Northmount
Moderator
  1. Don't need a bandsaw, any fine toothed saw will work, even a hacksaw. The coarser the teeth, the rougher the cut. Then you'll spend more time sanding the edges. Can use a coping saw if you want any fancy curves. Low cost if you don't have one already. CTG
  2. I missed seeing this post earlier. Welcome aboard. There are a few Albertans here. Good to see you putting your inheritance to work! Where are you located? CTG
  3. control 0 (zero on the number pad) will take you to the browser's normal zoom, 100% I think. I'm on an iPad at the moment so can't try it. CTG
  4. I was looking for more info as well for making dies. There is a little info in this thread, but he never followed up with the results. Dies CTG
  5. Tandy has lesson plans that you could review to see if they are useful for what you want to do. They are free download. Lesson Plans CTG
  6. They are still there. Have you installed Adblock software? If so, you need to allow ads from this site. CTG
  7. For short runs, you can use shorter length of thread, just make sure you have some extra so you don't have to splice more in for the last 2 stitches. For long runs, always go with the 2 arm lengths. Longer than that is self defeating. More snarls, can't do the initial snug-up in one pull, etc. CTG
  8. The arm on the motor usually has 2 or 3 holes in it for the foot pedal connection. Make sure it is in the hole furthest from the shaft it pivots on so it has the longest arc to travel through. CTG
  9. The Canon Pro 9000 Mark II inkjet printer will print on up to 11" x 17" on flat board, etc. Has a special front feed for flat stock, no curves in the paper path. It doesn't cost a fortune like others, yet will also do real photo quality as well if you like to do that kind of work too. I need to try it on leather one of these days. Have been thinking about it, just always busy doing something else. CTG
  10. Techsew servos come with one. But I see a number of requests in the past months.
  11. There is a manual in this post servo Item 2 in the manual tells how to reset direction. To others out there, don't mess around with the buttons if you don't have the instructions for them. Just makes trouble for yourself. CTG
  12. Do a search for John Barton. He has quite a few posts plus a website. Also has a pattern to download. CTG
  13. Look at a tire/tube repair kit. If you don't have a lot to do, the small tube might do what you want. Otherwise a autoparts jobber will have larger sizes. The is also a yellow rubber cement that is used to glue rubber weather stripping to car bodies. Might take a little experimentation to find the right combination for your purpose. A lot depends on what type of forces will be pulling it apart. And yes, you really need to rough up the surface. Looks like your roughing is good. In the old days, we used heat to vulcanize tube patches to the innertube. There is a barges rubber cement that Tandy sells. It's not the temporary stationery type. I had to cut it apart ... Was supposed to be temporary so I could easily remove it. CTG
  14. Look at this post and scroll down to rickybobby and to Bruce's comments. http://leatherworker.net/forum/index.php?showtopic=36751&st=0&p=227224&hl=+oblong%20+punch&fromsearch=1entry227224 Need proper board to punch against, solid support, and heavy enough mallet. CTG
  15. As mentioned above, use rubber cement, but not Barge rubber cement. It is permanent. Ask me how I know! Use LePages or similar rubber cement from a stationery store. It removes easier, and you can also rub residue off. CTG
  16. See this post http://leatherworker.net/forum/index.php?showtopic=39829&st=0&p=247582&hl=+sewpro%20+servo&fromsearch=1entry247582 This servo has a potentiometer instead of digital control. Just bought one from Toledo for $165 plus shipping. 300 W, 900 RPM, 3:1 gear reduction. I could still use a little more speed reduction so will be making another modification to get there. CTG
  17. Try Toledo http://www.tolindsewmach.com/thread.html sometimes has other thread colors. CTG
  18. Many of these questions have been covered in posts over the past couple months, so use search to help find them. I'm no expert (x is an unknown quantity, spurt is a drip under pressure) but can help a little. - when starting to stitch a project, do I start ahead a bit, backstitch first, then forward over and then continue around? Start 2 or 3 stitches in from where you want to start, backstitch back to your starting point then forward and keep going. At the end, back stitch 2 or 3 stitches. I find it easier to keep needle and hole aligned by stopping with the needle down, then pulling the reverse lever down. Tie off the threads after. There are lots of posts about how to tie off, use super glue, burn the ends, etc. When starting out, always make sure you hold the threads tight until you have gone a couple stitches. - when I get back to the start do I stop at the "peak" of my initial back stitch and then back stitch a bit to finish off? Lots of choice here. Can start with no backstitch, make sure stitch is tight when you come back around to it, stitch over top, then a backstitch. Or no back stitches, but tighten and tie off the threads, especially if you can hide the tails between layers. Should be able to do it so you can't see the begin/end. I'm sure there are other options too, but I like to see no doubled up stitching. No beginning, no end! - the 2700 has a relatively small bobbin(imo), especially with 207 below. Are you limited to stitching the distance the bobbin will get you or is there a tidy way to stop and start with a full bobbin? My 2700 won't even feed 207 thread through the bobbin. Use a smaller diameter thread on the bottom. I did manage to replace the bobbin without losing the top once. Not easy to do. I took the article out from under the presser foot and didn't cut the top thread. I pulled stitches back