Gymnast
Everything posted by Gymnast
My answer is, that it is a bit more expensive, to make a motor drive with good low speed control, and there is not sufficient demand in the market for that. EFKA do make expensive motor drives for sewing machines with a wider speed range. In more technical terms, you got an issue with measuring the speed of the motor. For my drive I use another DC motor to measure speed, at it provide a very fast response. But it got brushes that will wear out in time. The normal way is to use digital encoders of some kind. For good low speed control, you need a speed loop response of within about 1 ms. If you have got an optical encoder of 100 lines (as I have seen on some the servo motors), the minimum speed will be 10 rounds/sec or 600 rpm. You can get more expensive encoders with 1000 lines - and then you get minimum speed of 60 rpm. But some of these encoders can then get problems at high speed due to a high optical frequency. There is more ways to measure speed, but in general it is not that easy, and it can become more expensive to do it. Another issue is how you control the winding current. The cheep way is to use three digital hall sensors in the motor, and it becomes a somewhat raw way of control the winding currents at low speeds. It is the old way of doing it for BLDC motors. More modern principles use the term Field Oriented Control, FOC, and they use other more expensive ways to measure the position of the rotor of the motor, and they use current waveforms near sine waves. But I think the pedal could be improved without extra costs, and it puzzles me why no manufacturer have made a change here. You need to focus on the force, that your foot provides on the pedal, because with your muscles you can control force much better than a position. For me the lowest speed is with a force of 4 Newton (0.9 lbF) on the pedal and 40 N (9 lbF) on pedal at full speed. For some pedals it is like 20 N for lowest speed and 25 N for highest speed, and to me it makes the machine much harder to control.
Needles breaking on Singer 15-91
Gymnast replied to lukeoliver1776's topic in Leather Sewing Machines
The sudden change could be, that the needle changed height by the needle is not sufficiently fastened or the fixing of the needle bar to the crank shaft is loose. So I recommend that you check the height of the needle bar. Have you got the service manual? The other thing to do is to remove the shuttle hook and clean this area for possible remains of thread. The shuttle hook always need good lubrication at its race. You need to use leather point needles as Wiz already wrote. -
Thank you for the moved post and answer
Thanks. I did not know about this trick. But then Google helped me to look it up, and it did not show up that many places. I found it here by Bernina: https://blog.bernina.com/en/2023/02/sewing-needle-and-thread/ I tried it on some known threads, and I think it will work to discard too small needles. My 207 thread and 140 needle was on the edge. But Google directed me to this other similar method as well proposed by Groz-Beckert: https://youtu.be/4fsQGtMSFEQ?si=2CGPJffRur3sgU8x&t=121 I think this method will accept too small needles.
I am just confirming the remarks by others. Something is wrong, when the hook hits the needle like that. Make sure, that you do not use a bended needle. It could also be the presser foot or feed dog that push the needle towards the hook. You should also make sure, that the hole in the presser foot and feed dog got sufficient size to the needle size you use. I think the machine manual should inform you about that. For my machines I got almost all sizes of needles, so I am able to alter them for different threads and fabrics I sew. The right needle size for V207 thread is above 140, but I have sewn some vinyl with a V207 polyester thread and 140 needle, so it is not like it should be impossible. It do also help to use leather needles for leather. The thread manufacturer will normally provide you with information about the right needle size. This is an example of that: https://www.amann.com/products/product/serafil/
In connection with my experiments with making a DC motor drive, I had the opportunity to measure the motor current consumption for a sewing situation. For DC motors, the current is close to proportional to the delivered shaft torque. I'm fine with getting some measurement results with numbers on some situations to get a better understanding. But for normal users I don't think it has any relevance. Maybe the knowledge can be useful if you want to experiment a bit with which motor you want on a sewing machine. The curve below shows the DC motor current over time for just above one stitch. The driver electronics ensures a very constant motor speed. This video shows the current situation used when the power consumption was recorded: https://youtu.be/N-FB2jHYyuw The measured mean torque here is approximately 0.5 Nm, while the maximum torque is approximately 2.3 Nm. This corresponds to a peak pressure on the sewing needle equivalent to 145 N (15 kgF or 33 lb). For these slightly more powerful household sewing machines, I use as a general rule to limit the torque to 3.5 Nm. My guess is that industrial sewing machines for leather can generally withstand a significantly higher torque. At higher speeds of the sewing machine, you will be able to get help to penetrate the material by taking the energy from the inertia of the motor and flywheel, which then briefly reduces speed. At low speeds of the sewing machine, there will typically not be enough rotational energy for it. I guess that for larger leather sewing machines you will also see a correspondingly large variation in the torque that the motor must supply to the sewing machine at low speeds. If you want to know more about the specific setup with this Pfaff 230, there is more information here:
vintage Singer 201k for edge binding
Gymnast replied to TonyGreen3455's topic in Leather Sewing Machines
Thanks. Yes, I guess the CB-bobbin allows for thicker thread, but the 201 actually was able to handle this thread as well. I guess, that when you compare a Singer 15-91 and a 201-2 in the US, that have got the same potted motors, then you will find the 15-91 to be better, because the 201-2 require more torque from the motor to operate thicker threads. TonyGreen is from UK, and these machines are belt driven machines in Europe (with few exceptions). Belt driven machines got more possibilities for changing the motor power or using speed reducers. I agree with the Northmount and Wiz, that a walking foot machine is better for leather and jobs like this. But TonyGreen asked for advise on smaller household machines, and some of them can do some jobs too, if you modify them. -
Hello kgg My YouTube channel got some more videos with this sewing machine. This is a speed test with some remarks using the original motor: https://youtu.be/VLU_s1RGasA This is more about the mechanics regarding the new DIY motor drive: https://youtu.be/Ig69cM_0w7Q The pedal is like you see and attached to an air pressure sensor. Some electronics and an Arduino microcontroller is involved as well, but I have not yet made any "nice" documentation of that yet. To my knowledge, the important thing about the pedal is, that you need to have a large range of pressure applied from minimum speed to maximum speed of the machine. I use a pressure of 4 Newton (0.9 pounds) for minimum speed and 40 Newton (9 pounds) for max speed. So you got a factor 10 in pressure needed that allows for precise and fast control by the foot. The possible length of compression of the pedal have much less importance. When you using air as I do, you will have have a pressure change due to temperature changes (ideal gas law). Therefore a zero point adjustment are needed by some manual setting or by some software (I use software here). Furthermore the software implement some unilinear function, so you can get more accurate low speed control. I use parts of a parabola function. You are welcome to ask for more specific details, and I shall try to provide them.
In my opinion, the Singer 15 and 201 got about same performance. I think the Singer 15 is close to a Pfaff 30, and I have tried to make a comparison of a Pfaff 30 and Singer 201 with this video for heavier work: https://youtu.be/u2D2DEKtgFQ I think the possible limitations for the standard Singer 201 or 15 is the lack of low speed control and its possible max reliable thread tension. So you may look into doing a few modifications to the Singer 201, like making a speed reducer and using a heavier tension spring. -
I bought a Pfaff 230 about a year ago. It is a somewhat heavily built household sewing machine and can be considered a bit like a little sister to the Pfaff 138. Where household machines have typically been sold with motors with a maximum shaft power of 40 W, the Pfaff 230 was sold in Denmark with a larger motor with a shaft power of 80 W, which could make them sew at a maximum speed of approx. 1900 stitches/minute. According to German sources, the machine can withstand speeds of up to 2500 stitches/minute. Today's typical servo motors for industrial sewing machines have an input power of 550 W and a maximum shaft power of around 350 W. Since I don't have room for a fixed table with a regular servo motor, I decided to build a smaller motor drive from scratch as a little DIY project to see what could be achieved. But at the same time cheap components were used. The idea was to achieve a wide speed range, and the result was that the difference between the lowest possible speed and the highest speed became a factor of approx. 600. Lowest speed was 2-3 stitches/minute and highest was 1780 stitches/minute. Most available servo motors that you can buy have a minimum to maximum speed ratio of about 50. Most users here will probably think that the speed ratio of 50 is good enough, but maybe they haven't tried anything else. The reference may be the old clutch motors, which were more difficult to control. Here, for example, a seller who describes the sewing machine's lowest speed as super low: My assessment would be that the lowest speed here is far too high. At the same time I don't like how the machine jump-starts with no warning. This is a video with a demonstration of my DIY motor drive: I have now tried using the machine for a few projects, and I think the low possible speed is an advantage. This means that you get full control of the needle position via the pedal. A good pedal is also necessary to be able to achieve this. At the same time, the sewing machine can also sew quite fast.
