Members MarlinDave Posted December 1, 2022 Members Report Posted December 1, 2022 Not sure if this a tool or an accessory. My sewing-type green cutting mat is shot. Punched through it too many times. Is there a permanent building material type cutting surfacev I can use? The table has a 2 x 6 top and I take the cutting mat to another table sometimes to cut. Quote
Contributing Member fredk Posted December 1, 2022 Contributing Member Report Posted December 1, 2022 You really cannot beat another self-healing mat. Anything else also gets cut up or blunts blades and needs replacing as well. If you shop around you can s-h mats quite cheaply. I just bought another A2 size for £8.50 (about $10?) I used to do some cutting on a large piece of 6mm thick tempered glass. But that was heavy and it blunted blades pretty quickly. MDF or hardboard is cheap but gets sliced up quickly and needs replacing often Quote Al speling misteaks aer all mi own werk..
Members Hags Posted December 1, 2022 Members Report Posted December 1, 2022 I go to thrift stores and good will. Occasionally you can find them there. Otherwise, mywife is a quilter and use her hand me downs. Quote Not so retired RN. Living on the Washington Peninsula.
Members MarlinDave Posted December 2, 2022 Author Members Report Posted December 2, 2022 I wonder if this Uline product is the same stuff. No grid lines! But I don’t use that much anyway. https://www.uline.com/BL_2820/Workbench-Mats Quote
Members Cattledude Posted December 2, 2022 Members Report Posted December 2, 2022 I use a 4'x4'x1/4" sheet of HDPE on my cutting/layout table. I'm on my second sheet after 25 years... Quote
Members Hags Posted December 2, 2022 Members Report Posted December 2, 2022 I've thought of HDPE, I wonder if you could run a sander over it when it got rough. Quote Not so retired RN. Living on the Washington Peninsula.
Members Burkhardt Posted December 2, 2022 Members Report Posted December 2, 2022 On 12/2/2022 at 1:24 AM, Cattledude said: I use a 4'x4'x1/4" sheet of HDPE on my cutting/layout table. I'm on my second sheet after 25 years... Expand Is it something you can get at the big box stores or do you order at building stores, online ect.? Quote
Members Klara Posted December 2, 2022 Members Report Posted December 2, 2022 On 12/1/2022 at 7:32 PM, 327fed said: Punched through it too many times. Expand I'd buy another cutting mat and remember to not use it as a base for punching... Quote
Members MarlinDave Posted December 2, 2022 Author Members Report Posted December 2, 2022 Good idea. What’s the best base for punching? Quote
Members JayEhl Posted December 2, 2022 Members Report Posted December 2, 2022 You can find HDPE from used kitchen equipment stores, But if you want to go with mats, JOANNS fabircs has them on sale 1/2 price pretty frequently if you have that kind of store. Quote
Members Hags Posted December 2, 2022 Members Report Posted December 2, 2022 (edited) I have a rubber (I guess) poundo board I bought from tandy several years ago. I bought a new one last year, but it is still sitting on the shelf. The old one still works. A lot of folks just use a thick piece of scrap leather. I actually have a punching/setting station set up. I got a knife block from good will, turned it around, drilled a bunch of holes in it, and that is where my hole, half round, corner, snap and rivet setters, and a few other odds and ends sit. I have a piece of 6x12x1/2" steel next to ths poundo pad with a light over it. When I build a chest rig holster, I make several straps and connector pieces that need rivet and snap holes, the ends rounded, etc. Then I have to put all that hardware in. I have a parts bin next to punches with rivets, snaps and Chicago screws I use. A piece of peg board above holds the belt loop punches, screwdrivers, and a. Unch of other stuff that really need a better home. But, it is very nice to have it all in one place within arms reach. Edited December 2, 2022 by Hags Spelling and content Quote Not so retired RN. Living on the Washington Peninsula.
Members Gezzer Posted December 2, 2022 Members Report Posted December 2, 2022 On 12/2/2022 at 4:02 AM, Burkhardt said: Is it something you can get at the big box stores or do you order at building stores, online ect.? Expand McMaster Carr has HDPE in about any size you want . https://www.mcmaster.com/hdpe/moisture-resistant-polyethylene-hdpe-sheets-bars-and-strips/ Quote
Members Charley1 Posted December 2, 2022 Members Report Posted December 2, 2022 If you don't need a very large board, Walmart sells a three pack of HDPE cutting boards, one 11x15, one 8 1/2x 11, and one about 6 x 8. Less than $10. Work fine for smaller projects. Quote
Members Burkhardt Posted December 2, 2022 Members Report Posted December 2, 2022 On 12/2/2022 at 3:56 PM, Gezzer said: McMaster Carr has HDPE in about any size you want . https://www.mcmaster.com/hdpe/moisture-resistant-polyethylene-hdpe-sheets-bars-and-strips/ Expand Thanks Gezzer Quote
Members Burkhardt Posted December 2, 2022 Members Report Posted December 2, 2022 On 12/2/2022 at 7:07 PM, Charley1 said: If you don't need a very large board, Walmart sells a three pack of HDPE cutting boards, one 11x15, one 8 1/2x 11, and one about 6 x 8. Less than $10. Work fine for smaller projects. Expand Do you know where as in online, office supplies, kitchen or the arts and craft depts? Quote
Members doubleh Posted December 2, 2022 Members Report Posted December 2, 2022 I use a scrap piece of red oak under my leather when punching holes. It stand up to a lot of punching and won't damage the punch. Don't have a scrap? Go to Home Depot and buy a 1' piece of I x 4. It will last you a long, long time. Quote
Members Charley1 Posted December 3, 2022 Members Report Posted December 3, 2022 On 12/2/2022 at 7:27 PM, Burkhardt said: Do you know where as in online, office supplies, kitchen or the arts and craft depts? Expand Kitchen utensils and supplies. Quote
Members MarlinDave Posted December 3, 2022 Author Members Report Posted December 3, 2022 Thanks everybody. Eventually I will get a permanent HDPE sheet for the table. I think in the meantime I will get a small hard plastic food cutting board for punching and ask my wife for the big cutting mat for Christmas. She makes the Joann’s/Hobby Lobby circuit and can find one on sale. Got plenty of wood scrap too but I seem to punch twice on the same slot. Quote
Moderator bruce johnson Posted December 3, 2022 Moderator Report Posted December 3, 2022 For punching I would recommend something softer than the HDPE. I recommend either rubber sole sheeting or LOW Density Polyethylene. End gran wood blocks work too. These are much more forgiving on your edges than HDPE. HDPE is brittle and can crack as well. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Contributing Member fredk Posted December 3, 2022 Contributing Member Report Posted December 3, 2022 I keep my cutting mats for cutting and when I need to use a hammer punch I do it on my wood blocks. Sometimes I'll put a piece of scrap leather between the blocks and the project Quote Al speling misteaks aer all mi own werk..
Members MarlinDave Posted December 3, 2022 Author Members Report Posted December 3, 2022 I punch a bunch of my larger holes with fired .223, .243 and 30 cal. cartridge cases. So as these are disposable I don’t guess I need a soft punching area for these. Quote
