Everything posted by Art
I can get on board with a lot of it, but I draw the line at the often used term "knife steel". There ain't no such animal: unless you allow any steel someone made a knife out of to reside in this "category". So many things are made of steel, that steel with out some definitive designation is just steel. Even if you go with only steels above the eutectic (say about .77C), only a very small percentage is used for knives. Any reasonable tool steel at close to the eutectic or above can make a darned respectable knife, if properly treated. The other consideration when selecting a steel is what the purpose of the knife will be. An knapped obsidian knife may possibly be one of the sharpest knives obtainable, but is kind of worthless if you want to chop or pry on something. Osborne has been using the same 1065 or so for as long as I can remember, and their knives are really first class (for the price and availability). I've seen a boat load of these (and own more than a few) that all act and react pretty much the same. Knives that can obtain at least HRc 55 or so will make a good knife although I like them a little harder. Every steel used for a knife is going to be a tradeoff, no one steel is good enough, cheap enough, and easy enough to work (including heat treatment), to make it an "industry standard" and become a or the "knife steel". Art
Use #8 or #9. Art
Don't know where you are, but the Weaver auction might be good for your hardware. That is a harness community up there and the machines will be appreciated. Art
I don't know that prices established at the Weaver auction constitutes anything but the price, there, on that day. I have seen used-up machines (still currently available) go for more than the new list price. A lot of their customers aren't generally dealing with the global reality, just the reality of that particular community. Then again, I've seen really great machines and tack and leather go for nothing. Kind of a crap shoot there, it can go either way. Art
Fill in your profile so we know from where thou art. Art
Good luck with it. Art
- 41 replies
- strap cutter
- strap cutting
- (and 2 more)
Give her a leather purse, give her some class; Take her out tonight, get a little .......wine and get drunk. Art
Call them again and again and again and again and again and again until the darned thing works right. If mine had that problem right out of the box, I'd pull the shafts and check them for straightness. If it doesn't work and it's Chinese, there's a good chance a bad part as opposed to a bad adjustment is the culprit. If you are close to them, take it back. If not, then you are the mechanic. Art
- 41 replies
- strap cutter
- strap cutting
- (and 2 more)
Could be any number of things. Bent bottom roller or knife shaft. Knives not all the same diameter. Where did you get it? Art
- 41 replies
- strap cutter
- strap cutting
- (and 2 more)
Hi Mike, You might want to adjust the depth of cut, or actually the bottom roller height. There is a black lever to the right of the cutting throat that should be all the way up. If that is not the case then put it all the way up and try again. If it is all the way up, you can adjust the eccentrics (like cams) on this lever (under the feed table) to give you a little more lift on the bottom roller. Art
- 41 replies
- strap cutter
- strap cutting
- (and 2 more)
Jane, Now putting aside a mountain of animosity between Jerry and I, it looks like he might have his act together now, and has recovered from some health problems that really got him down in the past. He has a portable machine he calls the 335 B BT Transportable which looks like son of Pfaff 335 and if it comes from where I think it does, will be a very good machine. I like his transportable/luggable setup for this machine if you have a limited space. Good strong motors too, shouldn't need the speed reducer. Art
Bonded Leather (Re-Engineered?, that's a new one) is not classified in a manner approaching the quality or handling of Bonded Whiskey. A leather "slurry" is applied (bonded) to a polyester or some other backing. This can (and has) been classified as Genuine Leather. It is generally put-up in rolls. Most of the automotive "leather" interiors are of this type. In a lot of instances I have seen, they put a tough, heavy polyester topcoat on it and often texture this topcoat. It would be almost impossible to get any kind of finish to penetrate or adhere to that topcoat. Art
A nicer man you will never meet, RIP Chuck and condolences to his family. Art
Which machine brand/model: Artisan vs Cobra
Art replied to Saddletramp307's topic in Leather Sewing Machines
First off, the Cobra Class 18 is a flat bed, at least the two that I have are. The Artisan is the better machine for bags, and works well for flat if you make a insert for it. Maybe Jerry can get you one. The BT version is interesting, but it ain't gonna be light, then again, it will work well from a desktop. Art -
A crop is generally used to "poke" rather than "swing". Crops generally have a very stiff shaft as opposed to a quirt which is generally used with a little velocity. Art
Looking for a leather competitions in the midwest.