I have studied a Pfaff 230 regarding the check spring motion. It is actually engaged four times each stitch. Can it be right? I think the machine works with no problem, and it sews with a max speed of 1825 stitches/min with a Tex 70 polyester thread with 4 mm wide zig zag in a 2 mm thick cotton webbing. The needle size is 120/19 with this task. The check spring stroke is set so it correspond to 11 mm motion of the needle thread. The tension of the check spring is set to 0.25 N (1 oz) at the point it engages the thread. This check spring tension setting is significantly higher than it was when I got the sewing machine, but this higher tension "feels" right to me. The clearance at the position finger bracket have been checked. The check spring is engaged when you have some tension in the needle thread and no thread slack. I made a video with the handwheel very slow turned, so you can see how and when the check spring is engaged: https://youtu.be/3vZr0fmwNsU The four times the check spring is engaged, seems to be caused by this: 1) The thread has been pulled down in max length and is around the shuttle. 2) The thread may be catching something at the hooks or shuttle, that shortly require some tension to pass. 3) The thread require some tension to pass the position finger bracket. 4) The take-up lever tightens and forms the stitch with the higher thread tension from the tensioner.
I have seen ISO 68 oil specified for some sewing machines as well. The number here refers to the viscosity at 40 C. You can get the same kind of white mineral oil up to ISO 150. Motor oil got some more additives, that you do not want in a sewing machine, and it typically have got a viscosity of about 100 at 40 C. A higher viscosity will make the bearings carry the load better at lower speed, but the loses and heat up of the oil may get unacceptable for higher speeds. If the machine have got an oil pump and some centralized systems to distributes oil around, then you should stick to what the manufacturer recommend. I use some ISO 100 oil in two of my vintage sewing machine, that I use for heavier loads and for lower speeds than it may have been designed for. The machine would normally use ISO 22. It is no big deal for you to alter the oil type with respect to your use of the machine.
Do you know of suppliers of very long upholstery needles longer than 0.5 m or 20"? For some odd experimental project I like to try to use such a needle. It needs to have a needle eye and one sharp point end. I guess, that it needs to be at least 2 mm in diameter and made of a piano-wire kind of steel. Do you know of suppliers of such long needles in North America and in Europe? I found this supplier of a 24" needle in Arizona: https://homesewingdepot.com/products/upholstery-needle-24-11-gauge?variant=32770271685 What size is a 11 gauge needle?
