Everything posted by dikman
I'll have to ask you chaps, 'cos I'm stumped. My 211G166 has started misbehaving, and is forming loops (of the top thread) on the bottom. (#69 thread, size 18 needle, white on top brown in bobbin). It will stitch ok for 2, 3, 4, 6" and then start making loops. I've played with tension settings on the top and bottom threads, but it didn't help. I stripped and cleaned the thread tensioner and the takeup spring, all appears to be working as it should. I increased the tension and travel on the takeup spring, but it still happens. Seems to me that if the takeup spring is the problem then it should happen all the time. I tried a bigger needle (size 22) but it still happens. Not a good day, I switched to the Pfaff and now that's decided to start being stupid! Any ideas welcome.
You're both close. I threaded the needle right-to-left, it should be left-to-right! Which is what it says in the manual, but of course I didn't read that bit I just looked at the picture!! I put it down to another "senior's moment", I just had it in my mind that's the way it should go. It looked like the hook/shuttle was picking up the thread correctly, but in reality it was putting a twist in the two threads (which I thought I saw but wasn't sure) under the needle plate, and twang! While I feel dumb about it, on the positive side I now understand the machine much better and I know the adjustments are right.
Video: Binding Operation On A Durkopp Adler 205-370
dikman replied to Uwe's topic in Leather Sewing Machines
Excellent video, as usual Uwe - but your machines are just far too clean! It's not natural! -
Yep, usually called a shoe or boot patcher. As Wiz said, they're designed to get right down into a shoe or boot and the "head" (not sure of the correct term) allows the sewing direction to be easily changed without having to turn the work itself.
Yep, that's the one I've got. That thread size is probably the optimum for what you want to do - as long as the soles aren't too thick. Mine came with two thread tensioners, as in the link you provided. Don't know why, unless one is a spare, so I took one off. Make a careful note of how the bobbin carrier fits in relation to the needle position, as it's easy to remove it and a pain trying to line it all up again if you don't know how it fits. The bobbin winder on mine was pretty useless, so I made a replacement from bits and pieces that I had. One of the forum members, Darren Brosowki, sells a decent replacement bobbin winder for them (he also sells the machines).
Tag, there's a few posts on the forum about those Chinese shoe patchers (I've got one myself). There are also a few vids on youtube. Probably the best thread to use is a bonded polyester, size #69 (Tex70). The bobbin is too small to use anything heavier. The machine itself can benefit from smoothing down some of the sliding parts and making sure that they're well lubricated. They might look rough, but they're a nice little machine. I see Wiz got in first , I was half-way through typing and the phone rang.....
You did real well with that deal, it looks pretty clean considering its age! Plus all the other bits and pieces AND manuals (I've never seen one for the light, which I have on one of mine), a rarity in itself. I'd be very interested in a good scan of the manual, as it covers the 153 (which I think one of mine is).
Thanks Ralf, even if I can't read the words, there's some great drawings in there. I'll have a closer look later. "Complete" makes sense, as part 9636 would then include the eccentric that fits over the main shaft and the outer race that it rotates in. I can see where slightly different sizes could then vary the max/min stitch lengths available. Which means I'm stuck with a minimum of 6 spi, but it's workable.
Thanks Ralf, I would say that there has to be an adjustment inside somewhere, I just don't see them making separate components for each machine to get the stitch length. Mine, by the way, is labelled 335-17B and underneath that is L (no idea what L means). I've just had a closer look (again) and the only adjustment that I can see anywhere is that eccentric (part #9633). I'm beginning to wonder if they do, in fact, make different size eccentrics to fit on the main shaft to give different stitch lengths. Constabulary/Ralf, what does "vollstg" (part #9636) translate as? Assembly?
Uwe, one of those pots came with my 111WSV77 (appears to be the same as a 111W153). It took me a while to figure out how it was supposed to fit the machine! I gather they normally only came on 155's? Gump, that's a monster motor! I thought their motors normally ran at 1725 rpm, yours must have gobs of torque!!
I'm always learning something new. What Uwe said makes sense, considering that Singer back then was a world-wide conglomerate. It probably made perfect sense to ship parts every which way just to make up machines. The fact that there were different metal threads used by different countries on their nuts and bolts could make such machines "interesting"! I noticed that motor too. My 51W59 came with an original Singer motor, which is big but doesn't appear to be as large as this one! Teched, any chance you could post a couple of photos of the motor?
Power hacksaw blades make pretty good knives (just don't overheat them if shaping with a grinder).
Ok, referring to your first picture - the adjuster lever (9612) is already resting on part 9626 at the bottom of its travel. No plate holding it back. the screw (64) isn't an adjuster, it secures the adjuster lever to part 9606. by carefully grinding the front plate (9626) at the bottom, I managed to lower the adjuster lever just enough to give me 6 spi. Part #9633 is an eccentric that fits on the main shaft, and is held on by two screws at the back. Its position affects the spi. By loosening the screws and shifting it around I can change the spi, but I can't get any better than 6spi. I'm still trying to figure out how moving the lever changes the spi .
Makes sense about the short stitches, being originally a binder. I've already removed the binder parts and replaced the feet and needle plate/feed dog to make it a "conventional" stitcher. It works well, except for the stitch length. I'm about to go out, armed with your first photo, and start poking around in the innards!
Teched, it's extremely difficult to date W series machines (made at Bridgeport, USA) because there doesn't appear to be any surviving records for them. If you can download a manual, and it has a print date, then that's probably about the best you can do. Just enjoy it, knowing that you have a lovely old Singer.
