I accidentally came across an old needle feed Pfaff 142 (well, I think it is a 142 as it has no tags) but outfitted with just a single needle foot for the right needle. But it is outfitted with a double needle bar and two hooks. So I wonder if someone has "accidentally" a double needle presser foot for the 142 with 7.2mm space. Furthermore I could use a cover for the hook gear (one is missing) part number is 10052. Condition doesn't matter but price does as I know that Pfaff parts are expensive and I do not have a real use for this machine. I´m just playing with it a little bit so this is nothing that has priority and I don´t want to waste money on it.
Check this thread. Member dthayer had a similar problem with his Adler 205 http://leatherworker.net/forum/index.php?showtopic=51731&p=330315
This is a quite small domestic sewing machine. You may be able sew some garment leather on it but it has it´s limits. I´m not sure what needle size it can handle but I think the limit will be a size 19 and #92 thread. The machine is not made for sewing heavier leather, it originally was made for sewing garment fabrics.
I have no Landis but what is a "Friction Disc Shifter Link"? Can you add a picture? You know, maybe one can help if he sees what you mean.
- 7 replies
- mckay
- sole stitcher
(and 2 more)
I even have 2 synchronizers. I wanted one on each machine so I can switch the machines on my table and can use one motor (saves me space) but both synchronizers have the same issue. I tried to adjust the synchronizers back + forth but no change at all. So I think this is not a common issue, right? Or have you ever heard of this before? I ask because I don´t want to deal with this issue again in case I´m buying an Enduro motor or a clone.
BTW - the extra stitch happens on light fabric as well not only on heavy material. I first thought it is because of the compound feed of my 111G156 but I now have mounted it to a different machine with regular feed and the problem is still the same. Here is a short video - you see what I mean? http://s351.photobucket.com/user/orangeagentz/media/sewing_vids/MOV001.mp4.html EDIT: For those who find this post randomly and think it is an ENDURO motor - IT IS NOT!!!!
Thats possible! I´m currently working on 2 speed reducers but anyway - I still have the issue with the extra stitch when the motor is positioning the needle. So sewing just 1 stitch is not possible with this motor. It at least makes 1 stitch too much and sometimes even 2! I decided kick out this motor and look for another one. I´m thinking about one (or two) of the Enduros + my Speed reducer. They have more Watts and a good reputation too, plus I even can order spare parts online. So I wanted to check if the Enduros also have this "1 stitch too much" issue that my motor has.
Yet Another Speed Reducer Question
Constabulary replied to Wishful's topic in Leather Sewing Machines
Or you can mount it to the table frame. I once did this on a machine I have sold. Just to give you an idea: -
Thanks Eric! Is that the case on ALL servos with NPS (or EPS)? I wonder if I´m the only one who has this problem. I do not sew very heavy leather but sometimes quite thick canvas straps. I wonder if the guys who make holster from heavy leather have this problem too. Men - this sucks so bad... How is it with this "one stitch too much" - is this a known problem? Because of the info you sent by mail - no, it honestly has never arrived. But don´t send them again because my pal kicked out his motor and bought a used Pfaff clutch motor.
I recently bought a 400Watts Servo with needles positioning system. Its not a common brand you find in the US I think. It is an analog servo with magnetic speed regulation. Overall a nice motor but the needles positioning system (NPS) sucks! Problem is sometimes the needle positioning system makes 1 stitch too much. Needle goes down and you think it will stay there but then it makes another stitch. This is pretty annoying when you sew short seams on straps or so. No way to adjust the sensor on the hand wheel. I tried it over and over again. Furthermore if the needle hits a hard point the positioning system does not turn off even when I take the foot off the pedal. it always works against the hard point. So the only way is to turn off the entire motor. I don´t like it at all! So I wonder if I can run the ENDURO Servo motors (or clones) which are equipped with a NPS without the NPS. I know I can get them without NPS but I want to know if I pull the plug of the hand wheel sensor just for the case I don't want to use the NPS "today" does the motor still work or does it produce a failure? Also, do other motors with NPS turn off when they hit a hard point?
