Yetibelle
  • Content Count
    358
Everything posted by Yetibelle
  1. I think your going to need a Right Angle Binder/Folder attachment. You can search for an example on YouTube. I think it all depends on the seam you want and how thick the binding leather is? For thicker seams I would first glue and clamp it then just sew over it once it is set in-place.
  2. I have used Sharp Sewing Supplies via e-bay. They have most of the parts for the older machines and they are priced well. They have a few Complete Tension brackets that say part 240446, some are less than others. I see one for $10.39 that looks like a good deal.
  3. Well the first thing I recommend is a quick Google search for REX 26-188 parts. It is exciting to get a good deal on a quality machine, but it is a real bummer when you cant find the parts for it, or have to pay a lot for parts since they are no longer made. I bet it has a clutch motor and you will need to replace that, they are power hogs and crazy fast so that's another 130-150 bucks for a new motor. That is why I would recommend an old Singer machine. There are plenty of parts most at a good price plus they invented the sport. If you just want to sew canvas and leather with a straight stich then you could start with a small machine like the 201-1 and get leather needles at any sewing super store. The 201-1 is a small tank, they can be found cheap, easy to move and repair and lean the basics on. If you want a machine that is a lot of fun for cheap get a Singer 401a Slant-o-Matic. They can do a variety of stiches still an all metal machine that is way better then any $500 new machine. But if you are still set on the big machine get the a Singer 111W machine with a Servo motor. It will take on just about any project under 1/2 inch, but with this machine you will have to get the parts from a commercial sewing store rather than a local store. remember to make sure it works before you buy it bring some test material along with you to try it out. Good Luck
  4. We really need some video of this machine in action. There is no good video of a 97-10 on YouTube.
  5. You need to save up at least $1000 for a decent used leather machine, I will explain. You will be tempted by the "great deals" that can be found on Craigslist. Sometimes they are great deals however buying a 50-100 year old walking foot sewing machine can be tricky. Most of the parts are probably good but you may need a few new parts, and you will need the correct needles and thread (they can't be found at Jo-Anns). This process is not unlike getting a classic car be prepared to invest time and money. I have found that used machines typically cost 2x the purchase price to get in working order. So if you pay $300 for a Singer walking foot machine like a 153, or a 111 expect to pay up to another $300 to make it work perfectly. Typically there are plenty of parts however they are not all cheap and then you have to figure out how to replace the part and then readjust the whole machine, sometimes without the manual. The next issue is the old used machines typically come with a clutch motor. The clutch motor while super strong and fast is a nightmare. Sure there are tricks to slow it down, swap pulleys, add pulley speed reducers, add bungee cords, it will drive you nuts. You lightly tap on the pedal and zoom the machine takes off and your project looks like Frankenstein. So you will need a servo motor. They will give you control over your project. So now you have your $300 machine that needs a new bobbin case ($40.00), new servo motor ($150) , few packs of needles and thread ($50) a six pack of beer for your buddy who helps you carry all this ($10) since it weighs almost 200 pounds. Now your up to $500 and you still have not sewn anything. I recommend looking for a machine that already has the key features you will need, servo motor, extra bobbins, needles, bobbin case (shuttle), thread and extra feet attachments. Bring a few test scraps of leather with you so you can test sew. If it is set correctly you should be able to walk up power it on and sew a line without issue. If you hear anything grinding, the thread getting tangled in the bobbin or breaking, the stiches look bad or very loose I would walk away and keep looking. However if it has all this then you should be in good shape. Bring a flashlight with you so you can look the machine over. You can't see all the little parts without good light. If your missing a few tiny screws in the wrong places the machine will kind of work but not exactly work well. They you will be so angry when you have to order .89 cent screws and pay $10 in shipping to get them. Also because this bothered me when I started- Why do they all look the same? The new machines are practically all based on the old machines and this is why they all look similar. If you look at similar model lines from Consew, Techsew, EconoSew, Cowboy, Juki they are appear at first glance to be the same machine re-branded. Adler and Phaff also fit into this but they have a few features and parts that are unique to them. All of them in the correct model machine and configuration servo motor can be setup to sew leather, plus the have probably have reverse. Just like the 75 year old Singer they can run almost forever. However because they are new or slightly used they will not have the issues I described above with the 75 year old Singer. You get a clean machine that is ready to sew. Expect to pay $800 plus for a used system like this, up to 4k for a new one. I can't recommend a one brand over the other, what I can recommend is that you visit you local industrial sewing store and see them for yourself. This will also help you narrow your search because you may want a post machine over a cylinder arm machine, they will have all the machine variants to look at. Good Luck
