cazio
Everything posted by cazio
My Latest Speed Rig
cazio replied to Boothill Bob's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I just found my way back to this site and this was one of the first threads I looked at, I'm very happy to have rediscovered this place. I never thought a rig looked complete without the cartridge loops but your rig looks fantastic. -
New Belt
cazio replied to RobDude30's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
RobDude, Belt looks good, I hand stitch everything and I know how long it can take, did you also cement the leather together? Have you tried using chicago screws instead of line snaps? I switched when I discovered it was easier to just punch the holes and not worry about setting the snaps. It also allows you to change the buckle (nickle,brass) and then just use the same color screws. -
I have found that Gum Tragacanth works very well for me, it seals the edges and I've never had a problem. Good luck. Cazio
My First Cowboy Rig
cazio replied to mattsh's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Great looking rig. We all make mistakes, that's what makes it look homemade but when we do it makes us remember for the next time. Cazio -
My Take On A Tucker Holster
cazio replied to smalltown's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Smalltown, very nice work. I have a couple of the Tucker HF1s in black cherry both just like the main one shown on his website. Yours looks great I may have to give it a try, I've been wanting one for my kimber pro. Thanks for the picture. Cazio -
Dye Removal
cazio replied to cazio's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Thanks for the advice guys. I figured I was stuck so I went ahead and dyed the belt black, I'll do my next belt in the cordovan. I'll post some pics of the gun belt when I finish it, cartridge loop stitching isn't fun. Robert -
I guess I've been lurking long enough..
cazio replied to Rock76's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That's nice work. The stitching and moulding looks as good as any of my sparks, kramer or tucker holsters that I own, I hope to see more of your work. Robert -
Dye Removal
cazio posted a topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I did a search and found some info but wanted to ask just to be sure. I have a belt that I have several coats of cordovan colored dye on (tandy pro dye) I wanted to give the belt a bit of a darker finish and used a little bit of black, I then used a leather dye solvent (tandy) to take some of it off. My question is this, is there any other products you folks can recommend for doing this? once dye is applied is there much that can be done to remove it? It isn't that big a deal since the belt is mine and I know I should have experimented on scraps first. I have a holster that I did and the color is just what I wanted on the belt and I wasn't sure how I did it(now I remember) I can always just leave this belt black and do the next one with the color that I wanted now that I remember what I did to get the effects I wanted. Thanks Robert -
I agreee about the simple design and think it would not be that difficult to copy. Instead of using a reinforcement inside I personally would use a thicker piece of leather for the lining, I think something like 7-8oz inside and as the body would be ideal in that it would make it firm enough not to collapse and hold up to some abuse. This thinker lining would also hide your chicago screws that hold the belt flap over. These are my simple opinions.
Fantastic looking work. I can tell you've done leather work before.
Cartridge Belt and Holster
cazio replied to Warren's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I understand what your thinking about there but do you think with the weaving of the loops behind it that you would be able to get a uniformed look once you stitch it to the belt? I recently came across a belt with something like your thinking but it actual may have had the loops stitched on and then the whole piece stitched to the belt. I'll try to find it and post a picture. -
Trying some new methods
cazio replied to JRB's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Yes I use the GB and then use a tandy slicker to smooth it all out and then stitch and mould. I think it works out quite well. If I line the holster then I just dye, stitch and mould. -
Need T-Nut Size Information and sources.
cazio replied to Randyc's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I use 6x32 in my dot pull the dot fasteners and the fit fine, I will have to try the 8x32 and let you know. -
I always dye before stitching and moulding, I also dye the inside and use GT on it to give if a smooth surface. I usually re-dye the piece when I'm done moulding and the leather forms up. -
I get the T-nuts from lowe's and they are for the 6/32 screws. As far as the snaps go I buy them from paragear.com, I buy the pull the dot and they are black and are priced at .85 per set with a $25 minimum order. I like the pull the dot because they can only be release by pulling them in one direction. Hope this helps. -
Very nice. I think the color looks great, nice and deep and your edges also look good. Keep up the good work.
First Cartridge Belt
cazio replied to 99centtaco's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice looking belt. Are there cartridge loops? I would love to see them. Can't wait to see the holster. -
Beautiful workmanship, I REALLY like it. I've been checking out all the holsters and belts I can as my next project is going to be a cartridge belt with matching holster, any advice you guys could share would be greatly appreciated. I'm thinking of using two pieces of stirrup strap for the body but haven't decided if I want the billet style for the buckle or just the tapered ends. -
For you Holster makers
cazio replied to ABC3's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I was reading this thread and wanted to thank you guys for your tips to Hobby Tom. I also stitch by hand and usually try to set my stitch line and sew it up before I mold any of it, I want to try out your tip about partially molding and then setting the stitch lines. From time to time I really mess up my lines and the holster opening is to tight, this may be just what I need. Thanks guys. Cazio -
sass gun belt rig
cazio replied to figthnbullrider's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That's funny. I know just how that fella feels. Nice work. -
What about using chicago screws? I have them on a couple of my belts and it makes it so easy to swap out buckles and keepers. I recently switched the brass buckle with a silver one on my Tucker belt in black cherry and it is even better looking than before as least to me anyways.
I'm all ears Josh, Let me know and I can send you my email or how ever you prefer to do it. I was thinking of a drop loop but am now thinking of a 3" wide straight belt. I'll wait to hear from you. Robert
I'm a newbie here and was looking for help with a gun belt pattern, I want to make the type of gun belt with the cartridge loops and haven't found anything yet. Does anyone know of a good book that might have some. I have made holsters and knife sheathes and a couple of regular belts but this would be my first belt with the cartridge loops. Thanks Cazio
Hey Don, I was browsing the site and found your post, as you can see I'm new here and I was wondering what you might have for a Ruger Vaquero SA? I was thinking about a drop loop style if you have one, I've been doing leather off and on for awhile now and could probably make one up but thought I'd ask. Thanks Cazio
