Everything posted by IHL
For sale in Continental USA only. This is a used Randall Model R32 Rotary Embosser. Please take note that this is a 110v Power machine. This machine is in excellent condition, breaks open easily to change top embossing roller, machine does come with one basketweave commercial embossing roll (does NOT come with the stainless steel roller that is in the picture). Has heating element control and heating rod, will accommodate a 7 ¾” wide piece of leather between guides, I do have the manual for this machine, simple to use. Standard Features: Quick Change of Embossing Rolls, Ideal for doming and forming, simple width adjustments, adjustable pressure, heat control, standard rolls 3” Diameter, pattern 9 5/8” long, larger diameters available for longer patterns. Comes with machine, motor and table Shipping weight is about 350lbs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up. Asking $2700 Complete Machine is over $7000 new. Reply through this forum or you may call the shop at 602-two69-zero202. Thanks for looking.
For sale in Continental USA only. This is a used Ellegi model SKS 8” wide Stationary/Straight Knife Splitter. Please take note that this is a 3 Phase Power machine. Can be converted over to be powered by a 110v motor by replacing motor. This machine I believe was imported by American Shoe Machinery Company. This machine is in excellent condition as well as the blade and feed roller. Splitter has forward and reverse switch. I have upgraded to a wider machine and selling this one. Manual/instructions included. Machine stands about 45” tall and is 18” x 18” on the base. Shipping weight is about 247lbs and 265lbs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up. $1300 Reply through this forum or you may call the shop at 602-two69-zero202. Thanks for looking.
- ellegi
- stationary
(and 3 more)
For sale in Continental USA only. This is a used Campbell Bosworth Rotary Embosser . Please take note that this is a 110v Power machine. This machine is in good condition, breaks open easily to change top embossing roller, machine does not come with embossing roll. Has heating element control but no heating element (available at Campbell-Randall). Adjustable pressure and will accommodate a 7” wide piece of leather between guides, I do not have the manual for this machine but one is not required, simple to use. Comes with machine, motor and table Shipping weight is about 170bs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up. Asking $1400 Reply through this forum or you may call the shop at 602-two69-zero202. Thanks for looking.
For sale in Continental USA only. This is a used Rotary Embosser ( do not know what make or model it is). Please take note that this is a 110v Power machine. This machine is in good condition, machine comes with one embossing roll (see Picture). Adjustable pressure and will accommodate a 5 ¾” wide piece of leather between guides, can modify the guides to take a 6 ½” wide piece. I do not have the manual for this machine but one is not required, simple to use. Comes with machine, motor and table Shipping weight is about 120bs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up. Asking $1200 Reply through this forum or you may call the shop at 602-two69-zero202. Thanks for looking.
For sale in Continental USA only. This is a used Schaefer EC model edge coating glue machine 11” wide. Please take note that this is a 110v Power machine. This machine is in good condition and easy to clean up after use, I do not have the manual for this machine but one is not required, simple to use. Description below is from the Schaefer website. Shipping weight is about 120lbs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up. Machine costs $5495 new. Asking $1300 Reply through this forum or you may call the shop at 602-two69-zero202. Thanks for looking. Edge Coater - EC Series Edge Coating Machine (model EC): The EC model is an edge gluer, which is a gluing machine designed for adhesive application along the edge of a part. This type of gluing machine has open end (cantilevered) rollers that allow adhesive application to either the edge of a sheet or to the full surface (up to the width of the gluing machine). The adhesive coating thickness is adjusted by means of a dial which controls the gap between the pickup roller that sits in the glue tank and the coating application roller. The standard machine can glue parts from paper thickness to ¼ thick, but an optional model with floating feed roll can be used for adhesive application to parts up to 2" thick. The position of the feed table relative to the coating roller is adjustable so the machine can be set for gluing a narrow strip along the edge of a part or can be used for adhesive coating of the full surface. The edge cementing machine can be built with special rollers for coating stripe patterns or for application of a stripe of adhesive a pre-set distance from the edge of the part. The Edge Coater can be used for the application of many types of adhesives - latex cement, dextrine glue, PVA and EVA resin cement, acrylic PSA adhesive, epoxy adhesive, ultraviolet cured adhesive, hot animal glue (heated glue tank), and many other types of coating and adhesive formulations. The machine is designed for easy cleanup, and has a removable glue tank and adhesive pickup roller. This design allows glue to be cleaned from the machine in less than ten minutes. Edge Coating machines are very popular for the application of latex cement to leather goods such as wallets, handbags and belts, as well as to shoe and boot components. These machines are also used for gluing many other products where a band of adhesive is needed: calendars, easel backs, sample books, specialty boxes, filters and toys are just a few of the other applications for these machines.