I Just Bought An Adler For $70Usd
Constabulary replied to IslandMoose's topic in Leather Sewing Machines
If the cylinder is no longer needed remove it if possible. I hope it does not leave a big hole! From my point of view, most of the times it is worth restoring old machine as long as they are not totally busted! But depends it finally on the machine. I have restored a few already. My biggest project was a 111G156 which now is my favorite machine and I´m currently working on an Adler Class III from the early 1900´s. It´s a lot of work but also a lot of fun and you learn a lot! Good luck with your project. I´d like to see pictures of your progress if you don´t kind. -
Monster Flange For Speed Reducer :-D
Constabulary replied to Constabulary's topic in Leather Sewing Machines
Today I received the two step pulley made after my specs. A sealed ball bearing on both sides for 15mm shaft, pulleys are 2", 4" and 6", milled out of aluminum. Each pulley cost me 40€ (about $55) incl. shipping. I´m quite impressed of the quality. I´m getting closer to my idea... -
Adler Class Iii - Early 1900 Leather Sewing Machine
The red Koch Atlas seems to be a Class II. Look at my pictures. Class II and Class III have different take up levers. You will see the difference from the back side view. You probably have noticed that the Class III has an excenter rotating on the upper arm which moves the take up lever. So I´d say you have the earlier Class II -
I removed the "general dirt" with glass cleaner, the old grease I removed with purified petroleum or lamp oil and a fiber brush. Not sure if this always works but this time it did. Some one told me barbecue or grill lighter fluid works too but I have not tried this. But I think it depends on the ingredients of the fluid. If the old grease is too sticky I use paint thinner to remove it. I figured the old paint on these vintage sewing machines is quite resistant... Of course you have to thoroughly oil the machine after this treatment. For rusted parts I use a bath of oxalic acid, this turns rust into some sort of grayish coating but I alway brush this off with a wire brush. Oxalic acid also does no damage the paint. -
Singer 45K1 Thread Tension Check Spring Broke
Constabulary replied to dkvv's topic in Leather Sewing Machines
I know but there is just one coil type spring in the 45K so I´d assume the dealer just have bad pictures. I´d contact them and ask. If just the small end that goes into the tension post is broken, try to bend the remaining end, it MAY work and since the spring is broken why not give it a try. Or try one of the dealer who have banner at the top of this page. But they are all located in the US or Canada but not in Europe. OR - maybe the check spring of the Singer 132K will fit but I cannot confirm this... http://www.college-sewing.co.uk/1416-CHECK-SPRING-SEIKO-_-SINGER-132K=97798 -
A few quick pictures of the Adler II / Adler MILITARIA and my ADLER III I think you will note the difference! Meanwhile I worked on my machine as you can see - its getting better and better but I´m by far not done. -
Mine is in deed and Adler III. I meanwhile have the manual, I had to pay 15€ for a PDF file. The guy did not care about a good quality scan but still better than having non! I also have an incomplete (as it seems) manual of the earlier type called Adler II or Adler MILITRIA. And I have some pictures of the earlier Adler II / MILITARIA from an owner who bought some Adler 4 parts from me. So here is a picture of the front cover of the Adler Class 3 Manual... -
Hey Johan, I guess you mean the inner thread take up spring which sits in the tension assembly on the face plate, right? Try College sewing in thew UK: http://www.college-sewing.co.uk/catalog/search.aspx?keywords=45K Or just ebay: http://www.ebay.com/itm/300720923095 -
Cool - you can´t go wrong with just $70. Seems it has the hook on the left side due to the cut out where normally the hook is placed. Anyway this machine is worth every penny if it does what it was made for... But welding could be a problem since it is a cast iron housing. Not everybody can weld cast iron. As far as I know you only can weld it when the cast iron is HOT (very hot) but heating the iron could cause damages to the mechanics. What I would do is cut a piece of 3mm or 4mm thick sheet metal and glue it in with JB kwik Weld, clean it, sand it and repaint the machine or just the base plate. Just my 2 cents. -
Singer 111W155 Cracked Upper Arm
Constabulary replied to oldskoolbob's topic in Leather Sewing Machines
I didn´t take the bearing apart. I took it off for changing the timing belt. I have attached a PDF parts list for your machine. Seems the bearing has 3 parts+ screws. BTW - for some reason I wrote NEW bearing at the above post, seems I had a weak moment. The bearing is not new, I just removed it, replaced the timing belt and put it back in. When I tapped it out I put the driving shaft against the wall with a thick piece of wood between wall and shaft. You know what I mean? 111w155 Parts List.pdf