Now I have put a few numbers of sewing again... I know, that more experienced people here already have told us, that the same type of thread from a thread manufacturer are different. Different by color and different by batch. I did not think. that it mattered that much for the bobbin thread tension, but when I could not repeat the balanced stitch from some previous notes I tried to measure a bit more. It was a Amann Serafil polyester thread Tex 135, and for the same setting of the bobbin thread tension spring I got these measured bobbin thread tensions measured by a spring dynamometer: White: 0.5 N (1.8 oz) Black: 0.6 N (2.2 oz) Blue: 0.75 N (2.7 oz) This is a video about how I measure bobbin thread tension, but I guess many of you have already seen it: https://youtu.be/kINRgj42GnI
If you have looked the news recently, there have been a rapidly rising global concern regarding PFAS in the environment. Nine states in US have come up with strict restrictions on PFAS in products. EU is still talking about it for a long time. So I think everybody in our business needs to think about, what we use, and try to avoid products, that contain PFAS or creates PFAS when produced. Factories that produce PTFE (Teflon) are leaking PFAS to the environment. I know that we got lubricants for sewing machines, that contain both PTFE or PFAS like Triflow. We also got some fabrics and sewing threads with PTFE in them. I noticed this note regarding lubricants: https://www.ri.se/en/there-are-no-justifiable-reasons-to-use-ptfe-in-bike-lubes
More things can cause skipped stitches. I remember a video by Uwe, on a Juki 441 class machine that can have a problem with skipped stitches in reverse. Perhaps it can help:
I think it needs to be the manufacturer of the machine, that make the S-twist requirement. I just noticed, that many normal machines using normal Z-twist thread got different direction of the hook relative to the needle. In the previously shown video, you got the hook approaching from right from needle perspective. I have looked at some of my machines and some other videos, and the direction of the hook vary: Hook approach from right: Singer 66, Singer 201, Pfaff 130, Pfaff 138, Singer 501a, Consew 206rb, Pfaff 545 Hook approach from left: CB4500, Machines with CB-hook, Machines with long shuttle, Husqvarna Viking 6010 (and similar with double rotating vertical hook). So it seems that this decision for the designer of the sewing machines was not influenced by the preferred use of Z-twisted thread. I have tried to press a needle with thread through some vinyl and retract it a bit to simulate the loop forming. I think there is a tendency, that the thread gets locally twisted near the needle due to the friction against fabric, and therefore I see a tendency that the thread loop goes a bit to the right as seen in this picture, but you also have a significant variation on that every time you try: When you look this photo, you may prefer to have the hook from right. But I tend to believe, that this matter has little significance.
Yet another question about my Pfaff 545 - tension.
Gymnast replied to LePoisson's topic in Leather Sewing Machines
The Pfaff 545 should be able to handle a Tex 70 thread all right. But I would not risk to buy an unbranded thread from Amazon. Do you know if it is nylon or polyester, bonded or not bonded? Normally a size 16/100 or 18/110 needle size would be used for a Tex 70 thread. A 21/130 needle is too thick. You think you got some problem with the needle thread tension. At lowest tension setting, I think you should be able to set a thread tension below 1.5 Newton just before the take-up lever. At some place of the thread guides you may have some metal damage that creates unregular tension. Try to thread the machine one step at the time and at each step try to feel the thread tension by hand when you pull the thread. It should feel smooth with little variation. Also the thread stand can be the problem - how do it look like? One common beginner mistake can be to have a heavy thread spool turn around a vertical pin, or the thread drops down under the spool. You got both bobbin thread tension and needle thread tension to worry about. While you are not experienced in sewing, it can be nice to be able to measure thread tension (it still is for me). This is a video about measurement of thread tension: https://youtu.be/kINRgj42GnI -
I got a Singer 66, Singer 201 and a Pfaff 30, and they are all quite capable and durable household machines. But they are not that durable as industrial machines. The main problem will be the feed of the leather. The feed dogs may leave permanent marks on the leather surface. When you sew more layers it can be difficult to have an even feed at top layer compared to lower layer. You can do helpful modifications like speed reducer, a heavier tension spring and a food with a slid to the back. I normally prefer to use the Singer 201 and Pfaff 30, because they got full reverse stitch length. You need to turn your work to lock the stitch with the Singer 66. I think the the Singer 66 got lower thread friction at the hook than other machines, so in this way it operates with less driving power. You may find some tips on my channel below. This is a video of a Singer 66 sewing Tex 135 thread in 6 layers of vinyl: https://youtu.be/p6tsFd8kpbM
Can you inform us what exact type of thread, that you use? It needs to be for a sewing machine and of a reasonable thickness. -
I agree, that the normal timing adjustments of needle bar height and timing of hook is important. I just think these adjustments are well defined, because the same needle system got the same distance between needle but and upper edge of the needle eye when needle size is changed. I have had a harder time finding information about needles systems and the dept of the scarf and some of the geometry here, when you change needle size. So this is why I decided to discuss this in forum. I do not have a CB 3200 or 4500, but I have seen videos of them. They have got an oscillating hook and Uwe have made a nice video about it: According to Uwe, the play of the shuttle hook regarding distance to needle needs to be low and I guess it means below 0.1 mm. The distance is adjusted by having more rings (race back) to be replaced behind the shuttle, and the rings got different thicknesses. Uwe comments about the orientation of the race back, that can influence reverse stitching. Nmgunguy, did you adjust the distance by replacing the ring or did you do it in some other way? I got a Bernina household sewing machine with a oscillating CB-shuttle hook. It have got a quite high play of about 0.3 mm regarding distance to the needle. For this machine I see the lowest distance when the needle go down and pass the hook while doing so. The lowest distance is determined by the part of the needle outside the scarf and near the needle eye. Perhaps you will se the same with this much larger machine, because it is also an oscillating hook machine.