- schaefer
- ec edge coater
(and 2 more)
For sale in Continental USA only. This is a used Randall Union Lockstitch machine. Please take note that this is a 110v Power machine. This machine only has about 80 hours on it, machine is in premium condition and was only used for double thickness belts. Black worn off in the arch cover area is NOT from excessive use, it is where your hands, leather, buckles, rings etc are always touching and hitting. I have the instruction manual for this machine. Machine comes complete with table, motor, bobbin winder, 6 x bobbins, 3 x bobbin springs, 3 x extra presser feet, 39 x Number 3 awls, 8 x Number 2 ½ needles and a full set of wrenches. Shipping weight is about 350lbs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up. Machine costs $7000 + new. Asking $3300 Reply through this forum or you may call the shop at 602-two69-zero202. Thanks for looking. Description below is from the Campbell-Randall website. UNION Lockstitch High Speed Leather Stitcher Needle & Awl machine for Heavy Materials For stitching all kinds of leather up to 3/4 inch thick Noted for pulling a very tight seam. FEATURES: Straight Needle & Awl Lock-stitch High Speed (800 SPM). (Operator ability in handling work governs the speed of the machine) Needle Feed/ Jump Foot Extra Large Bobbin holds 100-150 yards of thread (fewer bobbin changes) 12 Inch Throat Sews Up to 3/4 Inch Thick Tight Seams Thread 3 to 12 cord, Left Twist (Wax Optional) Heavy Duty Variable Speed Control for custom or repair work Ideal for high volume production applications APPLICATIONS: Designed for sewing light to heavy weight materials such as leather, plastics, coated nylons, and other non-fibrous materials. Used to manufacture.. Belting, Strap and Harness Work, Gun Leather, Saddles and Other Leather Goods. Sporting Goods including Footballs, Basketballs, Volleyballs and Softballs. Shoe stitching applications in Moccasins, Fairstitching, and Flat Sole work. Luggage stitching on Brief Cases, Bags, and Handles. Optional Accessories: Custom Attachments, Variable Speed Motor and Variable Speed Control available from Campbell-Randall
- 2 replies
- randall
- union lockstitch
(and 2 more)
This is a used Schaefer EC Series 11" Wide Cementer for sale, made by Schaefer Machine CO, Bridgeport, Conn. $1,300.00 Shipping weight is 120 LBS, I will Crate/Box this machine to be shipped, you will need to arrange shipping. Info posted below from Schaefer website. Edge Coater - EC Series Edge Coating Machine (model EC): The EC model is an edge gluer, which is a gluing machine designed for adhesive application along the edge of a part. This type of gluing machine has open end (cantilevered) rollers that allow adhesive application to either the edge of a sheet or to the full surface (up to the width of the gluing machine). The adhesive coating thickness is adjusted by means of a dial which controls the gap between the pickup roller that sits in the glue tank and the coating application roller. The standard machine can glue parts from paper thickness to ¼ thick, but an optional model with floating feed roll can be used for adhesive application to parts up to 2" thick. The position of the feed table relative to the coating roller is adjustable so the machine can be set for gluing a narrow strip along the edge of a part or can be used for adhesive coating of the full surface. The edge cementing machine can be built with special rollers for coating stripe patterns or for application of a stripe of adhesive a pre-set distance from the edge of the part. The Edge Coater can be used for the application of many types of adhesives - latex cement, dextrine glue, PVA and EVA resin cement, acrylic PSA adhesive, epoxy adhesive, ultraviolet cured adhesive, hot animal glue (heated glue tank), and many other types of coating and adhesive formulations. The machine is designed for easy cleanup, and has a removable glue tank and adhesive pickup roller. This design allows glue to be cleaned from the machine in less than ten minutes. Edge Coating machines are very popular for the application of latex cement to leather goods such as wallets, handbags and belts, as well as to shoe and boot components. These machines are also used for gluing many other products where a band of adhesive is needed: calendars, easel backs, sample books, specialty boxes, filters and toys are just a few of the other applications for these machines.
