Everything posted by Patrick1
The reason I don't offer the feed dog and plates for the CB 3200 is there is no lateral adjustment for the feed dog. The 3200 has different parts vs a 441 clone. I can't rely on the Chinese tolerancing of thier parts.
http://www.artisansew.com/pdf/specs/TORO_3200.pdf If this is the machine your looking at, it's a 441 clone with a 7/8 thickness capacity. It's same as the Cobra class 3, or the Cowboy CB 3500, not the Cowboy 3200 which is not a 441 clone because the all the parts are not compatible. You're better off with the Toro 3200 because you can upgrade the machine with the narrow feed dogs and plates to sew thinner material. Just the best versatile machine out there in my opinion.
Here's a little history on Singer screw sizes. .125 dia is going to be a #5 as in 5-40 UNF or it could be a UNEF thread. As far as I know the Juki machines and clones still utilize the Singer thread sizes. https://www.singersewinginfo.co.uk/screw_threads
Narrow feed dog FLAT Plate for Cowboy CB4500 and Cobra 4
Patrick1 replied to Patrick1's topic in Leather Sewing Machines
No, that was just a one off I built for the machine but you can get one here. https://leathermachineco.com/product/heavy-duty-roller-edge-guide/ -
Table Top Questions for Cylinder Arm Machines
Patrick1 replied to kgg's topic in Leather Sewing Machines
@1hp You did real a nice job. The flat plate has a nice blend to it. -
Will have the same tables available for the Durkopp Adler 205-370 as shown here. Sure is a beautiful machine. -
Here's a larger table. 14.75 X 8.00 X .375 thick with about 8.875 from the edge of the table to the needle. Still solid as a rock. Looking at offering both tables in Storm Trooper white Cerakote. $125.00, coated. Doesn't break the bank for most folks. -
Cobra class 4: 346 bonded polyester thread? Help!
Patrick1 replied to DieselTech's topic in Leather Sewing Machines
Should work but not guaranteeing it. The feed dog slot is .106 and shorter than the stock dog so not sure how a thicker thread will sew. -
Did you ever lubricate the presser foot bar inside the cover since you purchased the machine? It will stick or not move as freely giving a false pressure adjustment so you end up over compensating the pressure. The presser foot you are using spreads the pressure lengthwise vs widthwise as in @RockyAussiewelded foot. -
Well if it's any comfort, the shipping rate to Australia is cheaper than me sending something to Canada. I don't know what the rates are for the table yet but it weighs 2 lbs. or .907 kilos. @Wizcrafts would need more detail on the Adler 30-7 patcher. Like pictures of what the current plate is off the machine. One other thing on using aluminum, all the ones I ship will have an epoxy clear coat. Will probably offer some in Cerakote but that will cost more. The Cerakote is awesome, better than anodize in my opinion. Redid all my rifles in Cerakote, doesn't scratch as easily. Table works with the stock plate and feed dog also. -
Plate size is 3/8 thick X 8.00 X 7.50 of an inch. Plenty of surface area for sewing vs all that real estate with a slot down the middle. -
I didn't realize Techsew sold an aluminum flatbed attachment for the 441. I don't think they fit the flat plates. Works with round plates too, but you end up with that gap at the plate. My table is 3/8 thick aluminum vs 1/4 inch. Pretty stout and no movement. Won't be able to sell any until after Oct 30, waiting on a shipment of screws. Not everyone sells 11/64-40 screws. The best part is 95 bucks plus shipping. -
Finally got around to making a table for the wife. She loves it. Fits all my flat plates and stout. It will probably stay on 95% of the time. 2 screws and it's off. Been racking my brain for a year for a good set-up. This is too simple. The main thig for her is having a flat place to sew on. Not sure about having a fence and engraved lines for I don't no if we would need them. -
Adler 205-370 feed dog and needle plate
Patrick1 replied to Michiel's topic in Leather Sewing Machines
Adler 205 needle plates and feed dogs are not compatible with the Juki 441. The plates are smaller for the Adler and the feed dog is different. As far as I know there is no lateral adjustment for the feed dog to center the needle like the 441. If your interested in a narrow feed dog and plate for your Adler look no further....https://heprecision.com/ -
The purpose of the holster plate with feed dog is to maintain the the design of the machine. It sews just like the regular feed dog and plate. You can go fast or you can go slow, and even back up with no issues. It's the same with the narrow plates and feed dogs. The
I'm not making black oxide parts anymore. Everything is now stainless. Any parts I did black oxide was with hot salts cooked in a bath. You can get more info here https://feeds.brownells.com/userdocs/learn/Inst-113 Bluing Booklet.pdf -
I have the Xtreme #25 feed dog and plate which has a slot width of .160 recommended for a #25 needle and below. The Narrow presser foot set, Also have the streamlined Double presser foot and left presser foot for the Adler 205-370. -
No I'm only making parts for the Juki 441 or 441 clones and the Durkopp -Adler 205. Guess I should clarify, I'm not making any more feed dog and plates for the CB 3200, but my Narrow presser foot set and left presser foot fits the CB 3200. -
I do make a #25 for the CB3200 but the demand is low for the 3200 so it's best to contact me directly to see what I have in stock. -
Cobra Class 4 Bobbin Set Screw Missing
Patrick1 replied to Brinksleatherco's topic in Leather Sewing Machines
A lot of screw thread sizes on these machines date back to the thread sizes that Singer used in their machines so your pretty much out of luck. Your best bet would have been to purchase a shuttle hook assembly of eBay for 28 bucks and use it for parts. -
arrow presser foot now available for the Adler 205-370. Get to within 1/8 of an inch to the edge on ledges and hard to sew areas. Also have the streamlined Double presser foot and left presser foot for the Adler 205-370. Available at https://heprecision.com/
Fresh of the mill am offering the Adler 205-370 Xtreme #25 feed dog and plate. Upgrade your Adler with a narrow feed dog . Slot width.160. Beats the OEM products in quality and price. Feed dog is adjustable for height. $135.99 plus shipping at heprecision.com .
Folks with the COWBOY CB 3200 now can upgrade thier machines to a Narrow feed dog and plate made specifically for the CB 3200. 3 sizes available. #25 for #25 needles and below, #23 for #23 needles and below, and #20 for #20 needles and below. Check them out at https://heprecision.com/
Inconsistent stitch length Ferdo Pro 2000
Patrick1 replied to jrk65's topic in Leather Sewing Machines
@jrk65 should invest in a XTREME #25 NARROW FEED DOG WITH FLAT STAINLESS PLATE at heprecision.com for your Ferdco. Had a customer purchase one for his Ferdco last week with the same set-up as yours and similar issues. Don't have to stick my neck out here, feed dog, feed dog, feed dog! As @RockyAussie was saying about the oil, it's extremely important. Had another customer who purchased a brand spanking new CB 4500 with feeding issues. Had him pull the side plate, put some oil the presser and center foot bars and everything in between and now it runs as it should.
