Archery Arm Guard - Pattern & Instructions (*pdf File)
Northmount replied to Sherkhan1962's topic in Leatherwork Conversation
It seem that many new members fail to bother to check older parts of a thread. Well here it is. -
Buckskin Leather also has stores in Calgary and Edmonton, Alberta
Singer Industrial Sewing Machine Screws
Northmount replied to shoepatcher's topic in Leather Sewing Machines
the only link that doesn't work is Dixiesewing....you can try searching archive.org Gregg's PDF downloads fine for me. Tested other links too. they are okay. -
Hobbyist warehouse contents for sale
Northmount replied to joea's topic in Businesses & Estate Sales
We have both hobbyists and professionals here. Some hobbyists would pickup some of the larger machines like clicker presses if they are close by and have the space and utilities. -
@Samalan Here is your original post. It was down a few pages in your history. It was originally posted in a for sale forum. I was weeding out a number of expired posts and realized, this doesn't belong here, so moved it to Show Off where I thought it should be. So it wasn't taken down. There has to be a good reason to take down posts (really, we hide them). Good content is not hidden.
To whoever was visiting as a guest and reporting that this item is sold: Please note that when items are marked as sold, the thread is locked and moved / archived in old/sold. Pay attention to the location of the thread you are looking at ... Home Marketplace Old/Sold Landis 25 - Landis 5 in 1
- 6 replies
- landis model 25
- landis
(and 2 more)
Perhaps you could provide a link for that post?
Just after posting my comment a reply in another thread came up. https://leatherworker.net/forum/topic/132896-fenda-leather-splitter-restoring-help/#comment-791957 This is an example of finding information in a post that was archived in Old/Sold with lots of photos that were 3rd party hosted, that we copied and saved the photos here. If photos are resized to 800 pixels in the longest dimension, you can post over 100 files without hitting the wall. And you can post more in a reply. -
Please don't use 3rd party photos. Links get broken due to changes by the 3rd party hosts or by the owner moving or deleting files. I know that this is unlikely in this case because as soon as items are sold, or age out at 60 days, the thread is archived in old/sold and it won't make much difference. -
Resize your photos. 800 pixels in the longest dimension is quite adequate. Smart phones can't display high resolutions even though the camera can capture the high resolution scene. If your files are too large to post here due to file size restrictions, you need to resize your files to fit. Follow this link for some helps and suggestions. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 There are lots of Apps, software, and online tools available on the web, or even built into your device to enable you to reduce your file sizes. 800 pixels in the longest dimension is quite adequate. Smart phone screens and many monitors don't display high res files in high resolution. People that live on the fringes of the internet appreciate smaller file sizes and high res photos may take from 10 minutes to hours to download. -
The IP address resolves to tor-exit-2 Stockholm, Stockholm, 100 05, Sweden Assuming he's not using a VPN to some other location. (Virtual Private Network)
spring flowers and good food
Northmount replied to chuck123wapati's topic in All About Us and Off Topic
My furnace started acting up a couple weeks ago while we were away for a couple days. I can remotely monitor our house and could see that the thermostat was calling for heat, but none being delivered. I have a separate heating system for our basement (glycol boiler and perimeter baseboard heating loop) so I just turned up the basement thermostat. When I get home, I find that the pressure differential switch that detects whether the draft is adequate or not was acting up. It had water accumulating on one side so couldn't provide a correct signal to light up the furnace. After fussing with it several times, I decided it was time to find a supplier for that switch. Finally found one and placed the order. 5 days delivery time. Continued to have to clear the water out of the sensing tubes for a couple days. The guess what? It starts working correctly again. Now I have a spare switch. Decided it is a good idea to keep the spare as insurance. It's been working just fine for several days now. The real problem is poor design. The switch is mounted low, below the the pressure sensing lines. So condensate (water) from the wet exhaust gas builds up over time and offsets the actual pressure differential. Had troubles with it when we first had the high efficiency condensing furnace installed about 20 years ago. Pointed out the problem to the installer/supplier and the "Maytag Man" wouldn't do anything about it. So over time, condensate builds up, and the problem re-occurs every so often. But not for the past 5 or 10 years. So I should move the switch to a location higher than the pressure taps so any condensate drains back to the source. May I'll get around to it some day! But I have a spare switch that should keep it at bay for ... -
Please read the marketplace rules and conform. You must provide information or restrictions on shipping, and photos when possible. Failure to conform may result in your ad being blocked. See the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/
Three Used Auto-Soler Machines for Sale (Cincinnati)
Northmount replied to kevin-Cincy's topic in Old/Sold
Please read the marketplace rules and conform. You must provide condition of equipment, any information or restrictions on shipping, and photos when possible. Failure to conform may result in your ad being blocked. See the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/ -
Moved your post to Sewing Leather
iKonix Cylinder-Bed Lockstitch Sewing Machine - KS-335A
Northmount replied to Nanamagic's topic in Leather Sewing Machines
In the future, only place items for sale in the marketplace. That will avoid confusion. -
Cobra class 14 splitter
Northmount replied to BurntLeatherCo's topic in New and Refurbished to Like New
You need to state shipping info. Will you ship, where to, who pays for shipping, etc. See the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/ -
I moved your post to Leather Sewing Machines. You'll get more help here. Help wanted is more for hiring someone to do a job. Like the classifieds in a newspaper. Help wanted also requires all posts to be approved by a moderator.
New member here looking for direction
Northmount replied to Tommy1wide2high's topic in Leather Sewing Machines
Google is still a good search to use. Use site: leatherworker.net 132k6 This restricts the search to leatherworker. Add whatever search parameters you want to the search string. Google has larger servers, faster and better indexed.- 5 replies
- 132k6
- owners manual
(and 1 more)
kingsley machine Kingsley Hot Foil Stamp Machines
Northmount replied to Chris Wronski's topic in Old/Sold
Chances are your files are too large. Resize to 800 pixels in the longest dimension. If your files are too large to post here due to file size restrictions, you need to resize your files to fit. Please use jpg or png format files as they load automatically when the thread is opened. Follow this link for some helps and suggestions. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171There are lots of Apps, software, and online tools available on the web, or even built into your device to enable you to reduce your file sizes. 800 pixels in the longest dimension is quite adequate. Smart phone screens and many monitors don't display high res files in high resolution. People that live on the fringes of the internet appreciate smaller file sizes and high res photos may take from 10 minutes to hours to download. -
Just adding SOLD as the next comment is all you need to do. Then a moderator picks it up and moves to old/sold and locks it so it can't be commented on further.
- 6 replies
- landis model 25
- landis
(and 2 more)
I moved your post to stamping
Two Landis 16 Sewing Machines, Landis Machine Co Eli
Northmount replied to BattleAx's topic in Old/Sold
For sale items should go in the marketplace. This is unusual to be posting for someone else. I'm moving it to the marketplace. See the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/
