Northmount
Moderator
  1. With very soft thin leathers, they are more a reference point. Same as if you were sewing cloth. So you have to, in general, keep watching and adjusting your feed to keep the edge stitching even. The guide won't push the soft leather over. For long straight runs, a long guide can help more than a short guide. CTG
  2. I think a video could be very useful. It could show what the various parts of a "typical" machine are, how the top thread is controlled, how the loop is formed under the feed dogs/ plate, how the hook comes around and grabs the loop to pull it over the bobbin, how the top thread is pulled back up, how to adjust the tension, how to start a stitch, how to back tack, how to turn corners, follow curves, etc. Comments could be made about timing, walking foot versus not, how to adjust presser foot pressure. For specific brand names threading, timing, and that sort of stuff, viewer should be referred to the machines manual. More could be added to following segments on using edge guides, a little about routine maintenance, oiling, etc. One of the first things in the video should be how to correctly install a new needle. Charts don't need to be in the video, but reference locations (urls) should be given. Some good and bad examples of sewing should be included. Wrong tension, wrong needle and thread size combination. We could start off with an outline, followed by a text write up with photos. That could be followed up using it as the basis for a script to do video segments. There are a number of photos in various posts that can be used for illustrative purposes, both in a text document, and later for video either as direct insertion or guide for action in the video. What do you think? Will it get support and input, enough to make it worthwhile, or a good idea that goes off the rails and never gets finished. Some of the vendors here have done nice shorts promoting their machines and showing how to thread. Would they be interested in formally supporting, or taking over the actual video production? CTG
  3. Take a look at this post. How to mix. I would start with the suggested amount. If it is not working, then mix it stronger and go again. I did some once about 4X this ratio, makes instantaneous visible change. You may need to treat the whole braid so it all looks the same after, not lighter only where treated. Good luck with the clean up, and don't shoot the dog, just the person that left the braid where the dog could get to it. CTG
  4. As long as you are using their product, re-purposing what they have sold, there isn't much they can do about it, even if they don't like it. The only caution I (not a lawyer) see is not to make something that defames the company. Heck, they probably want you to buy more so you can make more art! CTG
  5. Leather and Wood vol 2 has a magazine rack that might give you some ideas. Is available as an ebook from Tandy. CTG
  6. A really great piece of work. I'll never be that good, but I appreciate the beautiful work that you and others here do. I shouldn't have shown my wife the lizard. She loves lizards, so guess what? Now have to learn to make nice looking lizards! CTG
  7. Nice bit of research. Now "line" makes a little more sense to me. I've always had a selection of snaps, so just grabbed the one that looked the best for the article I was fixing or making. There are some other posts in the last couple months about setting snaps and how long the post should be so it doesn't bend over and collapse, making a crooked mess. Do a search, should be easy to find if you limit the search to a couple months. CTG
  8. On many machines, raising the foot releases the top tension, so raise it just enough to allow you to turn the leather following your curve. Raising too far will mess up the stitch appearance and position of the lock. CTG
  9. There are several photos in this thread. Edge guides CTG
  10. You can make a leather strop very easily when you want. There are posts here with instructions and how to use. Some people use cardboard, poster board, and even newspaper to strop knives. Probably takes a little longer than when using jewellers rouge. But the main idea is to polish the blade so all those little rough stirations are gone. CTG
  11. Needle in right? Top thread not threaded correctly, can't pull thread through so needle cuts thread as it goes down? Rats nest under plate? Follow the thread path to make sure nothing is hanging up. CTG
  12. Try Bob Kova,Toledo Industrial Sewing Machine Sales Ltd. 419-380-8540. He is another LW supporter. Provides bonded pre-lubricated thread in black, white, straw, light brown and dark brown. Thread (and good prices) CTG
  13. Try a heated box, hair dryer, heat lamp, just don't burn it to a crisp. Kitchen range ovens may not be able to set the temperature low enough. Do some searching here for how people are drying their projects. I have seen lots of posts. CTG
