Samalan
Contributing Member
Everything posted by Samalan
  1. I KNOW IT LOOKS CRAZY BUT TO MY AMAZEMENT HE DRAWS THAT THING WITH QUICK EASE
  2. It's not easy to get everything right shiny just happened
  3. No that's a customer I don't do much in fir anyway LOL
  4. If you do get a class 4 get it with the needle positioning system it's incredible !
  5. this happens when you bend the leather backwards when you buckle take that same leather and bend it backwards as hard as you can and you will get the same effect that's without a backer .
  6. the middle of the veg tan because you made the back of the leather stronger by using a backer you are compressing the front of the leather causing the leather itself to separate to a degree which can look like little fat lines.
  7. The very first machine I got was a Cobra class 4 and the very first thing I did was sew 7/8" veg tan leather wow that's a sewing machine also Steve has been very good with me for years now .
  8. First I'll say nice job. This is just my opinion but when you back leather it creates a stiffer back which will make the front leather compress more that kind of separates the leather in the middle what I do is work the leather with a bit of oil first then back it when the leather is fully dry also stitching the backer on is a good idea .
  9. Thanks Matt it was a fun job.
  10. just an idea if it's covered this guy wanted pistol and rifle in the same slide covered 270 win and 357 mag
  11. Also If you want a loser fit wrap a piece of tape around the bullet case first you will need nice square lines across the leather for the front and back for the stitch guide lines. for the front piece 4 oz leather should do it
  12. It's easy stuff put a piece leather on the table then take a leather strap that's the same thickness as your outside cover piece dampen the edge of that just a bit place it over the bullet case then with your thumbs nice and straight up and down pressing your thumb nails against the leather around the bullet case hold it nice and tight push down and mark the leather strap with your thumb nails then lay it out flat and measure the distance thumbnail to thumbnail that length x 5 plus about 3/16 on each end and that's the length of the front piece. then the back piece take the with of the bullet case plus the thickness of the leather twice plus 1/32 that's where the stitch seams will be add those up 5 times plus the 3/16 on each end and that's the length of the back . or you can do all sorts of math and end up with the same thing this method works every time for me good luck .
  13. Beautiful work I know about the extra small things I once tried to make a small coil spring making the coil no big deal now harden and temper that's very different LOL
  14. You made those tools! nice work what steel did you use and the heat treat on them.
  15. That's nice work Chuck like Pastor Bob said nice looking tools also
  16. I always dye after wet mold and whatever I'm making is very dry and only air brush now some exceptions to this but not many I have found time is the most important part of everything coming out right letting things dry well before the next step .
  17. Nice work thanks for showing
