Everything posted by Andrew Chee
Hello all. I've been looking for a while for a flatbed attachment for my Pfaff 335. I saw a video from a company in France that made one but never was able to get one from them. I couldn't find a company here in the US that made one either. Recently I got into contact with a local machinist here in the San Francisco area about making some custom Consew 206RB needle plates (more on that in a separate post later) so I asked him if he could make a flatbed attachment for my machine. Here are the results. Andrew
Refurbished Adler 467... Is This My Best Bet?
Andrew Chee replied to Leslie Ryanne's topic in Leather Sewing Machines
That machine should suit your needs just fine. Adlers are nice machines. The speed reducer should give you plenty of torque for the thicker stuff. The only question is whether a flat bed machine will be suitable for bag making? If it is, then that machine will work just fine. Andrew- 5 replies
- first purchase
- walking foot for leather
- (and 2 more)
Trouble Peening Copper Rivets
Andrew Chee replied to Leslie Ryanne's topic in Hardware and Accessories
You should check out Douglas tools. They have a three piece setter for rivets. It comes with a setter, a Peener, and a domer. I don't like the all in one setter from Tandy because the setter part marks the leather. I'm waiting on my order for a setter from Tim Judd that does the same thing as the Douglas tools so we'll see how we'll they work. Andrew- 20 replies
- copper rivets
- peening
(and 1 more)
For long straight cuts you really can't beat a rolling craft knife. They're like a sharp pizza cutter. They don't pull the leather at all since they roll. As long as they're sharp, they'll cut pretty much anything. Andrew
Chicago Screws Instead Of Rivets?
Andrew Chee replied to humperdingle's topic in Hardware and Accessories
I use Chicago screws in some areas. Especially areas I might want to be removable like handles and straps. The onlyproblemmwith Chicago screws is that the shortest closed end ones are 1/4". If you want shorter then you have to get open end Chicago screws which look a little different. Andrew -
I know of a lady in San Francisco that teaches high end hand crafting of leather (think Hermes). I haven't taken lessons from her but hear good things. She has a full nine month course of instruction that costs $10k. She also has smaller classes. Is that what you're looking for? Andrew
Consew 206 Rb Keeps Popping The Clutch
Andrew Chee replied to ArtifactBags's topic in Leather Sewing Machines
Could it be that the spring tension of the safety clutch loosened? That might explain why the clutch disengages on heavier material (when the needle meets more resistance). Might be worth checking out. Andrew -
I bought my wife a Bernina home sewing machine. She had a cheapo Janome sewing machine before. I have to say that the Bernina (the lower end model) is awesome. Great control. good features. I use it to sew the cloth liners for my bags. Not a heavy duty machine but it sews great. Andrew
Chrome Tanned Leather Splitter
Andrew Chee replied to NewYorkerInSydney's topic in How Do I Do That?
How wide of a split do you want to do? Blade splitters won't split chrome tan very well since its pretty soft. The best splitters would be a band knife splitter but they're too expensive for your budget. One thing you can do is to use a bell knife skiver. You can run the leather through in several passes to get the whole piece split. Those can be found for under $1k. Andrew -
The finish on your bracelet is kind of a matte finish. I've seen braids that have a shinier finish. Is it a matter of the type of leather one uses? What type of leather did you use? Andrew
It's funny what people consider heavy duty in the regular world and what people consider heavy duty on this board. That kingmax machine is no lightweight sewing machine but for the purposes of this board it's only considered a medium weight machine. Folks on this board focus a lot on holsters and sheaths type of work and that would be considered super heavy duty to the rest of the world. Andrew
Can't really tell from the picture but if you can see the knot at the end (where your arrow points) then they simply sewed to the end, did one more stitch to go past the last hole and then backtacked. If you don't see the knot and this is not hand sewn then I have no idea. As for the logo, looks like it was hot stamped before they sewed. Andrew
For a rough comparison of machine thread to hand sewing linen thread, a four strand linen thread is roughly equivalent to a size 207 thread. Three strand is about a 138, and 69 is about a one strand so it's pretty thin. Way too thin for holsters and sheaths. For those, you need a size 207 and higher at least. I don't do holsters so I don't use stuff that thick. Don't know what machine you got exactly but if your machine was set up for 69 thread, I highly doubt it will handle 270 thread. Andrew
These look really nice. How are the awl blades secured to the hafts? Would you be interested in making awl blades to specific specifications? I'm thinking about somehow getting awl blades that will fit into a 441 clone sewing machine so the shafts would have to be a specific diameter and length. What's the ballpark price on your work? Andrew
Blade type splitters (such as the Landis as well as the Artisan and Cobra blade splitters) are less expensive. The Landis can split up to six inches. The Artisan and the Cobra can do 12-18 (forgot exactly). They will split leather nicely but only down to a certain thickness. The minimum thickness you can get down to with a blade splitter is probably 2oz. Any thinner than that, these splitters just don't have the precision to do reliably. These cost from about $400 - 1800 depending on model and condition. The powered splitters (band knife splitters) have a moving blade like a band saw. The basically come in two flavors. One with a powered top roller and one without. Some can do both (swap out the top roller for a bar). They will both split to sub 1oz thickness. The top roller models will be able to handle stiffer leather but will not be as precise on thinner materials. The ones with a top bar (no roller) will work better for super thin things but won't handle stiff veg tan as well. These splitters will be $5000 and up depending on model and condition. I wish I could have a band knife splitter.... Andrew
Check out kwokhing.com. You can get one for like $50 including shipping. Andrew
I make fishing rods as a hobby on the side. The problem with using leather on the grips and such is durability. For the wet conditions that the rods go through, a lot of leathers would not be appropriate since they are not water proof. You can't do embossed images on leather for rods because only vegetable tanned leathers work for embossing and tooling and veg tan leathers are not waterproof. You could add a waterproof coating but I don't think that would hold up to the wet conditions over time. I guess that's why people don't use much leather on rods. Andrew
Armor For Samsung Tv Commercial Update
Andrew Chee replied to Prince's topic in Historical Reenactment
Incredible work. Just out of curiosity (you don't have to answer this) but how much does a job like this earn you? Looks like an incredible amount of work. Andrew -
The doming tool is made by Judd Tools (www.juddtools.com). I purchased it directly from his website. Judd tool's email address seems to be down but I was able to email them directly via their Paypal email and did get a confirmation from them that they received the order and will process it in a week or so. Andrew
Same Thickness Of Thread On Both Sides
Andrew Chee replied to oisee's topic in Leatherwork Conversation
I'm not sure what size thread you are requesting but it could be that the thread is pushing the upper limit of what their machines are capable of sewing. In that case, using a lighter thread on the bottom lets them be able to use the heavier thread on top. With the correct machine though, there is no reason that you can't have the same thread on the top and bottom. The problem is probably because they don't have the heavier class of machines. Also bear in mind that the stitches on the bottom side will not look as nice as the stitches on the top. That's just a fact of machine stitching (unless you use a needle and awl machine). Andrew -
Ideas For Working In A Small Space!
Andrew Chee replied to Pennypower's topic in Leatherwork Conversation
Make it a little higher. Like 36". It'll help with your back not having to be bent over all the time. Andrew -
Difference Between Consew 206Rb-4 And 206Rb-5
Andrew Chee replied to sfmiaw's topic in Leather Sewing Machines
As far as feet and attachments are concerned, they should be the same. Andrew -
You can get the Douglas awl at Sheridan leather. Andrew
