Northmount
Moderator
  1. Please write up a little set of instructions and start a new thread in https://leatherworker.net/forum/forum/33-computer-help/ Name the thread something related to your brand of phone and directions for posting directly. It may be helpful for other brands and users too. Then I can clean up this thread and get it back on topic. Thanks for your help.
  2. I moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners since it is a finish for leather edges.
  3. I split this off an old topic since it really doesn't match up with that thread. Better to not mix topics in the same thread, especially old threads.
  4. Maybe, also maybe files were too large, but somehow missed telling you that. There was a major upgrade here a month or so ago and some things are still cropping up to be changed or clarified. Keeps us all on our toes!
  5. @Thadrick I moved your post to Gun Holsters, Rifle Slings and Knife Sheathes. It seems to be the best related forum.
  6. @eLeM 800 pixels in the longest dimension is quite adequate and recommended. Most devices members use don't display much higher resolution and it is a favor to users on the fringes of the internet that suffer from low download speeds.
  7. Nobody is sitting waiting for you to post a question and able to immediately answer you. You need to be patient. I have merged your 2 posts into one to reduce clutter.
  8. I moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
  9. Moved your post to Leather Sewing Machines
  10. I moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
  11. I moved your post to leather sewing machines. If you haven't looked at this thread, you really should.
  12. IP address shows Valenciennes, Hauts-de-France, 59300, France @el_pipou You should put your general location in your profile. It helps get info relative to your location.
  13. Tandy has these 2 prong strap hooks. https://tandyleather.ca/collections/buckles/products/2-prong-strap-hook-solid-brass. The single prong "Mechanics Buckle" I got from https://springfieldleather.com/products/buckle-mechanics
  14. Do a search for mechanics belt. It doesn't have any exposed metal parts the can damage fenders, etc. while working, leaning against the car to reach what you are working on. Some people also refer to them for use by people that are allergic to metal as the hook is not exposed, not against skin.
  15. I moved your post to Patterns and Templates. Of all the different forums, this seems to be the best fit.
  16. I moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
  17. I moved your post to Stamping
  18. I moved your post to Gun Holsters, Rifle Slings and Knife Sheathes
  19. I moved your post to leather sewing machines
  20. I moved your post to leather sewing machines
  21. Helps if you quote a part of the post or tag the user so they get a notification in case they don't have notifications setup correctly. @esheeran
  22. I did that for a 4" hole saw. When you get down to the base of the teeth and sharpen it, you are into soft material. The edge rolls over if you don't come down perfectly square, then have to take more material off and sharpen it again. I guess I should try heating and quenching it to harden the edge. Lots to heat to an even temperature before quenching.
  23. It works well. I will remove a number of post that distract from the intent of your post.
