Everything posted by Greystone
hello from Gainsville fl
nice looking shop but the left lean is killing me........needs a quarter turn,,,, db
Jason has some great skins and beautiful work and easy to deal with
congrats, IMHO great choice and you will not be disappointed, remember you control what's happening ,the machines do what we tell them, its we just need to know what to tell them sometimes ,,, lol ,,, david
IMHO similar to many , and a good choice, if it works for you and has no issues AWESOME,,db
A North fla welcome,,,,,, Gainsville Go Gators David
looks nice to me,,,imho the dead space lends to your marks visibility which and is what I would want and not overpowering/glaring who says it has to it need s to be right up to or filled to the boarder of you makers mark David
Yes working on,,, a plan ,,, input ,,,I'll host ,,or just stop by,, welcome Jason are you local ? David
might have a punch will ck in am
welcome and will pm for details David
Welcome from Gatornation happy to add my $0.02 similar interest in leather....my $0.02 way over priced though David
check your packaging its in one of the bags a plug end
Oiling A Cowboy Machine Model 227R
Greystone replied to debinarizona's topic in Leather Sewing Machines
if it moves and looks like it can be oiled on a regular basis it is as well as the marked points -
I LIKE!!!!!! very nice and colorful +++++ welcome David
not an expert about the machine but looks good ,, NICE buy if you are happy with your purchase price even with the servo motor consider adding a speed reducer, for leather and better slow speed power and control CONGRATS David
consider what a skin looks like laid out the last I bought at the widest point +- 13" 30cm and about 42" long grade 1 $300+
Help Choosing The Right Cylinder Machine
Greystone replied to Cmoore's topic in Leather Sewing Machines
make sure you get a speed reducer or a gear reduction motor $.02 -
pis or general condition,,,, sharp???
Techsew 5100 Problem , Speed Reducer Seizing?
Greystone replied to MadMorbius's topic in Leather Sewing Machines
Talk with your Dealer/sales rep, but you did buy a new machine,,work with and isolate the problem my $$.02 is ask for a new reducer to be sent over night,,if you feel/ sure its the issue First recheck the machine for ease of rotation and motor for running free no load isolate the problem ,, you should NEVER have to FIX a new part unless its a, ABSOLUTE need ,,,,,if so make it work,,,,,,,, but ask for the replacement part be sent as a priority and return the part in question cost of info.... free but still my $.02 Be fair to your self as your dollars have been spent but understand some new parts are defective and can be beyond dealer control David -
Gun Belt, Skipped Stitches And Back Looks Rough
Greystone replied to Greystone's topic in Sewing Leather
went up to a 24 needle and saw no difference then went up to a 25 and looks ok but a little large hole imho contact cement had 24 hrs drying outside inward,, row 1 with the 23 row 2 is with a 24 row 3 is the 25 front and back view might have it worked out David -
Welcome from Gainesville, Fl you found a great place to learn and make your ideas a reality David
Quick follow up Thanks Red Cent, Rayban first test sew, on the short cutoff strap looked "ok" pics seem to make look worse than it is rest of the pics show a inconsistency top and bottom as well as missed stitches so I'm not sure if top tension is the bug or bottom I rechecked things prior to sewing as I had switched feed dog and feet to do some heavy canvas repair, and had a stitch length variation, which was solved by another post with the same issue reset feed dog height and recheck all normal things threading machine clear thread path no dirt/dust general normal stuff just looking to shorten the fight/curve and get a list of fix and see what works will try re thread non factory way and move on with tension resets and recheck needle hook pick up thanks and will keep at till, I GET THE Proper STITCH I WANT to see on a finished product David more detail, 277 bonded nylon top and bottom #23 organ needle supplied with machine top tension and 2nd tension springs are lightly set if any at all just so they are not flopping around quick note leather was contact cemented together both pieces were back cuts and firm and good quality,,, imho -
I've followed several post on belts and had a go at it , Belt turned out nice and went about wearing it and decided I wanted some stitching on it and well the pics tell the rest, What needs fine tuning and or adjusting?? belt details 1.5" wide with English bridle 7-8 oz and backed with vegtan 10 oz and skived the the outer third of the backing top and bottom/ edges down to 8 oz+- and left the center thick, Finished total center thickness @.28-.30" edges are 0.23 -0.25" thread 277 Cobra 4-25 had a practice run on the smaller piece and thought I had the set up tuned in the test section was the finished belt cut off test fronttest back the put the belt under and pressed away and got a nice start and kept the speed manageable Belt finished front n backfrontbackside missed a stitch and another and ,,,said well its just a nice work belt now and ran the length up and back and had a few more dropped stitches and mark this down to an expensive learning lesson backside what do I need to do, to get on track, timing looked ok ?thread? different needle? feed back NEEDED and welcome David
