Northmount
Moderator
  1. Take a look at this thread: http://leatherworker.net/forum/index.php?showtopic=40290 CTG
  2. Are you logged in? I haven't had any such responses. CTG
  3. Like you did ... Option I missed is moving the pulley itself. So when the belt is straight down from the head pulley and not attached to the motor, does it hang in the middle of the slot, or against one side? If it hangs against the side, widening the slot like you are doing is the easiest thing to do. Then the motor pulley/ motor should be moved to align with the head pulley. CTG
  4. Some motors have the mounting bracket slotted where the table bolts go through. You should be able to get about 1/2" of adjustment there ... hopefully in the right direction. Some motor housings are like extruded aluminum, slots that have a recess for nuts inside the extrusion. If your motor is like this, then you can loosen up the mounting bracket attachments on the motor and slide them over a little. The last resort is to drill new holes in the table. CTG
  5. Something else that helps is Fiebings Liquid Saddle Soap. If I remember right, I used the saddle soap first, followed by the oxalic acid. CTG
  6. A piece of MDF (medium density fiber) board works well too. The surface is very flat, firm. Lasts longer than cardboard. Very sturdy and supports sharpening guide helping to keep it straight. Has become my preferred method instead of leather. CTG
  7. I'm no expert on splitter blades, but ... Since the blade is relatively thick, I would do a micro bevel until such time as it is getting too wide, then reshape the edge and apply a new micro bevel. Same as with many woodworking tools like planer, jointer, plane blades, etc. It's a lot quicker to touch up the micro bevel and to strop it than having to work the whole surface each time. CTG
  8. Depends on what the blade is. Swivel knife, maintain the full angle. Don't do a micro bevel on its edge. Regular knives, chisels, etc. work on the micro bevel. After a long period of use or damage due to improper usage, then the edge may need to be ground back and reshaped. Then a micro bevel done on the edge. There are a lot of posts on sharpening different types of knives. Do a search for the type you are sharpening. CTG
  9. I have used oxalic acid to reduce the smell to a much more tolerable level. Then air out with good circulation around it for a couple days. By the time I was finished tooling and applied a finish, the smell was gone. Don't soak it too much or you will be waiting a long time for it to dry back to a proper cased working level. CTG
  10. You could put a divider in the bag, attached to the gussets, and place the pockets on the divider. CTG
  11. I'd like to see the leather inside. Did you do any pockets, or just line it? The combo looks great. CTG
  12. The roughness inside the collar is likely due to age and sweat and oil from your skin, breaking down the leather itself. Most leather coats and jackets show degradation in the collar after a few years of wear. One fellow told me to always wear a scarf of some sort to protect the leather in the collar. CTG
  13. 0.9 mm is very thin, between 2 and 3 oz. I would go heavier IMO, maybe around 6 oz (2.4 mm). There is some info and a conversion chart here. Leather info 1 oz is 1/64 inch or 0.4 mm. For the people stuck in British units, 1 inch = 25.4 mm. Time to get familiar with metric units and conversions for the basics so you don't get ripped off and can figure out what you are dealing with. CTG
  14. Do a search for the items credit card magnet There are 3 threads with info that might help you decide what to do. CTG
  15. There is a post somewhere here with pictures and description building a rawhide mallet. Try searching for it. Even tells where to get rawhide ... Can use dog chews. CTG
  16. The tongue end is too long. It absorbs a bit of moisture so is being wet formed while wearing. It looks like the shirt cuff, or the way he wears it pushes it out of alignment with the rest of the strap. Cut shorter, and maybe an additional keeper will help keep the tongue in alignment with the rest while being worn. CTG
  17. Nice to note the difference in black and white thread. Thanks. Smaller needles of course make a smaller hole, however in his test he was sewing through exisiting holes punched by a larger needle. So it is not an accurate test. But it does point out that the top tension was really not adequate. I sure like pre-lubricated thread. Bob Kovar at Toledo has a good stock, color and size selection. CTG
  18. I can't resist it. When I saw the topic line a couple days ago, I wanted to say "don't cut yourself". CTG
  19. You need to substantially increase the top tension. With large hole and smaller needle, the knot should have moved higher in the hole, since it wouldn't require as much top tension to place it halfway through. For testing purposes, I like to use black on one side and white thread on the other so I can see where the knot is much more easily. So boost your top tension. CTG
  20. Are you lifting the presser foot as you make turns or to reposition the leather. Some machines release the top tension if the presser foot is raised very far. I'm not using a Cobra, but my machine has caught me a few times until this action penetrated my thick skull. CTG
  21. Another recent post (for oil dripped stain on a saddle while sewing) said to cover with cornstarch and let sit for 3 or 4 days. I've heard this elsewhere so think it would now be my first try rather than water and soap, especially if there is any tooling involved. Do a search for oil stain saddle for the past 2 weeks and you will find it. CTG
  22. Also places that sell wigs. CTG
  23. That is fairly thick leather. The stem should protrude about 3 mm above the leather. Too short, not enough to flare/bead over to hold, too long and they tend to collapse crooked instead of beading over nicely. CTG
