SUP
Everything posted by SUP
  1. @sparctek, rather like I do with my laced bags, but that is much easier, since the lace is much wider. At this point, I am making items in which the beauty is in the pattern and leather itself and I keep the stitching discreet and in the background. Perfect time to practice until I get it right. Thank you for the detailed guidance.
  2. @sparctek, that is a lot of useful information! I appreciate that. Ritza is lightly waxed, so it is possible it rubs off as I stitch. I will try waxing it periodically, before it knots. Seeing that it knots over time, it might just be drying out as you say. I am not sure whether I pull it at weird angles - I will watch out for that. One question - how do you get flat thread to lie flat in your stitches? Doesn't it wind around as you go through the stitches? I try to keep it flat as I stitch, rather like when I make laced bags, but this is difficult with the thin thread.
  3. @Handstitched Thank you. Over the years, Valentine's day becomes somewhat routine. This year, since I learnt something new, I thought of making this - something different. Otherwise, I'm more of an April fool's gal - salt in tea. misleading signs etc. What fun!!
  4. @mike02130, I have no idea whether 'higher end' work requires thinner thread than I presume 'lower end' work does. I do know that such thin thread does not work on the larger bags and backpacks that I make for family and friends. I started out recently too, about a year ago, although I am much older. I also don't know the ages of the people who consider Ritza to be one of the best or recommend it and would not presume anything. Older people do try different things too. In my opinion, Thinner thread is needed for items like wallets and watch straps. Larger items like backpacks, saddles etc. need thicker thread. It is possible that Vinymo and Meisi ranges are of thinner thread, correct me if I am wrong, because I searched and could not find thread that is 0.8-1mm in thickness. Rhino, Ritza and others have ranges of thread of thicker diameters. Comparing them would be like comparing key limes to grapefruit.
  5. @zuludog Thank you. I'll certainly try both. I've used Rhino thread from SFL . It is a flat thread as well. It works okay.
  6. Yes I plan to do so.
  7. I must try it then. No more Ritza. I'm seriously annoyed about it right now.
  8. Nice colors, @DieselTech. But it is natural fibre is it not? I am a little leery of that because I wear a lot of cotton and linen and they always break down within decades - the stitching as well as the cloth. Will these not do the same? About the Ritza, it knots at the base of my needles as I continue to stitch! I have stitched so much over the last year and that has never happened with any other thread. I'm a bit grumpy about it - I need to do some more stitching with that thread to complete a backpack and see myself using a pair of pliers or cutting the thread and re-threading the needles periodically.
  9. @DieselTech I've not tried those. Will do so next time I need a new color. That is still not as pricy as Ritza though. I need to check how my stitching is with flat thread. The thread is exactly the color of the leather, so t is not much visible.
  10. Why is Ritza thread considered one of the best? I have been using a variety of threads, from ones on Amazon to the Rhino thread from SFL to, recently, Ritza. I frankly see not much difference between Ritza and others which I consider good. Some are bad in that they are too extra-waxed or under-waxed, both of which can be managed, or too loosely wound but other than that, I find that Ritza is no different from many other, more reasonably priced ones. I wondered if there is any specific reason why everyone recommends Ritza so often.
  11. You get the same cuticle trimmers on Temu too. They work great and that is what I usually use now as well. You can change angles and they are lot more manageable. @Toffe you should be able to get them very easily from China.
  12. SUP
    TandyPro Tools
    Tandy always mention their sales on their site. They sometimes have good deals, especially on overstock.
  13. @fredk I tried map pins but they are sharp as well. The cork is a good idea. Might work better than earring backs. I think I will try those when I receive my metal earring bases.
  14. @DieselTech Yes. My idea of using old earrings really works well. No idea why I bought these when I had something working well.
  15. I like the hummingbird - you caught it very well. Same with the butterfly.
  16. For a quite a few months now, I have been seeing a type of item to hold leathers in place, stitch holders if you will, for sewing leather by hand. I tried them and I do not like them for several reasons: - They are very sharp and can easily scratch the leather as we slip them into the punched holes and draw blood as well. - The not-so-small backs can mark the leather on the other side as well if plugged in too tight. - There is a pulling mechanism to insert it as well as to unplug it, a bit fiddly to use, in my opinion. - My thread always gets caught on the rather large parts of it. - They are rather expensive at, right now, about $1.5 a piece. Now I have been using old earrings for this and they work so well, without any of the problems described above that I thought I should mention that here. Firstly, earrings have blunt ends, so will not scratch the leather - rather like using blunt needles. The earring backs can be replaced with silicone ones or plastic ones or the metal ones can be used gently, so no markings on the reverse side of the leather. We can get flat and tiny earrings which will not come in the way of the thread while stitching. Thy are very inexpensive indeed - especially if one buys earring making kits. You can get so many for a pittance on Amazon or even cheaper on Temu. I say Temu because I have found the same things on Etsy and Amazon that have been available on Temu for a while - sold on Amazon or Etsy or eBay with a significant mark-up. I am currently using plastic earring stud bases and backs but they bend after 3-4 uses, so have ordered metal ones as well. If anyone wants to know what and where, let me know. I will put up that information here.
  17. @Northmount sounds good and would be great to work on. Thank you. I just checked on Amazon. I will check nearby stores as well.
  18. SUP
    Lilac handbag.
    @toxo, patterns make it easier to work with, that's true! At least there is no worry about whether the stitching holes will match!
  19. SUP
    Lilac handbag.
    @toxo that is a beautiful bag!
  20. @fredk, so that's over an inch thick. I should get a slab which is at least that thick - then I don't have to worry about it cracking as I work. @purplefox66 I have not seen any headstone makers here but I see granite countertop makers everywhere. there are several near the Tandy store here. Not yet had the courage to walk in and ask. I should really do that, since the granite slab I use is rather large and very heavy to pick up and keep away each time. A smaller one works so much better, so I still use the broken marble or work on the floor.
  21. Thank you @Northmount. I should do that - attach some felt to the underside of the slab I use, although right now it is placed on a silicone mat. My marble slab was completely flat and used on a completely flat surface. Maybe it already had some flaws that I couldn't see. I have no idea what to check for when buying such slabs.
  22. @fredk, How thick is the marble? Do you use it for punching too? I had one but it cracked ad a piece broke off. So I got a granite one.
  23. Essentially, it is to provide a firm surface to work on. All the things we do in leatherwork - from cutting heavy leathers to punching to skiving and so on, most work best with a hard surface. Granite gives the best all round function Wood would work for some but not others, same with metal. A single granite slab and one does not need to worry about whether the surface is appropriate for the current function. At least, that is what I believe.
  24. @fredk LOL.
  25. Tandy has an equivalent to Tokonole which they even sell in a similar packaging. It appears to be the same or very similar. In fact, in their classes, that is what they provide.
