Everything posted by MorningStarL
It's done. Not my best nor my worst work ever. I was trying to make stitching holes late at night, in an unheated workshop with the taps dripping so pipes wouldn't freeze, and was going to have to re-set my awl, when the knifemaker suggested that just this once, I could drill the holes. I didn't want to. Even with all those other reasons -- but the customer had been crude and disrespectful, so I did it. Pictures tomorrow maybe, with the dye and everything on it, before it goes in the mail. I was using thin leather, and the front and the back are two pieces each, flesh side joined together. The clip's mounted in a separate piece (thanks, Snubbyfan) and stitched to the back of the back; the strap for the stud is stitched into the front of the back. The stud's in the front of the front. I used 9-10oz for the welt, and left the top 1/2" or so unstitched. The knife has a big brass bolster and it needs room. I got the edges burnished very sweetly and dyed it all with Fiebrings Black; then Resolene 50-50 with water, and a coat of neutral shoe polish. It goes in the mail tomorrow. Thanks, everyone. You're making me better at what I'm doing. Sorry I don't know how to get the pictures in order.
Hi, Kiwican! I'm in Texas right now, and the customer's in California, so we're okay on the legality. One of my problems with the project is that I'm not a big fan of a knife that you can only use to stick in someone. Canadians, eh? Snubbyfan, really nice work. I like clean leather, with visible stitching and little or no ornamentation. Yours is right up my alley. I'll try that if there's a next time. Right now I've got the pieces cut, two pieces of a lighter weight leather (not sure -- I usually use 9-10 ounce, and I inherited this), the Sam Brown stud in the outside of the front, and contact cement setting up on the front pieces. Got the strap for it cut. I'll anchor it to the inside of the back piece, and put the clip through the back and glue them. Stitch the top edge of the front, and later add the welt and put them all together. There's still time to do it like you said. I know the flaw in my plan is going to be stitching around the clip when I have to anchor the strap in the back too. Your way will take care of that for me. Thanks! I'll post pictures Monday.
I'm not having good luck using the search engine, and I'm sure the answer I want is in the Forum somewhere. I make mostly knife sheaths, and I like a sewn on belt loop. Keeps metal away from the blade. The knifemaker just sold something to a guy who has a disability that prevents him wearing a belt. He's asked for a sheath with a metal clip. Since I don't like them, I've never done one. Is the answer to line the sheath? Which would mean two thinner layers of leather? And is there a way to attach them firmly to the sheath? The ones we have here look like the slide through a slot. What I'm thinking of is to cut two pieces of thinner leather than I'd usually use for a sheath,one for the lining; put the clip through the outside layer only; then contact cement both pieces together and go on stitching up the sides. The knife is a punch dagger, which will need a strap and Sam Brown stud (I don't like them either -- metal inside the sheath where it touches the knife blade). So I'd put that through the outer leather and secure it too, before lining. If I'm messing up here, I'd like to know. I've seen someone with a belt clip that isn't metal and seems to be attached to the sheah with a non-metal rivet. I've asked him about what he's using, but I bet you guys are faster. Thanks in advance, and happy New Year!
Finishes For Reptile Skins?
MorningStarL replied to MorningStarL's topic in Exotics, Reptiles, Furs and others
Thanks, Cheryl-- don't know why I didn't see this sooner. The knifemaker sold the knife today and sent me a picture of it with the sheath. So I do have a picture.- 4 replies
- finishes
- neatsfoot oil
- (and 4 more)
Thanks! I was going to post a picture of it here, but I can't find one. I guess I really didn't like it. Well, next time.- 4 replies
- finishes
- neatsfoot oil
- (and 4 more)
Thanks, Bill. I'm fairly new to this and have only made knife sheaths. You guys have been making my product better and now I want to branch out. I've looked at the Stohlman book and wondered about getting it. I need all the help I can get.
- 4 replies
- construction
- cylinder
(and 1 more)
Thanks! I tried searching the forum with things like "cylinder" and got sewing machines, and "lens case" and got something else. I'll watch this.
- 4 replies
- construction
- cylinder
(and 1 more)
I live in mountains with hiking trails. I like my hands as free as possible, and I'm thinking of making a lens case with a strap on it: a cylinder with a bottom and a lid attached with a small strap because I'm good at losing things. I'm not sure how to attach a bottom to a cylinder. As I'm typing I've decided to go look at some arrow quivers -- but good suggestions are welcome. Thanks in advance.
