Docado
Everything posted by Docado
Look up “Tips and Tricks for Cobra Class Equipment “ explain your problem and someone will help you.
In addition to above comments. What helped me most was to have my stitches set to a length that I knew. For instance if stitches were set to 6 per inch. I would mark material at the place I wanted the corner stitch to end. I would then measure 1/2” before I would reach the corner in my stitch line. If I positioned needle correctly at 1/2” mark, it was almost certain to be placed correctly in the corner mark. That also gave me 3 stitches to adjust if needed.
Deeter Custom Saddlery makes a buckstitch lacing needle that fits in a cobra 3/4 sewing machine. They also have a video on how to get it set up in machine. Others also make similar needle. No affiliation with any of manufacturers.
Hello Try doing a search for "Information on Classic Cub manual stitcher" on this forum. It will give you a bit of information at the very least. Congradulations on your purchase. Kirk
Hello Alex Yes I still have clicker and it's available. Still works fine, I just used it a couple of weeks ago. Thanks for your inquiry. Kirk
Hello You might want to take a look in classified section. It seems to be on ebay also. Its not a byler. But it might do for your needs. No connection. Just trying to help. Good Luck. Kirk
Brother LS2-B837 Sews Forwards But Fails in Reverse.
Docado replied to LunarConcepts's topic in Leather Sewing Machines
Congradulations! Glad you were able to get everything worked out. Thank you for reply back and on how you were able to fix problem. -
If i was having this problem, i would try sewing in reverse first, on a test strip of course. If it was stitching correctly in that direction, I would start stitching in the forward direction over the top of previous stitches (reverse). If it them birds nests or messes up, it would appear to be more related to needle size than the reverse direction. In that case I would change to the next size larger needle. If there is not enough space in material where needle pierces along with thread being doubled up in same hole, it may cause problem you are having. Hope this helps. -
You can move alot of heavy items by placing them on a pallet / plywood (securly) and using 3 or 4 pieces pipe (pvc works well ) under pallet to roll on a flat surface. Nice Find. Good Luck!
- 24 replies
- adler sewing machine
- efka
(and 1 more)
Few Holsters off the Bench
Docado replied to Rohn's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice! Looks like a lot of hours of work, it shows. -
Yes still available. Sorry just say inquiry.
Best Way To Transfer Pattern For Decorative Stitching?
Docado replied to SantaFeMarie's topic in Sewing Leather
Use your sewing machine to "cut slits" for pattern without thread in needle. -
Hello Viking Queen When I have problems as you described; I unthread machine and rethread using a manual or some sort of instructions, making sure that I have thread going in or through everthing correctly. Check bobbin thread to make sure it is coming off spool in correct direction. Change to a new needle. I double check needle to thread size. Make sure machine is propperly oiled. Change to different thickness of leather. Your example is two thickness correct? What I see: knot is a bit towards top of leather on top thread. I would reduce top tension. Not much help I know. I'm sure you have already done all of these things. May help someone else. Good Luck Docado
I still have clicker for sale. Life sort of put this on back burner. Will take $2100. Kirk
You might try looking for "Jacques Shear". Good Luck
Here is a link to same company. http://www.cutexsewingsupplies.com/100-organ-7x4nw-dyx3ll-singer-7-class-leather-point-sewing-machine-needles
Hello JLS I found some on eBay. Seller was Cutex. They will sell 10 or 100. With 100, you can choose different sizes in bundles of 10. They were $86. Shipped. Organ 794 nw LL point. I haven't tried them yet, but they appear to be fine.
Which Sewing Machine Is Best For Making Purses
Docado replied to Mariel's topic in Leather Sewing Machines
If you go to try out machine, take whatever item that you will be making with you to sew. Sew it through from start to finish. You will then be able to tell if it works correctly or if it will do what you need for it to do. I would make an appointment and explain what you intend to do. If seller doesn't have time for you to do this, I would look somewhere else. There is nothing worse than spending alot of money on something that doesn't do what you need for it to do, or needs major repairs. That way you will gain a better understanding of what you will need instead of just burning gas and wasting your time. Good Luck! -
Hello I would try using a larger size needle. Look at pinned links for needle, thread sizing.
Hello This is not exactly what you are looking for, but may give you a lead or more info. I know nothing about it, just found link. Also has other heavy duty machines for sale. http://eastoregon.craigslist.org/art/4951126535.html Good Luck !
Maybe this will work http://dixiesewingmachine.tzo.com/MANUALS/PFAFFSERVICE/145%20545.pdf Good Luck !
Hello Amuckart, Do you by chance have an Artisan Toro 4000 series manual? I found it on here somewhere. It may be of some help to you. Docado
- 19 replies
Try checking your guard that covers the belt and pulley or speed reducer. It might have got shifted and when you start sewing, it jumps slightly and hits the edge of guard.
- 9 replies
- belt slippage
- pully bearings
(and 1 more)
Make sure thread is not getting wrapped around little screw and thread guide on it's way down to needle from take up lever. It happens when you are repositioning or removing a piece of material. If you pull extra slack in thread with left hand it sometimes loops around the guide. If unnoticed it will cause excess pressure on top thread causing bottom thread to be pulled up through material. Good Luck.
U might check into U-ship..