Union Lockstitch Heavy Duty Stitcher machine for sale, $3500.00. This machine only has about 50 hours on it, machine is in premium condition and was only used to sew double thickness belts. Machine comes complete with table, motor, bobbin winder, 6 x bobbins, 3 x bobbin springs, 3 x extra presser feet, 39 x awls and full set of wrenches. I will crate the machine, table and motor on a pallet for shipping, you would need to arrange a carrier for shipping. Contact Ian 602-269-0202 or reply by email UNION Lockstitch High Speed Leather Stitcher Needle & Awl machine for Heavy Materials For stitching all kinds of leather up to 3/4 inch thick Noted for pulling a very tight seam. FEATURES: Straight Needle & Awl Lock-stitch High Speed (800 SPM). (Operator ability in handling work governs the speed of the machine) Needle Feed/ Jump Foot Extra Large Bobbin holds 100-150 yards of thread (fewer bobbin changes) 12 Inch Throat Sews Up to 3/4 Inch Thick Tight Seams Thread 3 to 12 cord, Left Twist (Wax Optional) Heavy Duty Variable Speed Control for custom or repair work Ideal for high volume production applications APPLICATIONS: Designed for sewing light to heavy weight materials such as leather, plastics, coated nylons, and other non-fibrous materials. Used to manufacture.. Belting, Strap and Harness Work, Gun Leather, Saddles and Other Leather Goods. Sporting Goods including Footballs, Basketballs, Volleyballs and Softballs. Shoe stitching applications in Moccasins, Fairstitching, and Flat Sole work. Luggage stitching on Brief Cases, Bags, and Handles. Optional Accessories: Custom Attachments, Variable Speed Motor and Variable Speed Control available from Campbell-Randall
Model R32 Randall Rotary Embossing Machine with heat for sale $2700.00. Does not come with roller that is on the machine currently, it comes with Commercial grade Basketweave roll die that is seen in the picture. I will crate the machine, table and motor on a pallet for shipping, you would need to arrange a carrier for shipping. Contact Ian 602-269-0202 Information Listed below as per Randall Model R-32 Rotary Embossing Machine Western Embossing – Molding – Forming Roll Leaf Color Inlaying For the Belt and Strap Trades Simple to Use – Built to Last This machine is powerful, rigid, well balanced, and will give years of good service. It is adaptable for all classes of rotary embossing. Constructed so that the head swings open allowing for quick change of embossing rollers. Simple adjustments for different width straps and belts. Any amount of pressure can be had by turning pressure adjustment wheel. Made in USA! Standard Features Quick Change of Embossing Rollers Heavy Duty Western Embossing Ideal for Doming & Forming Simple Width Adjustments Adjustable Pressure Heat Control Standard Wheels 3 in. dia, Pattern 9-5/8 in. long Larger Diameters Available for Long Patterns
Machine has sold, thanks for looking.
This Machine has also been SOLD, thanks for looking
This Machine has been SOLD, thanks for looking.
Randall NSB Beveling Machine set up for 1.25” wide belts. Machine, table and motor $1750.00 I will crate the machine, table and motor on a pallet for shipping, you would need to arrange a carrier for shipping. Contact Ian 602-269-0202 Nothing can beat the Randall NSB Beveling Machine for producing leather belts or strap goods with a smooth, round uniform edge. The NSB can finish both edges in one continuous operation (excluding point). Easy to operate, precise and economical, the NSB is easily adjusted to your work . Self adjusting gauges guide and hold the belt properly as it speeds through the machine. All parts are accessible for easy cleaning, changing cutting tools, etc. Its rigid construction assures dependable, uninterrupted service. STANDARD FEATURES Quick-Change Feed Rolls Bevels Edges in One Pass Any Width from ½” to 2-3/4” Thicknesses of 4 oz. to 20 oz. Bevels a Gross of Belts in 5 min. Easy to Maintain OPTIONAL ACCESSORIES from Campbell Randall Grooving Attachment Creasing Attachment 10 styles of knives to choose from
Randall NSB Beveling Machine set up for 1.50” wide belts. Machine, table and motor $1750.00 I will crate the machine, table and motor on a pallet for shipping, you would need to arrange a carrier for shipping. Contact Ian 602-269-0202 Nothing can beat the Randall NSB Beveling Machine for producing leather belts or strap goods with a smooth, round uniform edge. The NSB can finish both edges in one continuous operation (excluding point). Easy to operate, precise and economical, the NSB is easily adjusted to your work. Self adjusting gauges guide and hold the belt properly as it speeds through the machine. All parts are accessible for easy cleaning, changing cutting tools, etc. Its rigid construction assures dependable, uninterrupted service. STANDARD FEATURES Quick-Change Feed Rolls Bevels Edges in One Pass Any Width from ½” to 2-3/4” Thicknesses of 4 oz. to 20 oz. Bevels a Gross of Belts in 5 min. Easy to Maintain OPTIONAL ACCESSORIES from Campbell Randall Grooving Attachment Creasing Attachment 10 styles of knives to choose from
