ToddW
leather on the backside of a watch band
I was going to make a watchband for my iwatch.. What is a good leather to use on the underside of the watch band?  the outside is visible, but the underside is agains the skin and was curious what everyone uses..
Check out this previous thread:
what are folks using for inside padding on the bands?  some are flat and some are padded..
whats a good punch tool for the holes on the watch band.. they are tiny and not sure what size is best.  I think I saw some with 5 of them but they were oval..
https://www.artisanleathersupply.com/collections/all-tools-1/products/watch-strap-punch
Veg tan leather for padding.  You can shape it how you want.
You are asking for size, rather than brand, I guess?
Many watchband makers go as small as 2 mm for a stitching iron/chisel. 2.8 mm is also available.
Make sure the thread size matches the stitch width, of course.
All they have thats not sold out is the5x2.5mm Oblong.. I am making a band for my 45mm Apple watch  Series 7.. this going to be to big?
I don't know.  You could just use a single punch.  Use a wing divider set at half the width of the strap and mark your holes.  Better yet, make a template out of some card stock.
Don't worry about it too much. You won't make  "a" watch strap, but almost certainly several. Make the first one with the tool and leather you have on hand and find out what you really need.
For example, it is not actually necessary to pad or even line a strap. I'd suggest watching a few YouTube videos and going with the most straightforward construction for a first strap.
what is a good shape and spacing for a 5 punch watch band punch?  oval or round... 1.2/1.5/1.8/2.0 MM are the options..
My watch is a series 7 Apple watch I am making bands for..
The form of the punch should conform to the buckle prong. If the prong is round, you want round holes and if the prong is flat(tish), you'll want oval holes. And the size should be the tiniest bit bigger than the prong.
I disagree; the hole is always best to be oval. When the buckle 'prong' goes into the hole and the strap is pulled down it forces a round hole to become oval. This puts strain on the hole and becomes unsightly, but if the hole is oval to start with then this doesn't happen and the strap lies down more neatly
I have, did, replace many vintage car bonnet straps because the round holes had torn the leather trying to make the holes oval. Mostly the straps were still serviceable but had to be replaced because of the mis-shapen holes and the damage around them
I have a feeling that a car bonnet is strapped down with a lot more tension than a watch strap ;) I also think that a round prong would "float around" rather unsightly in an oval hole (the oval is width-wise! See here: https://www.etsy.com/fr/listing/876722338/outil-de-poinconnage-de-bracelet-de?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=watch+strap+punch&ref=sr_gallery-1-1&frs=1&sts=1&organic_search_click=1)
@ToddW Looking at the price of this punch, I repeat @mike02130's advice from above: You do NOT need such a punch! A single prong will do if you measure where you want your holes. I also have a feeling that it might be not as easy as it looks to make nice holes with a five-prong punch (because you need five times more force than for a single one). Never having had one I can't be sure, but I notice the difference with stitching chisels.
The length of the oval should be aligned with the length of the strap, not across it. Really, there is very little difference of tension on a bonnet strap, a belt or a watch strap
Maybe it should, but that's not how the punches are made. Because the punches are meant for punching the holes for buckles with rectangular prongs, as I said above.
I don't know about car bonnet straps. But I do know about belts, saddle girths, stirrup straps and watch straps and I am absolutely certain that I have never ever tightened a watch strap as much as the others.