Art replied to Trinity Whip Co's topic in Leatherwork Conversation
September 15 - 18, in Columbus Ohio, at the Crown Plaza I think. You have to be a member of one of the member guilds to compete. The IILG is an internet guild if there isn't one near you. This is about as big as leather competitions get with top leather artists as judges. Art -
For a riding crop, to be used with horses, I like something stiff, and the fiberglass works well. I use them primarily on horses that like to bite. When you are tightening up a saddle, sometimes the crafty buggers will try to bite you and a good still crop just stops them. You don't swing it at them, you just kind of poke them when they turn their head toward you, and you'll learn to do it right quick the first time one nips you. Now, for fetish apps, you can get get a couple of pieces out of a buggy whip, and they are pretty cheap from suppliers like Weaver and Bieler's. Don't know if you have a buggy crowd down your way, but that is where I would try first. Also they make different sizes of disciplinary canes that would work, and they are rather inexpensive (they can be outrageous too depending on where you buy). This topic is headed to the NSFW forum if it gets much more detailed. Art
Advice On Cobra Class 4 and Getting Another Machine For Lighter Stuff
Art replied to zckry's topic in Leather Sewing Machines
No, I haven't used 207 in the bobbin, but it shouldn't make a lot of difference other than tensions. If you are worried, have one of the dealers set one up in his shop and sew off a couple of yards of the kind of leather you do the most and send it to you. You should buy the machine set-up to sew the leather and thread you use. Art -
Yes 207 is ok, at least it is for me. I use 207 top and 138 bobbin but it shouldn't matter. Cobra says 207 os ok. Art -
The Highlead made Class 18 (0618) are very good machines that run and run. If you need a medium flatbed unison feed (triple feed) machine, you won't go too wrong with the Class 18. You'll have to get with Bob on the CB0618. Good Guy. Art -
My Language????, did I spell something incorrectly????. BTW, I have two 441 clones, and I clearly have as good a depth of knowledge of how the 441 works as you do. I was in this conversation before you were. You are trying to bully the wrong person. Art -
Those machines use 111 feet, and smooth feet are available, but I would suspect they are provided on the leather version of the 227R. Art -
The only thing I said was about altering the rate of the spring not about anything else which you incorrectly read into it. I have altered and made many springs in my day, I don't need to try it first, been there, done that and don't need suggestions from you. Art -
The illusive Secondary Bevel, what and why is it? The secondary bevel is another bevel on an edge that is at a greater angle of incidence than the primary bevel. Huh? Lets say you sharpen a tool edge to 25°, which as we know for an opposing bevel edge (bevel on each side) will be 12 1/2 degrees per side. This will be a pretty sharp edge and will cut leather well; but it is a delicate edge and will require a lot of care, stropping primarily, to maintain it, still not too much of a problem for leatherworking knives, but it will eventually wear out, no amount of stropping will bring it back to bleeding sharp because the edge isn't there anymore. This is the same for any edge, eventually it goes, and you have to put a new edge on the tool. For the same thickness of blade, the "ramp" from the body of the blade to the edge will be longer the less the angle if incidence; 25° has longer ramp than 30°. We can take the dull 25° edge and change the angle of incidence to 30° with very little removal of metal and still have a sharp edge that will have more metal behind it. Of course, if you keep adding 5° every time you sharpen, you will eventually approach the geometry of a cold chisel (not terribly sharp, but tough as nails). So what we do is use that 30° bevel (15° per side) and "ride" it back with subsequent sharpenings. You will have to remove a little more metal with each sharpening as you "ride" the edge back, the heel of your bevel will increase each time you sharpen the secondary, but a whole lot less than going back to the primary. Eventually it takes as much or more time to sharpen the secondary bevel as it would to just go back and sharpen the primary, or the secondary becomes in effect the primary (obliterating the original primary), and at this point you can add another (the "new" secondary) bevel at a higher angle, or drop back and sharpen at the original primary angle. The nice thing about the secondary bevel, is that oftimes it requires using only a fine and then extra-fine stones to attain the edge because most of the work has been done when the primary was established. This technique is used quite a bit when sharpening chisels and other working tools that may be sharpened a couple of times a day. They often are micro-beveled at a degree or two increase over the primary and another degree or two over the last secondary when a new edge is necessary. Other knives, especially head knives and other weird profiles are difficult to sharpen this way, but it can be done, although the increase of angle between the primary and secondary may have to be somewhat greater when hand sharpening. I don't use the primary/secondary system on head knives. I sharpen to a convex (teardrop) edge using a slack belt (although there isn't a lot of slack) and finish with leather or a sewn buff and .50 micron compound in the strop or the buff. Art
- sharpening
- knifemaking
(and 1 more)
I am referring to a spring in torsion or compression; and I stand by my statement. When you add a spring rubber to a spring, it "deadens" one of the coils and increases the spring rate which makes for a "firmer" ride. When you compress a spring with a screw, as the coils bind against each other, coils are effectively "removed" as one collapses against the next, and the spring rate increases. Art
