Everything posted by dikman
I must admit that I'm surprised that it's not 15 mm (particularly as it appears to be your basic Chinese servo). We live and learn. The keyway is pretty standard, and is the same on all my Chinese-bought pulleys, plus the locally bought ones (same thing) and also the two generic clutch motor pulleys. As there's only 2 mm difference, you could try some thin sheet tin or aluminium to sleeve the shaft, cutting a slot for the key. If you can get a snug fit then it should be pretty close to centred and tightening the nut should lock it in place. Considering that you don't intend running at high speed it should work fine.
My first thought was "they don't know what they're talking about!" Unless they had that motor specifically made for them (unlikely, as it's similar to several other brands for sale on AliExpress) then the shaft will be 15 mm. I also have two generic clutch motors, both a few years old, and both have 15 mm shafts. Like I said, the guy at the shop (who has been in business a long time) said that 15 mm is pretty much a standard shaft size for industrial-type sewing machine motors. Don't take their word for it, remove the pulley and measure the shaft, that way we'll both know.
What a wife! She deserves a .
Best Servo Motors For Singer 211G Walking Foot
dikman replied to Silphion's topic in Leather Sewing Machines
Nothing wrong with more toys!! Although.....I started off handstitching, and was pretty happy with that, but one thing led to another and I now have 3 industrial machines and am currently building a shed to put them in (so that I can actually use them!). So be warned.....- 5 replies
- servo motor
- singer 211g
(and 3 more)
Kangaroo? It's relatively thin and tough.
I don't know anything about the Family Sew other than what I've read here, but the price is pretty good for a servo, and if you are likely to be varying the speed a bit then the knob control will be much better than the little push buttons, as Art said. The other one is pretty typical of a plethora of servo motors coming out of China. They seem to be constantly trying different ways of housing them! I wouldn't pay much attention to phrases like "Step Stitching Technology" (what does that really mean?) it sounds to me like a bit of advertising jargon. I bought the optional needle synchronizer with my first servo from China, but took it off. I set it to stop needle down, but found that when I took my foot off the pedal it gave one more stitch so that it could stop needle down. If you don't allow for this when sewing then you end up with an extra stitch. Very annoying. Mine is on a 211G166 and I have also fitted a smaller (1 3/4") pulley to the motor and a speed reduction pulley in order to get the slow speed/torque that I wanted.- 5 replies
- servo motor
- singer 211g
(and 3 more)
Vinculus, the Chinese servo should be a straight swap for the existing motor (mounting points the same). The only thing you may have to do is buy a replacement belt as the pulley spacing may change slightly. I notice it comes with a 75 mm pulley (most do) but you can pick up a 45 mm replacement pulley pretty cheap on ebay from China. I strongly suggest you consider getting one - I fitted them to my two servos - as it will help with getting the lower speeds. Sandyt, an impressive job with the pulley on the G166. I tried the same thing on mine, but found that the design of the existing handwheel created a problem - the handwheel has a sleeve, for want of a better word, as part of the wheel, that fits inside the main bearing on the head. Without that sleeve I found the main shaft could oscillate, which was not a good thing! So I didn't fit a larger pulley. Curious how you did it.
Sark, I'm guessing that the second photo is the "before"? Either that, or you've gone overboard with the "used look". My three used tables are a bit the worse for wear. I toyed with the idea of refurbishing them, but decided it was more trouble than it was worth. Your idea of picking up a cheap one is actually a good one, and as you point out could be less than the materials required to build one from scratch.
- 178 replies
- diy sewing table
- industrial sewing table
(and 3 more)
Can't argue with the price, Rayban. Elthoma, that looks like it's meant for winding coils for electronics, judging by the fact it has a counter. Neat idea using a drill chuck.
Patcher, Refurb Or Go Inexpensive Chinese
dikman replied to Ole South's topic in Leather Sewing Machines
Being in the good ole US of A as you are, I've no doubt that you won't have too much trouble finding used ones, unfortunately here in Sth Oz they definitely are rare! Nope, not a common mod that I'm aware of, or a flaw. Most users that I've come across use them as is. Whilst it's not exactly a work of art, I actually quite like it because it is so different to anything else I have (very "agricultural"). -
I've figured out the two thread sizes - the edge binder nut is an M4 x 0.7 pitch and the pressor tension is M5 x 1.0. I have a lot of (assorted) metric bolts used in various electronic/communications assemblies/racks/panels etc, and not one of them has that particular combination of size and pitch. It appears that, at least in that particular industry, they are not "standard" sizes (e.g. M5 only comes in 0.8 pitch and I have to go to M6 to get 1.0 pitch). My tap and die set covers M4 x 0.7, but not M5 x 1.0. At least I now know what I'm looking at.
