Built Me A Speed Reducer Consew 225
Constabulary replied to jkbuzbee's topic in Leather Sewing Machines
Buy some flowers first...- 12 replies
- consew 225
- speed reducer
(and 2 more)
Cool, always nice to see other ideas but does your wife know the laundry machine is missing parts now ;-)- 12 replies
- consew 225
- speed reducer
(and 2 more)
I dont have a consew but a Singer 111w156 and it came with a Pfaff knee lifter (I know it because I had the same on my Pfaff 138 once) but on the back of the machine it has the original Singer 2-lever-system and the two system do not work together because the original Singer lever setup needs a push mechanism knee lifter and the Pfaff knee lifter needs a pull lever. So this lever from the consew is what I would need. I would assume it will fit to my Singer, right?
- 9 replies
- consew 226
- walking foot
(and 1 more)
if you don't need the long lever, I could probably use it as on my table I have a different knee lifter which does not work with the levers attached to the back of my machine. Can you post a picture showing the whole lever please?
- 9 replies
- consew 226
- walking foot
(and 1 more)
Single Phase Into 3 Phase Converter
Constabulary replied to Yanni's topic in Leather Sewing Machines
covering from 380 to 220 is a quite simple task BUT you have to understand what you are doing! What you need is a good diagram of an STEINMETZ CIRCUIT, the correct capacitor and the knowledge how to do it. But if you know nothing about electricity DON`T DO THIS ON YOUR OWN - ask a qualified electrician. http://www.plctalk.net/qanda/showpost.php?p=273421&postcount=11 Again - If you understand it, it will cost you just a few bucks for the capacitor - if you don´t understand it don´t even try it. Ask an electrician or buy a servo motor. -
If you have a large pulley on your motor you can replace it with a new smaller pulley (50mm recommended) and / or add a speed reducer but it is hard to find in Europe. Another option is a servo motor where you can dial the max. speed.
Adding A Speed Reducer To A Flatbed
Constabulary replied to cdthayer's topic in Leather Sewing Machines
I´m selling a Heavy Duty flat bed Adler 4-3 leather sewing machine. It has been refurbished once in it´s live as it seems. It is in fully working condition.No mechanically issues. Makes nice stitches and is slow running because of a nice running 4:1 speed reducer with ball bearing. It has an adjustable alternating presser feet, this is not a walking foot in the common sense but it moves back with the feed dog and then jumps forward again and so on. This function can be turned off if not needed. I just have listed it on Ebay - please note the 8 minute Video (I`m not a video artist but I think it shows what is necessary) www.ebay.de/itm/201011368704 Don´t hesitate to ask questions!
Thread Jumping Off Tension Spring Think Juki Lu -55
Constabulary replied to jerry895's topic in Leather Sewing Machines
Are you sure that the thread runs the right path? -
Looks like a Juki DDL 5500 or so. There are many clones of this machine type on the market. Over here recently one sold for just 73€ on Ebay but it was just the head. Brand was STITCHER. Never heard of it before but it was brand new. www.ebay.de/itm/151177167875
While I looking for an idea for my new kitchen and living room table I stumbled over this website. www.simplifiedbuilding.com http://www.simplifie...h-simple-table/ They offer a quite cool looking and easy to assemble tubing system. I looked at their gallery and was quite amazed what a wide range opportunities I have with this system. And I thought it would be a very cool idea for a sewing machine table as well. No welding, just some tube cutting and a hex wrench, thats it! Big advantage is that you alway can always expand the system or change the parts configuration of the table when you need more space or just a different table. I will definitely buy some of their stuff for my new kitchen and / or living room table. I really love this idea. What do you guys think?
Manual For Frobana Outsole Stitcher
Constabulary replied to Jim Wilson's topic in Leather Sewing Machines
Maybe this is the one you need but ask the seller first http://www.ebay.de/itm/Frobana-Doppelmaschine-Gebrauchsanweisung-/221294397705 -
Singer 111W155 Alternating Presser Foot Problem
Constabulary replied to Wishful's topic in Leather Sewing Machines
I looked closer at your picture and compared it with my machine with foot in lift up position. At your machine the part I numbered with 3.) seems to be quite far up in the fork when the foot is lift. At my machine it is in a much lower position even when foot is lifted. See pictures below Try to put flat screwdriver between the parts, use it as a lever and try to push down part 3.) I assume the fork part is too tight and the part 3.) is stuck there. -
So with other words the presser foot is stuck in its position, right? Then before you loose the screws on part 1.) + 2.) check the part that looks like a fork and part 3.) is sitting in. The part is secured with a small screw from the backside. Loose the screw a 1/2 turn and try to adjust the "fork part" with a screw driver from the top side. The part has a slit. I had this problem with my Duerkopp 252 and a small adjustment on the fork part did the job. A thoroughly oiling could be useful as well. -
This would be my 1st idea. Check the parts 1.), 2.) and 3.) in the picture if their screws are loose and check if part 1.) is moving when you lift the foot lever and check is parts 2.) + 3.) are moving when you turn the hand wheel. Screws for the parts are all accessible from the backside. I assume screw of part 1.) is loose. But it can´t be wrong to check them all. -
Electric Drill As Sewing Machine Motor?
Constabulary replied to bikemaniac's topic in Leather Sewing Machines
Are you serious? I think there is a reason why no one else did this before but if you like the idea go ahead and try it. I personally would never try this. Too much fuzzy work. My advice: Buy a servo motor mount it to the table, but a V-belt on it and go. With other words plug + play! -
Singer Mfg. Co. - Image Film From 1934
Constabulary replied to Constabulary's topic in Leather Sewing Machines
I think there was not much difference between the factories in the US and GB. I guess it looked almost the same in the 1930´s. But you are right, I´d also like too see films of the US Singer factories. Do these films exist? If you know other films from the old days please post them. I´d really love to see them!!! -
yeah, exactly my thoughts! Imagine how big this factory must have been. They produced EVERYTHING from cast iron housing to wooden cabinets in one big factory - nothing outsourced. Good old days! -
I also like it very much, too bad it has no sounds but watching the film on full screen is great! I wish I had one of the great shipping crates. I´d kick out my TV board and replace it with one of these crates! -
I just found this in the WWW and thought it is pretty interesting for vintage sewing machines enthusiasts: 70 minutes film "Birth of a Sewing machine" http://ssa.nls.uk/film/1592
Adler 269-373 Or Adler 267 Thread Tension Assembly
now that I see the assembly, are you sure that your thread runs the right path? From what I see I´d assume the thread runs from the backside through the hole on the right, then between the discs along front side and the through the middle hole and then through the left hole. I have edited Gregg's picture a little bit. Not sure what the manual says but this is how I would do it without knowing the manual. -
I can´t the the part good enough on the picture to tell what the problem could be but since you say it has discs I think they should be replaceable, right? Can´t you just add larger discs? Isn´t the assembly spring loaded and you can put more pressure on the discs when you turn the thumb screw? Or just wrap the thread two times around the assembly. As I said I cant´see the assembly very well.... -
not sure how the motor mount looks like but on my motor I have two spacers I can place at different positions. With these spacers I can move the belt a little left or right. Maybe this could solve your problem. -
