1hp
Contributing Member
Everything posted by 1hp
  1. these work pretty well. https://durston.com/product/ring-shank-bender/
  2. my mother once put a needle through her thumb nail. very gnarly. i always wear safety glasses while using a machine. never know where broken needles might go.
  3. this guy makes some excellent parts: https://heprecision.com/shop/ols/products?page=1
  4. better to get your last machine first.
  5. these are oil wicks for Consew 206: https://parts.jacksew.com/oil-wick-consew-18110/?searchid=227348&search_query=18110
  6. on my 206rb5, the reverse lever shaft is on the right side of the head. there is a hole near your bobbin winder in a similar spot.
  7. looks similar to the original motor on my 206rb5. Consew_CS-1001 (1).pdf Motors-Con-Serv1000.pdf
  8. on my Cobra 4, they are 11/64-40. got some on ebay.
  9. tig weld with nickel rod. pre-heat & post heat. cool slowly in insulation. we do this alot at work.
  10. if you highlight text & right click, chrome has translate in menu.
  11. Check out Bruce Johnson's web page
  12. $15 a foot at McMaster-Carr.
  13. 1hp
    made loop stick
    nice. this is 6061 aluminum.
  14. made loop stick as seen in J.H. Leather video: amazing leatherworking skills on display in her videos! it is 1"x1/2". taper is 8" long. 3/16" to 1/2". cut piece on table saw, tapered on mill & rounded edges on router table with 1/32" radius round ov
  15. @brucejohnson sells bleed knot tool.
  16. nice to have extra feed dogs to experiment on.
  17. bought a Towa tension gauge. think it was more for embroidery or something. gave it away. just go by feel now.
  18. https://www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Store_Code=TTE&Category_Code=sewing-machine-bobbin-style-info some bobbin info
  19. the underside. had to mill the standoffs to get the right height & levelness.
  20. made one out of 304 stainless. recommend buying one from Patrick1. this was a total PITA.
  21. thanks for coming up with this great mod! may put some reference marks on the visible side some day.
  22. made a @RockyAussie adjusting nut. the detent ball is a bastard to get back in. used small tweezers & a toothpick to push it back in its home.
  23. no, it was a very snug fit on the stock Cobra bobbin. fyi, it was 600 revolutions to fill bobbin with #277 Amann.
  24. it is one like this: https://www.ebay.com/itm/326258473298?_skw=bobbin+winder&itmmeta=01JAQKF50DSB1BMDAB33K5AE6W&hash=item4bf6853952:g:fjEAAOSwEFpmMF~R&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKmiOV2Dtfen4bbj%2FZEM989stGDqKzt%2F63vyM8AQSD137QgkXEXH3OqMFlVG815a71hIPxCrZHtGvCL3ZbRivUKq23UVr48lzUoBvGfZO6I0RQTM5C%2FIzQosRW%2BBTzgZGcPjcRTek%2BN71NkIQFFurFUguXwW0ELkykRXKTwE2MiOBnN1UqBVPi0Ib4w%2Bn6160tFDoRUlEqynWUCYxIVie5k5bH%2B7YAweitpsR4QckI5TCkdkc0kNhPvDx9MhdqFowik%3D|tkp%3ABk9SR6bQvPPVZA made a frame out of aluminum to hold the tensioner the same distance from spool as the one on the Cobra. tensioner was off the winder that came with my 206RB5.
