Everything posted by RiverCity
Words On A Belt? Best Way. Stamping, Carving?
RiverCity replied to BarnDog's topic in How Do I Do That?
Another vote for carving the letters. Stamps are ok for some stuff I guess, but IMO it always puts me in the mind of cub scout arts and crafts. You can go to a site like dafont.com and find what looks right, then print out the wording etc in different sizes depending on what you need. Chuck -
Lather Guild Is Portland Oregon
RiverCity replied to electrathon's topic in Special Events, Contests and Classes
Ill be there. Should be fun! Chuck -
Other than you will have to let it mostly dry.... no problems at all. Leather that is too wet is too soft to work, and wont hold the tooling as well as leather that has the correct moisture content. Chuck
Ill add that you can use a modeling spoon or even your finger (if you spray the area with water first) to smooth out and "round" the bevel. Chuck
I second buying by the side. You will typically get a better price per square foot, and will have the same pieces of leather you are currently using plus more clean leather from the shoulder that can be used. For the main cases that I do, the bellies are useless. I cut them off as soon as I unroll a side. However, I use them for things that stretch etc arent a factor. If you are looking at cost effectiveness, buy by the side. Chuck
The main reason is on the cases that I make, the lid and base cap are made of wood with leather wet formed around it. I also do exotic wood caps. The theres making forms for wetforming other cases etc Chuck
Youll have fun, I know I did. Chuck
Pretty much set back up, still have a few things to do. It's a never ending list lol Here's some pics of the shop and some stuff I'm working on. Chuck Some more pics
Practice walking the tool in a straight line without a cut. You might find it easier to hold the beveler slightly about the leather and "bounce" it with the mallet/maul. Also, make sure your leather has the correct moisture content. Too wet, and it will look choppier. Chuck
Paul Zalesak (Sk3) Teaching In Portland Or
Great class with a hell of a nice guy! Thanks Paul for your knowledge and the knives! Learned a lot brother. Thanks to Aaron for setting it up! Everybody was great. Chuck -
Starting with no experience would prove difficult. You really need to start at the beginning and learn the basics and develop your skills before you can even think about opening a store. I would suggest some of Al Stohlmans books to get an understanding of basic leatherwork. How to carve leather The art of hand sewing leather Leathercraft tools Tech tips http://www.tandyleatherfactory.com/en-usd/home/department/books-patterns/books-patterns.aspx There are also several lifetimes of knowledge on this website. Spend some time and do a lot of reading. Hope this helps Chuck
Here is the frame of the main bench. I had to get some longer screws for the top so I couldn't finish it tonight. The top is a 32x80 solid core door. Tomorrow I need to finish it and build the cutting table. Thanks for the threads, I'm reading through them! Chuck
The granite will be about half the length of the workbench I'm building. Not sure if Ill make the rest of the surface even to it or not. Using a solid core door as the top and framing the bench like a house, so I might just leave it on top. The marble is probably going to go under a poly board for punches. I was kinda bummed when I got directed to the dumpster that had been emptied recently. Then I saw one of the fabricators and asked if he had any scrap he had not tossed yet. He took me in the shop where he had a pallet going. The marble is in the 150lbs + range, and I definitely felt my age when I picked it up. Lol. Chuck
Just moved down to Portland from Alaska and am in the process of setting up shop. Stopped by a granite countertop manufacturer and hit the mother load. Was expecting smaller scraps, but what I found was excellent. The big piece of granite is 47x22.5 rounded on two sides, the marble is 26x16 smooth cut. Both pieces free from the scrap pile. Chuck
The 4 piece sets have a die for each part of the snap, male/female post and cap. If you can find the Tandy on sale buy it. You can get the same press from other places if you look around too. But I do advise ou to wait for a sale. Lol. Chuck
50/50 Resolene
RiverCity replied to Paulr's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Has anybody tried spraying resolene out of a spray bottle, like windex type or even an atomizer type? Chuck -
Just got my new cowboy 27 set up and am playing with stitch lengths and tensions. Do these stitches look right? The bottom thread looks like its trying to pull through to me? Chuck
What are the times? Chuck -
I use 2000 grit auto paper on the outside surface of the punch tube, followed with flitz. Smooth going after that, except for the once in a blue moon touch up. Chuck
Now see, my dog is helpful. She finds any rivets that I drop, and leaves them all over the living room carpet to step on barefoot. Chuck
Sounds good! Bob is sending an invoice in the morning. Thanks again for all your help Wiz, it is much appreciated. Chuck
How Do You Accomplish This Look -- Black W/ White Impressions
RiverCity replied to LeatherHead99's topic in How Do I Do That?
That's what I usually have happen. I'm guessing dryer block and less pressure? Chuck -
A cowboy 227. I went back and forth with the consew 206 flatbed class machines, and almost got talked into a 441 clone, but its more machine and capacity than I need. The 227 gives the cylinder arm advantage and with a flatbed attachment for wallets etc, should be good to go for my needs in a machine. Down the line I might add a big machine if the need arises. Chuck
Hi Aaron - email sent, please add me if you still have openings. Thanks Chuck
