Garyak
Everything posted by Garyak
  1. Gotta have some sort of cylinder arm machine, or hand stitch.
  2. Several folks on my group have them, and use them in their daily business. I have the Techsew version. Not much difference in the machines except in price. You’ll be fine. The key to success with skivers Is knowing angles and how to achieve them on the skiver. Just turning some screws.
  3. Nothing is wrong with the machine. Turn the shaft till the rocker arm Bering lines up with its slot, and the slot on the shaft lines up. You gotta work with it. You cannot hurt that thing so don’t worry about breaking something.
  4. I don’t understand how folks even attempt something without the center finding rulers. I still use the same ones I ordered from Dick Blick art supplies in 94. Definitely one of the first mandatory items needed in the tool box. Work off the center for everything, you can’t go wrong.
  5. What’s up brother? Nice work!
  6. Those are what you’d call distressed leather. It can be anything, bovine, swine, etc. it’s done in the process off tanning.
  7. https://drive.google.com/file/d/1BInD1kgMM1GeHjNmvX9pL5AuArThjFLI/view? Uploaded file: 14218b_ch9_10.pdf
  8. Google search the U.S. Air Force safety keepermans training manual. Skip the oxygen canisters section on to the sewing machine section. Here you will learn in the simplest of terms how to diagnose, and repair anything that could pop up on any sewing machine in the world. Even has a troubleshooting section… find your issue, right next to it is your solution. Any problems that can happen are caused by very specific things. Like skipped stitches or not grabbing the bobbin thread, there’s only a couple things that cause that, needle set incorrectly, wrong needle, presser foot isn’t keeping the material in contact with the bed, add presser foot pressure. I see people saying timing every time a stitch is skipped. With that PDF you will never ask another question online again. Covers 4 of the most common machines, 2 of each kind, oscillating shuttle (31-15), and rotary hook (singer 145 juki 158). Only two that matter to us anyway. You won’t be disappointed.
  9. Above the foot, there should be a stitch length screw/clamp. It slides up and down the feed bar. All the way down to full feed, up for zero.
  10. Garyak
    From the album: More stuff
  11. Garyak
  12. Garyak
  13. Garyak
  14. Garyak
  15. Garyak
  16. Garyak
  17. Garyak
  18. Garyak
  19. Garyak
  20. Garyak
  21. Garyak
  22. Garyak
  23. Garyak
  24. Garyak