After studying the subject a little more, I have also become more relaxed in relation to this subject. Sometimes I have seen strong warnings in some sewing machine forums, but I have never personally experienced major problems with this. But it has sometimes been difficult to completely decipher instructions on adjustment, where e.g. is already quite some slack for a CB shuttle hook - typically 0.3 mm. It is also my experience that these "CB shuttle hooks" with a little slack in outer positions might be able to hit the needle, but that it usually does not cause problems. When sewing Jersey, I have experienced lost stitches, and after an adjustment, it has solved the problem. And it has so often been the case that the machine had been incorrectly adjusted. Here I have not always been aware of the extent to which it could mean something for other needle sizes. Now I know a little bit about that. I have not usually seen the big differences with a change of 0.1 mm. However, an incorrect adjustment to about 0.4 mm too much distance will be apparent when sewing jersey. Due to the normal geometry of double-rotating "hook", those machines can probably be adjustable to a slightly closer distance.
Nmgunguy, So based on your experience and the Renters Book, it may look like the sketch below, when you change needle size on a sewing machine using round shank needles, that is used on industrial sewing machines: If you adjust hook needle distance here to a smaller needle and change to a larger needle, you might encounter problems. It will also depend on the moving geometry. You got a risk, that the needle at eye below the scarf may hit the hook, when needle moves upwards. It depends on the hook geometry and how fast it go past the needle.
I think we all are in for some education here I have tried to look in a German book by Wilhelm Renters from 1957, and I took a copy of one side below. It seems to me, that you are right. There is a lot of needle systems, so I guess we cannot be sure. But Renters explains, that the flat shank needles (typically for household machines) are as I described in my drawing above. But the round shank needles got the center with the point of the needle in center of the shank. Nmgunguy, if you state what needle system your machine use, I guess somebody can answer your question.
Juki DNU-1541S have got a rotating hook. When you adjust the clearance that close, is it then to the bottom of the scarf of the needle? I just think that the hook needs to have a geometry, so the needle do not hit the hook further back, when it moves up. I got four domestic machines 66k and 201k. For both of them, you cannot adjust the needle hook distance without making very serious modifications. It means that they most likely have got the factory setting of distance. When these machines was designed, they were most likely designed for the 705 needle system without any scarf. I do not think, that you can get this needle system any more, and they were mostly replaced by 130/705H, that is used today, and these needles all got a scarf. I measured the distance to the bottom of the scarf of a Schmetz 130/705H, 18/110 universal needle. The dept of the scarf is 0.25 mm. Singer 66k von 1910 - 0.45 mm Singer 66k von 1930 - 0.4 mm Singer 201k von 1950 - 0.5 mm Singer 201k von 1954 - 0.5 mm So the needle hook distance outside the scarf or to the old system would be 0.15 mm to 0.25 mm. So I do not think these machine will ever hit a needle. I have measured the scarf dept of a 10/70 needle to be 0.1 mm and a 22/140 needle to be 0.4 mm. But you do have other kinds household machines, that got the possibility to adjust the needle-hook distance, and then of cause you can get into problems.