- 4 replies
- construction
- cylinder
(and 1 more)
Thank y'all. I've got the same dye, and I'm gonna take that advice about the superglue on a toothpick. My biggest worry was that it would catch on something and tear off and look worse. And, thank you all for the encouraging words. I love doing this. I see my job as a sheathmaker, as well as making something really useful (I don't like straps and studs or snaps cuz they're a pain in the butt in the field, so I like to get them to hold the knife tight even upside-down, but still go in and out easily), but also, like a picture frame. I try to make something that helps it look good without distracting from the beauty of the knife and handles. The guy I work with makes really attractive knives. This one has an old two-centavo piece with an eagle on it set into the antler crown, and it's a 52100 Bowie. I can get pictures of it easily, if you'd like to see. Thanks again.
I made this knife sheath a few years ago, before I knew all the things I know now. Still, it's a big knife, and the antler made curves and nothing's flat or straight, so I was pleased to make a sheath that fits this well and is handsome. I deliberately didn't do any stamping or tooling because I like the dark leather and the antler just like they are. My partner's had an inquiry about the knife. It's been put away for a while and tonight I noticed a little flap-cut near the top. He asked me if there's anything I can do for it. My first sense is, anything I try to do is likely to make it more visible. If someone's got a good idea for me, some kind of glue I could slide under there maybe? I might be brave enough to try it. Thanks in advance.
Boy Howdy, Thank you! I'm making 9 knife sheaths right now. I used your technique. I've got repetitive strain things in my hand, so my partner made be a burnisher by wrapping a 3/8" dowel with denim so I could chuck it into a drill on low speed. I don't have glycerine soap: I've been burnishing with water then saddle soap. I did a finish pass with a piece of caribou antler, then edge-dyed a couple of the belt loop straps and top edges of the sheath, waxed and buffed them. (Those parts are hard to do after the sheath's done.) I've never done anything that looked that good. Thank you.
Contact Cement My Nemesis - Dear Lord Someone Help Me!
MorningStarL replied to Windrider30's topic in How Do I Do That?
I've done it too. Sometimes, if I'm dying black, I'll go over the spot with a permanent black Sharpie marker before I finish coat. That helps. -
I'm almost finished with a knife sheath that I'm not really happy with, but the knifemaker likes it. It's got an iguana skin insert and I made the window a little too big; it's in the curve of front to back. I padded it before I put the liner in but I don't like how that worked either. Still -- I'll do another and it'll be better, right? My question is -- how do I finish the iguana skin? The top layer of the sheath is 9-10oz vegtan, lined with 2-3oz. I've dyed the leather black and put a light coat of neatsfoot on it this morning. I put a little on the iguana skin too -- it's old and looked a bit dull. Don't know if I shoulda done that or not. I'm going to put some Resolene thinned half with water on the leather -- does that go on the iguana skin too? Thanks.
- 4 replies
- finishes
- neatsfoot oil
- (and 4 more)
Adult area on Leatherworker.net
MorningStarL replied to Johanna's topic in Announcements and Administrivia
Me too, please. -
Thank you all. I'm learning so much here, and my work's improving. I want it to keep on improving.
Thanks, everyone. Richard, do you use a finish coat over the neatsfoot oil? And if so, what? I'm gonna start a jar of vinegaroon tonight, but I'm going out for dinner with two good-lookin' men first.
I'm going to try that. I've been away from leatherwork for over a week -- work deadline I wasn't sure I was going to make. My partner says he's sure there's some around here somewhere -- he made it to use on walnut shelving. Be a lot easier just to make some from scratch tomorrow.
Bingo! I used to always clean off a sheath with rubbing alcohol last thing before I dyed it, and once I read your reply, Gump, I realized I've forgotten to do that at all this winter. I bet that was it. Do you think if I went back to it now and cleaned them with alcohol and tryed the dye again, it would help? Or is it too late? The mink oil should have penetrated by now. Thanks for the reminder.
I never thought of that. My partner's used it on wood. I'll see about brewing up a batch. I know now that part of my problem's been that I'm not leaving things to dry long enough.
Thanks. I just found out there's a dyes and finishes forum. I'd only searched this one.
Thanks, everyone. I'll ditch the mink oil. I thought it would do what I wanted because the tin says it is a sealer and has silicone in as well as lanolin and the mink oil. I'll try dip-dying when I use the USMC black. Small operation here and I never buy more than a quart - it's half gone now - so I've never dipped them. It would make some of the little crevices from sewing on the belt loops easier, for sure. I'd still like to find something that isn't glossy for the finish coat. Just going to keep on trying.
