MickInMelbs Report post Posted December 8, 2022 What could I do to get dye to properly penetrate? I am working on a piece made from 2 different veg tanned hides. One has taken the black dye well, the other not so much. I attempted to address this by polishing the whole piece in black boot polish, but it seems to have highlighted the difference. My first thought would be to treat the bad sections with Fiebing’s dye-prep and then re-dye. Any other ideas? Quote Share this post Link to post Share on other sites
Sheilajeanne Report post Posted December 8, 2022 What dye are you using? People have commented on Fiebing's USMC black dye not taking well. You can buff until your arms are about to fall off, and it will still be bleeding into the rag. Quote Share this post Link to post Share on other sites
MickInMelbs Report post Posted December 8, 2022 Yes I’m using USMC black. Quote Share this post Link to post Share on other sites
tsunkasapa Report post Posted December 9, 2022 Two different hides will take dye differently, just like two different pieces of wood will take stain differently. Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted December 9, 2022 I can't help you with this one but as for me, I gave up on using the USMC dye because of rub off. now when I want to dye black I use vinegaroon, it turns the leather jet black and no rub off at all. Quote Share this post Link to post Share on other sites
MickInMelbs Report post Posted December 9, 2022 44 minutes ago, bladegrinder said: I can't help you with this one but as for me, I gave up on using the USMC dye because of rub off. now when I want to dye black I use vinegaroon, it turns the leather jet black and no rub off at all. Thanks. Will have to look into that. Quote Share this post Link to post Share on other sites
Handstitched Report post Posted December 9, 2022 One problem I had with some 5mm veg tan that it was a bit shiny, so the dye didn't quite penetrate the way it should have, so I got some fine wet 'n' dry , gave the grain a bit of a light rub and then dyed it, that seemed to have worked. Not saying this will work with your leather, but perhaps try it on some scrap first, see what happens . The dye I use is water based with a little bit of alcohol from Birdsall in NSW Australia . Haven't used your dye before though. HS Quote Share this post Link to post Share on other sites
Dwight Report post Posted December 9, 2022 The other thing you might do . . . it works for browns . . . hit it with a light coat of neatsfoot oil . . . if you have not put a finish on the leather. I had one heck of a time especially with saddle tan . . . blotchy . . . streaky . . . dark & light. Began doing a coat of NFO on every saddle tan project . . . NO MORE troubles. Now I use it on just about everything. May God bless, Dwight Quote Share this post Link to post Share on other sites
MickInMelbs Report post Posted December 9, 2022 5 hours ago, Dwight said: The other thing you might do . . . it works for browns . . . hit it with a light coat of neatsfoot oil . . . if you have not put a finish on the leather. I had one heck of a time especially with saddle tan . . . blotchy . . . streaky . . . dark & light. Began doing a coat of NFO on every saddle tan project . . . NO MORE troubles. Now I use it on just about everything. May God bless, Dwight Interesting. I’ll try that. Cheers 6 hours ago, Handstitched said: One problem I had with some 5mm veg tan that it was a bit shiny, so the dye didn't quite penetrate the way it should have, so I got some fine wet 'n' dry , gave the grain a bit of a light rub and then dyed it, that seemed to have worked. Not saying this will work with your leather, but perhaps try it on some scrap first, see what happens . The dye I use is water based with a little bit of alcohol from Birdsall in NSW Australia . Haven't used your dye before though. HS Will do, cheers Quote Share this post Link to post Share on other sites
nrk Report post Posted December 10, 2022 On 12/9/2022 at 4:02 AM, tsunkasapa said: Two different hides will take dye differently, just like two different pieces of wood will take stain differently. true @MickInMelbs avoid using different hides from different sources. one manufacturer's leather is ok. also, before going for final item, check pieces on small scraps Quote Share this post Link to post Share on other sites