  14. There is a set of 3 booklets by Al Stohlman - "The Art of Making Leather Cases". They are available in print from a Tandy store books, or as ebook downloads at eBooks. There is also a booklet on Handsewing Leather by Al Stohlman. sewing leather And as mentioned, there is loads of info here. Use the advanced search feature at the top right of the page here. I suspect you are not interested in tooling yet, so these books are a good place to start learning what tools and techniques are needed, and some simple to advanced projects. When you are doing searches here, search for "wet forming" as well. Enjoy CTG
  15. Try Wikipedia, they have a good article. CTG
  16. There are some liners that are basically 3 pieces, the two ends, and a central piece that floats in slots in the end pieces. The central section is not glued or sewen to the wallet back. There is a pattern posted here that I noticed a while ago that could be adapted to the style of interior you want. Then it can open flat and fold without bunching up. You will need to search for it. I would say it came up within tha past month or 2. Try wallet pattern. CTG Edited: found it. Pattern
  17. There are lots of posts on vinegaroon under several spellings. Search for vinegar and you will be more successful. Lots of comments, lots of examples, lots of testing has been done by several posters here. CTG
  18. I'm not sewing biothane, but 2 different machines, if I get a rats nest on the bottom, I have to increase the top tension so it pulls the loop back up through the material. Works for me on leather and on canvass. CTG
  19. Sometimes hard to really tell where the knot actually is on thin stuff. Use white thread on one side and black thread on the other side. Then you can tell for sure. If your needle size is too large, the leather doesn't grab onto the thread, so makes it harder to adjust tension. CTG
  20. You can buy one, use it as a pattern to make more. If you still have the one that is too small, use it as a base pattern for the idea and arrangement, and modify to fit what you want. Note that for folded wallets, the liner is typically 3/8 to 1/2" shorter than the back so it can fold without bunching up. Don't sew or lace the interior to the back across the fold so there is room for it to move. Make some paper or light cardboard mockups, staple the pieces together to see if they fit the way you want them to. Staples are easy to pull out and redo parts that don't fit or meet your satisfaction. The interiors can be sewn on a home sewing machine since they are quite light weight. A leather point needle will help with stitch line and appearance. Keep the good side (exposed side) up when sewing. CTG
  21. Looks pretty fair. Top right test is scorched a little, so just need to turn the darkness down a little and I think you are on the right track. Should fill a niche where people want a design of some sort, but don't want to pay for the time it takes to carve and tool the leather. It is also a quick way to do logos for company promotional gifts and awards. Good luck. CTG
  22. The acid probably needs to be neutralized. A baking soda solution should work for that. After treating it with baking soda, I would rinse it off a couple times. Too much bs in the leather damages the leather. There are threads about using vinegaroon here followed by bs to get rid of the smell of the vinegar. One or two of the threads made that comment. Good to hear all the blood came out. CTG
  23. Tandy is in the business of selling their patterns. If you distribute their patterns on the web, you are infringing on their rights. If you make duplicates of their patterns and sell the duplicate patterns, you are infringing on their rights. "For the most part" if you copy a logo at a customer's request, the customer is responsible. But be cautious. I am familiar with a case several years ago where a welding shop made milk barn stanchions that were a copy of the dairy's existing stanchions that were patented. The patent owner sent a representative out to the welding shop (since they didn't get the sale). When they found that the welding shop was not selling stanchions, but making them under the customer's direction, the patent owner backed off and just said "Don't make any for sale". The patent owner did not go after the dairy and I don't know what they were told, but they didn't come asking for anymore to be built. It is really best to stay clear of the problem. The big companies have a lot deeper pockets than you do. Ask or have your client ask for permission, stating what it will be used for and how many will be made. Keep a copy of the permission statement. Even making a logo that looks similar and could easily be confused with a deep-pockets logo (or any copyrighted / patented item) for sale to someone else could take you down a road you don't want to go. CTG
  24. Strap cutter and mallet are quite cheap at Tandy. See what they have for scraps too. Hopefully there is one in your area. CTG
  25. Most motors with a knob for speed control have a potentiometer under the knob. That is a wire wound resistor with a metal wiper that rubs against the resistor wire, giving you a variable resistor. The speed control arm adjusts another potentiometer. All analog electronics, no digital stuff. No optical sensors. Usually good heavy duty stuff. CTG
