to darken it slightly. You can leave them out in the sun to darken normaly. There are threads here about oiling and the results, as well as sun tanning. Neatsfoot Oil will darken more. I have some real Neatsfoot OIl that is > 50 years old, it sure darkens leather a lot! You have to experiment in a place not normally visible, like under the seat where the edges are turned under and stapled. CTG
Businesses, politicians, governments, etc. look at one letter or email being the opinion of anywhere from 50 to 200 or more people. The rest of us are too lazy or reticent to say anything, even though we should. I guess it says something about why the squeaky wheel gets greased. So you have a lot of "unvoiced" thank yous. Keep feeding us Chancey. CTG
Some post here recently said oil paint peals when the leather is flexed. Do a search, there is lots of info already posted. CTG
Cobra Class 3 Servo Motor Code E6
Northmount replied to Leatherman87's topic in Leather Sewing Machines
Try this thread Codes Model of the servo may be different than yours, so check closely before you get too excited! CTG -
I know this is a five year old thread, but would be interested to know how well these dies have worked for you. And if you have any other new info to add. Regards, CTG
Generally one coat is enough. Only on very porous stuff should you use more than one coat. One porous material, if it has lost all it's shine as it dries, you can go over it again. If you keep the glue brush in a closed container with a quarter inch of solvent in it, the brush doesn't go hard. Take it out when ready to use and clean by wire brushing it from base of bristles to the tip. Sometimes might have to swish it around in some more solvent, then brush it again. I have used an ordinary 1" wide natural bristle paint brush for years this way. Wider brushes of course cover larger areas faster. CTG
Looking For Advice On First Machine
Northmount replied to SeventhSon's topic in Leather Sewing Machines
There are a number of threads about it here. Do a search and you will find them. One makes a comment about needing three arms to use it. CTG -
A piece of MDF works well too. All one piece, don't need to mount anything else to it. CTG
Looks really great! Is there a metal tool box as the base? Now keep it away from the other tool boxes to keep it from getting all dinged up, that's what would happen around here. CTG
Just be aware that the wetter the leather is, the easier it is to stretch.
So, My Techsew 2700 Has Been Shipped
Northmount replied to Phatdaddy's topic in Leather Sewing Machines
Congratulations. You will enjoy it much more than the Tipmann Boss you were thinking of before. My 2700 is doing a great job. Get someone to help you lift the head when you assemble it so you don't lose your balance. Set the table height you want before you put the head on it. As I indicated in your previous thread, I had to set the table down to just clear my knees to avoid problems with my old shoulders and neck. If you alredy know a comfortable working height for a desk or counter top when sitting, you will want to get the cylinder arm near the same height. Lots of good advice above about being careful with making adjustments, especially being able to return to original settings. You can file a mark at 12 o'clock on the tension knob so you know the starting point to measure 1/4, 1/2 turns etc. Coloured fingernail polish, white-out, paint, etc. can be used to mark it instead of a file, but the file mark doesn't wear off. CTG -
Some of the leather probably stretched while wet and pulling it around to turn inside out. Then it can't shrink back to flat anymore. Also dry slowly or stretched over a form to reduce distortion from drying. You may be able to smooth some of it by burnishing by hand or with a glass plate burnisher while drying, possibly several times as it dries slowly. I'm fairly sure most of the problem was it was stretched while wet. Minimize how wet you get the leather. The wetter it is, the more shrinkage you will see as it dries. CTG
Why not try a few things on some scrap and see what it turns out like? Spirit based dyes often penetrate the finish, not deep into the leather, but at least into the finish. I've purposely dyed over a finish to stop the leather wicking the dye beyond where it is supposed to be. Then applied another coat or two of the finish. Worth a little experimentation to see what the best recovery method is. CTG
There are tons of info on thread sizes, types and application here. Do a search or two. Take a look at the pdf from this thread Info Also this chart Toledo posted previously by Wiz. CTG The T had nothing to do with fire or outdoor use. You were reading a description of the particular suppliers thread that just happened to have a T size listed.
