Sjm1027
Everything posted by Sjm1027
Thank you, some great data. I ended getting the #18 needles, .8mm waxed thread and the Diamond Stitching Chisel Set, 5mm. That will be a good place to start.
Is there a guide that I can use to select a pricking iron set? I have read about diamond, French, and crimson-style shaped holes, but I am getting hung up on the spacing. I will be making belts, wallets, and bags. Most of my projects will be medium to small. Then, there is white steel and carbon steel. Would anyone be able to help me in the right direction? Thanks
Great idea, thanks for the info.Steve
Thanks Dwight, I'll give that a try... Already have the sander. I can already see starting at the holes and working my way inward would be best. I wouldn't have tried it but now that you mention it, it makes perfect sense. Thanks, Steve
I wanted to make my first belt. Was wondering if everyone uses an oblong punch or do you simply punch 2 holes and connect the holes using an exact o knife to make a slot for the buckle and also do you trace a point on the end of the belt by hand or use a Strap End Punch? I am just curious if everyone is purchasing all these tools or doing things by hand? Thanks
Thanks Bruce I'll take a look. Steve
I have been away from this site for a while but have since been sparked up to start working with leather again. Would like to know what your opinion is on tools. I am looking for oblong and hole punches as well as a draw gauge. I have been looking at these tools and see so many different draw gauges and punches my head starts to spin. I want to purchase quality tools that I can keep in good shape and even pass them down some day. Is it worth spending the money on an Osborn #51 vs. a draw gauge from Leather Craft craft tool draw gauge? Price is about half... and also the punches, what should I be looking at, anyone have good luck at a particular web page. I live in MA and there really isn't anything around except Tandy Leather. I just want to make sure I am getting quality tools and it's hard to order on the Internet. Thanks Steve
Thanks, I will give it a try. Wasn't sure of the 50/50 mix. What does the soap do for the process? Thanks again, Steve
Any recommendations on waterproofing clogs. They are rubber bottoms but leather tops. Want to put something on them to protect. Thanks, Steve
I am looking for a good shoe stretcher. I have wide feet and always have the need to stretch my shoes in both the inside deep towards the toe and the instep. Looking for a good shoe supply store on-line to purchase a stretcher. What do you use to spray on the leather to make it stretch and is it ok for the leather? Thanks Steve
This may be a silly question to most of you but exactly what is a leather splitter used for or when is it needed in a project. I am confused because you can't pull to big a piece through so I want to know some applications you would use it. Thanks Steve
cell phone case
Sjm1027 replied to Sjm1027's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks Pete, appreciate the feedback Steve -
cell phone case
Pete, It actually fits pretty good, what I don't like is the curved look and the snap... the snap could of been moved down a bit. This cell case fits a Palm Treo Thanks Steve -
I had some time today to make a cell phone case for myself and I am a little disappointed as to how it came out. First off I am trying to learn here so I don't mind you all telling me the truth... truth is good! I have placed a bunch of pictures on a web page so you can see in detail what I may of done wrong. Web Page: http://sjm55.com/leather/ This project has not been stitched yet because I am not sure I will use it. I used 6 ounce leather, and a 2 ounce pigskin lining as shown in picture 10. The template: I had the idea to make this case all in 1 piece. Maybe I went about that in the wrong way but it is what I did. So you can see my 1 piece template in green as shown in picture 13 and 14 I folded the sides after adding a v-groove. As you can see the sides don't fold they sort of round over. Not sure I wanted this but it's not to bad. You can see in pictures 11 and 12 The next thing I did wrong was to make the front strap and snap to short. It reaches but sort of on a bend, should of brought it down another 3/4 inch then put the snap on. see picture 9 On Picture 8 my thoughts was to bend over the edge of the smaller flap and sew by hand. I just couldn't get it to bend easy enough, not to sure what happened there. I also added room for this bend in the template but ended up cutting the excess off on each end and will sew in a 45 degree angle. This is where I was getting mad at making this 1 piece and not 3 pieces making the 2 sides separate.
"just put a deer on it and maybe some initials on the back"
Sjm1027 replied to freak's topic in Figure Carving
Wow Freak, That's some beautiful work. Great classy look. Thanks for sharing Steve -
That is absolutely beautiful... Very nice job.... Steve
I usually use patterns I find in books or on this page and just assume it is correct. One thing about that is I find myself limited as to what I can make. I would like to create my own pattern for my next project and would like to ask a few questions. I have some really nice paper to do this with (Brown Shopping Bags) seem to be perfect for this work. I would like to make a simple bag, about 14" long X 5" wide. The five inches would be max opening, thin leather so it can accordion out when the extra room is needed. I am thinking 7 ounce leather for front back bottom and top, all one piece of leather and just add the sides at about 4 ounce leather. I will use a clasp for the front. My question is, Do you all assemble your templates with glue, giving the project a shake down before you start the real deal? Would appreciate it if someone would explain the design, template to project process or maybe there is something out there I have not found yet. Thanks Steve
I could really use some help with making patterns...
Sjm1027 replied to Sjm1027's topic in Patterns and Templates
I am also interested in Assembly. It would be nice to see some assembly techniques on DVD. Actually tooling DVD is good too. I will check it out Thanks -
Being from Massachusetts I really never get a chance to see anyone working leather. Thats why I like Leatherworker.net so much... I have received so much help from this group, I would be lost without you all. Does anyone have any recommendations on instructional DVD's. I could really use some help with making patterns... getting my ideas to a pattern is what I am having trouble with. It would also be nice to get a DVD to watch someone take a project from beginning to end. I enjoy making cases, bags and small boxes. Thanks Steve
Great, Thank you
I have been looking for a web page for Artisan or a contact that can explain a few things to me. Anyone know a good person at Artisan and how I can get to them? Thanks
Yes I agree Jordan, Just want to make sure before putting down 500+ dollars for a splitter (Campbell Bosworth Keystone Splitter) I want to make sure it is going to do what it is advertised to do and do it well. Thanks for the answer Bruce Steve
Hi Bruce, Thanks for your time... Can you elaborate on that... You mentioned this style of splitter... Do you have an opinion on this style of splitter? I am only trying to narrow down a selection. Thanks again Steve
I was looking in The Leather Crafters and Saddlers Journal and came across an add for Campbell Bosworth Keystone Splitter. Wondering if anyone here has one and what they think of it? Page 40 in the Nov/Dec issue. Thanks
Hay that's different, I like the idea... Thanks