Union Lockstitch High Speed machine for sale, $3500.00. This machine only has about 50 hours on it, machine is in premium condition and was only used to sew double thickness belts. Machine comes complete with table, motor, bobbin winder, 6 x bobbins, 3 x bobbin springs, 3 x extra presser feet, 39 x awls and full set of wrenches. I will crate the machine, table and motor on a pallet for shipping, you would need to arrange a carrier for shipping. Contact Ian 602-269-0202 UNION Lockstitch High Speed Leather Stitcher Needle & Awl machine for Heavy Materials For stitching all kinds of leather up to 3/4 inch thick Noted for pulling a very tight seam. FEATURES: Straight Needle & Awl Lock-stitch High Speed (800 SPM). (Operator ability in handling work governs the speed of the machine) Needle Feed/ Jump Foot Extra Large Bobbin holds 100-150 yards of thread (fewer bobbin changes) 12 Inch Throat Sews Up to 3/4 Inch Thick Tight Seams Thread 3 to 12 cord, Left Twist (Wax Optional) Heavy Duty Variable Speed Control for custom or repair work Ideal for high volume production applications APPLICATIONS: Designed for sewing light to heavy weight materials such as leather, plastics, coated nylons, and other non-fibrous materials. Used to manufacture.. Belting, Strap and Harness Work, Gun Leather, Saddles and Other Leather Goods. Sporting Goods including Footballs, Basketballs, Volleyballs and Softballs. Shoe stitching applications in Moccasins, Fairstitching, and Flat Sole work. Luggage stitching on Brief Cases, Bags, and Handles. Optional Accessories: Custom Attachments, Variable Speed Motor and Variable Speed Control available from Campbell-Randall
Model R32 Randall Rotary Embossing Machine with heat for sale $2700.00. Does not come with roller that is on the machine currently, it comes with Commercial grade Basketweave roll die that is seen in the picture. I will crate the machine, table and motor on a pallet for shipping, you would need to arrange a carrier for shipping. Contact Ian 602-269-0202 Model R-32 Rotary Embossing Machine Western Embossing – Molding – Forming Roll Leaf Color Inlaying For the Belt and Strap Trades Simple to Use – Built to LastThis machine is powerful, rigid, well balanced, and will give years of good service. It is adaptable for all classes of rotary embossing. Constructed so that the head swings open allowing for quick change of embossing rollers. Simple adjustments for different width straps and belts. Any amount of pressure can be had by turning pressure adjustment wheel. Made in USA! Standard FeaturesQuick Change of Embossing Rollers Heavy Duty Western Embossing Ideal for Doming & Forming Simple Width Adjustments Adjustable Pressure Heat Control Standard Wheels 3 in. dia, Pattern 9-5/8 in. long Larger Diameters Available for Long Patterns
Brand new Adler 69 Cylinder Arm Sewing Machine for sale, Made in Germany, head only. $1500.00 plus shipping This machine has never been used, it was set up only. Comes with stitching guide, 5 x Bobbins, 9 x needles, Spool stand holder that holds two spools, factory manual and wrench. I will package the machine and it can be shipped UPS, Shipping cost to be determined by final destination in Continental USA only. Contact Ian at 602-269-0202
Gun Rig For A Friend
IHL replied to cgleather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Holster and belt looks great Billy, mighty fine work there pard.See yaIan -
Wanted to buy: Duncan's aluminum mold gun only. Sig Sauer 5" GSR with or without Rail, please send pic if you have one that you want to sell, thanks in advance. Ian
Billy, Great looking cuffs and a nice border stamp pattern. Where can i get that stamp from ?. Stitching looks first class, are you sewing it on your landis 3 ?. Let me know Ian
Looking good Billy, those holsters sure look good against that background, pity you have shipped them already as you could have brought them up to Wickenburg with ya. Ian
Johanna, Thanks for putting up the directory. Billy from CGLeather and i will be looking for you up in Wickenburg in a couple of weeks, see you then. Regards, Ian Martin<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> International Handgun Leather 3334 W. McDowell Rd Suite # 26 Phoenix, AZ 85009 Tel: 602-269-0202 www.ihlusa.com Name: Ian Martin UserName: 525brwn IP Address: 67.40.74.164 Email Address: gunleather@qwestoffice.net
Full-time holster maker. Born in Scotland, raised in South Africa and been living in the USA since 1987. Was in the motorcycle industry in SA from 1979 - 1986. Worked for a holster maker here from 1987 to 1994 then started my own holster company at the end of 1994 to current.
Thanks Steve Ian
Thanks Billy Ian