to give me a couple inch tail on the bottom, pulled the top thread back through the needle and past the top tension disks, basically to the spool, then placed the needle in the next hole, picked up the bottom thread, and carried on. Then tied the bottom thread after. Was able to hide the note and tails. Not nice running out the bobbin part way through a long stitch line. You may have to hand wheel the machine to be able to stay in the original holes. - is it cheating to hand walk around corners or is that considered common practice? To me, there is no other way to start and stop exactly where you want to, and to be able to navigate tighter curves and corners. You do what is necessary to get the appearance and quality that you want in your finished product. A number of older machines had a hand crank pulley and later someone added a motor. The best of both worlds! Just don't whack yourself! - With my machine I got regular needles, is there a huge difference in the leatherpoint/tri needles? Do they have a noticeably easier time "cutting" through leather than the regular needles? (135x17) You may get a nicer bottom side stitch. A #24 needle through 1/4" of leather takes effort, regardless of the type of point. But dull needle is worse. On my little Singer flatbed 20-33, a leather point needle improves both stitch quality and bottom side appearance. Lubricated thread makes a big difference. - Is there a resource where these newbie questions are all laid out? The search function at the top of the page is your best friend. You'll soon get to know which posters have the best answers and most helpful information for a wide variety of topics. For sewing and machines, Sewmun, Art, 50 years leather, Wizcrafts, Cobra Steve and several others. Make a few small useful items, like protective knife sheaths for your leather knives, simple drawstring purse, and other things you can use around home. Helps to see your own progress, and to have made a few items you are going to use. At the same time you can experiment with fabrication techniques, carving and tooling, finishes, antiques, etc. Good luck, keep at it. CTG
  19. And be aware that Apple's iStuff doesn't support Flash. To work around that, need to have your page detect the browser type (Safari) and use an alternate scheme. CTG
  20. The confusion started with neither machine being identified, so my comment was just to ensure that it was clear the 2700 was a walking foot type. No offense intended.
  21. Dimensional specs for most phones are available on the web on the OEMs site. Cut and carve a chunk of wood to the same or slightly larger dimensions to check fit if you don't have access to the phone or are wet forming. If wet forming, add at least 1/16" to the dimensions, and split the block in half lengthwise. Use a skewer or such to spread the halves a little. The when it's dry, you can pull the skewer out, and no big fight to get the block out! CTG
  22. The 2700 does have a walking foot. There are videos on YouTube showing its operation and threading. Take a look see! I would ask for either a gear reduction servo or a speed reducer pulley set if you are going to sew 1/4 leather, else you will have to hand wheel most starts, especially starting off with a back-stitch. CTG
  23. A clutch motor runs at 1750 RPM, constant speed. When you want to go slow, you have to feather the clutch. Sometimes, either you shift your foot position very slightly or the clutch grabs, and you're away to the races, lost control and not able to keep up with the machine, so the stitches aren't where you want them. Maybe even wrecked the piece you have spent hours on. So you wind up having to hand wheel the machine for all but longer runs of straight stitching. If you are going to sew 1/4" leather, do yourself a favor and get a gear reduction servo from Toledo, Bob Kovar. You need torque to punch through the leather, and slow speed to control your stitch placement. A larger pulley on your machine would help too. The biggest difference I see speed wise between the smaller machines versus big harness stichers, both using the same gear reduction servo is the harness stitcher has a much larger pulley. That gets your speed down even further and much greater torque to punch through the leather. If you have no experience with sewing machines sewing leather, I would recommend you find a shop where you can at least observe a machine or two in action. If they will let you try them out, so much the better. Maybe they will be kind enough to give you a little instruction too. Electric motors need a little speed to be able to develop adequate torque. Even with a servo, at its lowest speed, its torque is reduced compared to a hundred RPM higher. Motor speed and torque need to be matched to the application. There are trade offs in both directions. You need to research and pick the best for you. CTG
  24. Nice! The only critique I have is to scale the horseshoe and head down just a little so it doesn't run over the fold. I just did the same horse head a couple times recently. The first for practice, the next on the inside of a leather binder. After I did the first one, I went out to a ranch and photographed my grand daughter with several horses. Made sure to get a few shots of the same profile as the pattern. Then fixed the mane, fore lock between the ears, and the nostril. My practice run nostril was too high, too far above the upper lip. I guess the one thing I learned is to look at the real thing or some good photos, then make sure my pattern (especially after it is traced on to the leather) has the right proportions. Keep up the good work. CTG
  25. Double that! I seem to have a habit of collecting books, magazines, patterns, etc. I'm running out of space so try to scan stuff and put it on my computer. But I keep getting further behind. I did manage to scan 2 shelves 4 ft long each, but they are filled up again!