Thanks Constabulary, that could be quite a help as I can't see inside to get a clear picture of what's connected to where. Mine already has full travel on the adjuster (9610). I see there is an adjustment screw, #64, that might have something to do with it (if I'm lucky), but first I have to figure out exactly how it changes the stitch length. A photo -
My 335 is one of the older type models, and technical information on them is rather scarce (other than what's been made available here). The meagre info I have says it can do 5 1/2 spi, but mine won't do less than 8 spi. Anyone know if there's an internal adjustment where I can get it to 5 or so?
I knew this machine worked, although I hadn't actually run any thread through it. All I did was set it up with a servo/speed reducer and made sure it could punch holes in leather (I've been too busy building and fitting out a shed for my machines, plus set it up for reloading ammo). Anyhow, I have a couple of belts to make, so figured I'd better get the machines working. I loaded up the 211 with thread, picked up the bobbin thread, ran 1 stitch and the thread broke!! After a bit of messing around it looked like the hook was catching strands in the thread. So, I reset the needle bar height, but it still broke (it appeared to be breaking somewhere under the needle plate). The hook felt like it had a burr on it, so I smoothed it out with a diamond file. Still broke. I reset the timing and shifted the hook a bit closer to the needle. It seemed to stop catching the strands, but still broke. Closer inspection showed that the thread was being picked up and feeding around the bobbin case ok, but then I thought that the needle was piercing the thread as it went down (as some of you probably know, it's a bit hard to actually see exactly what's happening due to having to have some of the bits and pieces in place). The check spring was working ok, but then I thought it looked like the threads were twisting under the needle plate, but couldn't be sure. I'd been working through the manual, checking and adjusting anything that looked like it might have helped. After a few hours, I was stumped. Eventually, I found the problem, but before I tell I'm curious whether anyone here can guess what it was. I also threaded up my Pfaff 335, but that wouldn't pick up the bobbin thread! That required pulling quite a bit of stuff off the end to see just what the hook was doing. The adjustments didn't look too bad, but unless the thread had no tension at all it wouldn't grab it, so I reset the needle bar and shifted the hook a bit closer to the needle. That did it, and it now works fine. In fact, I reckon it sews better than the Singer, it just feels real nice to use (I think I'm going to like this machine, it was a bargain for what it cost me). All in all, an interesting, if somewhat frustrating, day.
My 211G166 doesn't have an auto-oiler. Also, on the 211 the handwheel is cast to include a bushing that fits inside the head and around the shaft, it's not just a matter of fitting a different pulley. You can machine a replacement, of course, but there's a bit more work involved. One thing I soon realised is that, as in most things, there isn't one machine that will do it all (unfortunately). The machines you're talking about will probably do most of what you want, and do it well, but sooner or later you'll probably run up against the limitations of a flat bed machine. Also, be warned that, in some strange way, industrial sewing machines, and the collecting thereof, can become a bit of an addiction!!! Having said that, from everything I've read the Juki sounds like a nice machine.
Mmm, I can only speak about my servo(s), but there is a setting for the max speed, and this determines the sensitivity at low speed. If I want very slow speed control then I need to set the max speed lower than it's capable of. Conversely, if I set it to its max speed then the slow speed control is touchier. Like everything in life, it seems, there are always tradeoffs. No big deal for me as I'm looking for slow speed control. Which machine do you want to put the servo on?
It will still run up to speed quickly, the reducer will have minimal effect on that, what it will do is limit the maximum speed depending on the pulley ratios. You don't necessarily need both, it all depends what you're trying to achieve. Those who are trying to get really slow speeds generally aren't worried at losing their high speed so it's not an issue. If you still need fairly high speed then it's going to be a balancing act, juggling servo speed settings and pulley sizes. I've also replaced the handwheel pulley on a couple of my machines with larger pulleys. This is another way of adjusting speed and ratios without fitting a reducer. For example, my Pfaff has a servo, fitted with a 1 3/4" pulley and the handwheel has been replaced with an 8" pulley. This gives very slow control but it is a little notchy (glad you mentioned that, TT, I thought it was just my motor) so I'm going to experiment with a larger pulley on the motor and adjust the servo settings to see what difference it makes. The relatively low cost of servos these days has been a boon to us newbies as it makes it so much easier to control what are often high speed machines, without having to try and master a clutch motor (I still remember the "excitement" the first time I put my foot on the pedal of my first industrial Singer - scared the daylights out of me!!!). In fact, I've just ordered my third servo, for this particular machine.
Fitting A Nakajima 380 In A New York Apartment
dikman replied to zacb's topic in Leather Sewing Machines
No doubt about it, Uwe, you have a knack for lateral thinking. That machine is just too clean, by the way, please get some oil on it!- 12 replies
- nakajima 380
- industrial table
(and 1 more)
I just had a closer look at your table, and that leg arrangement is decidedly unstable for the machine! Like the man said, fitting the feet to a large board would definitely help.- 12 replies
- nakajima 380
- industrial table
(and 1 more)
Yep, I have two W machines, and while you can often find manuals for them there's no information available about their history.
- 5 replies
- singer 18-2
- old singer machines
(and 1 more)
Others have made smaller tables for their cylinder arm machines, but none quite as small as yours! As you found, stability is the biggest problem, due to the weight of the machine so high up. You may need to try and widen the feet to make it safer. Keep at it, I'm sure you'll get there. Certainly looks nice and compact!- 12 replies
- nakajima 380
- industrial table
(and 1 more)