Yep, those Chinese patchers aren't the prettiest thing around, but they are designed to be a simple, no-frills, inexpensive machine that will work anywhere and be relatively easy to fix if something should go wrong. Where I am used 29K patchers don't appear to be very common (I haven't come across one for sale in the year that I've been looking for machines) so I bought a Chinese one. It required a bit of work to clean it up and mod it slightly, but all that took was time and no cost. -
Thanks guys. I've already run into the issue with Singer, so I bought a couple of cheap machines and gutted them for parts. There are two bits I'm looking to fix at the moment on the Pfaff (it's an old model, btw, not the one in the parts list that Uwe provided), one is the screw on the top that adjusts the presser foot tension, the other relates to the edge binder - one of the brass "nuts" is missing, and while I can easily turn a new one I can't match the thread size of the existing bolt! A 3/16" Whitworth actually almost fits the top adjustment screw, it screws in ok (with no forcing) and does work, but I can feel that it's not quite a perfect fit. Judging by that chart, Uwe, it appears that there is significantly more variation in screw threads than I realised! (My life was somewhat simpler before I got into sewing machines - I usually needed either Whitworth, very occasionally a BA thread, metric - reasonably standard size/pitch - and, in the case of old firearms, the US system of sizing. Now I'm faced with all manner of weird thread sizes. ).
My Pfaff 335 needs one ot two bits replaced, but I'm blowed if I can figure out the metal thread system used. Being a European machine I assumed it would be metric, but while I have a large assortment of metric screws, nuts and bolts (and a few taps and dies) I've had a devil of a time trying to match the threads used. Anyone know for sure what they use?
Actually, the epoxy idea is a good one. Make sure the feet are thoroughly degreased (acetone should be suitable for cleaning) and use a good quality epoxy - JB weld or Devcon. Once it's set it can be shaped and smoothed if necessary. Might be easier for you than trying to grind off the feet.
- 11 replies
- presser feet
- econosew
(and 3 more)
Excellent job, Constabulary, I've added it to my growing collection of paperwork!
And so it begins...... .
Sewing Machine Singer Heavy Duty 4432
dikman replied to eddiekazan's topic in Leather Sewing Machines
Eddie, you can pick up suitable used machines on Gumtree, BUT you need to know what you're doing. There are a myriad of "industrial" sewing machines out there, but the vast majority aren't suitable for sewing the sort of leather that we want to use. You really do need, as a minimum, a walking foot machine, ideally with a servo motor if you can afford it. If it's not a walking foot then don't consider it. It's quite a steep learning curve, for a newcomer, to come to grips with understanding industrial leather sewing machines. (Personal experience talking here). I was given a Singer, and then bought another used Singer and a Pfaff. I have spent a considerable amount of time (and some money) since then to get them to what I consider a usable stage. Now, I'm quite happy to do this, because I like tinkering, but this is what can happen when buying used. Also, some used machines have ridiculous prices attached to them (these are usually the ones that remain unsold). Yes, new machines are pretty expensive here (compared to o/s) but at least you will be getting a machine that will work without having to spend time and money sorting it out and will be a known quantity in what it can do. Plus, if you should have issues then you'll have expert help to sort it out, unlike used where you're basically on your own. -
Yep, it has a binding attachment (don't know how I missed that!). As Constabulary said, you may need to replace the needle plate, feed dog and the feet if you want to use it for "normal" sewing. You need to check that out first and make sure you can get the parts needed.
- 14 replies
- sewing machine
- sewing
(and 2 more)
Certainly looks pretty good - been repainted?
- 14 replies
- sewing machine
- sewing
(and 2 more)
I still prefer my piece of rope . As LumpenDoodle said, it's idiot proof (probably why I like it). No maths, no calculators, don't even need to log onto the computer to use it. Rope of the correct diameter, however, will be better than string as it will fill the pulley grooves. (The guy at one shop had a measuring device that basically stretched the belt/rope/whatever between two half pulleys, mounted on a ruler. That way he could read off the exact size that I needed). Anyway, maths makes my brains hurt.....
Which is what I said a few posts back.......so it must work. The parts list shows two grub screws holding the handwheel on, spaced around the wheel. If it still won't budge you could try tapping it GENTLY with a rubber/plastic hammer. Failing that it may need a pulley remover to exert some pull on it. As for the belt guard, in the parts manual it looks like you should still be able to change the belt without having to remove it. Art, you're a bit of a worry........
Art is right, it will work ok like that but it's probably better to have the thread coming in at the rear (I'd prefer to keep the thread away from the handwheel). I doubt if too many servos would come with belts, mainly because you don't know what size belt you'll need until it's installed. I ran a piece of rope around the pulleys and tied it off with cable ties where it overlapped. Armed with this I went to autoparts stores until I found the right size. I also used the same trick when I needed a very small belt for a speed reducer setup. Figuring carparts stores were unlikely to have anything that small, I went to an industrial sewing machine shop.
